Old 03-11-2013, 05:37 PM   #46
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Originally Posted by doug s. View Post
i wanted something like that, too. i made do w/this - the fender is from an r6 yamaha; the fork protectors are standard rm-series, from the rm suzuki that the forks came from...
(yesterday, i installed a 320mm rotor - now i have brakes!)
doug s.
Thanks! RM250 plus 320 rotor is going on my DR in the next couple weeks.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 03-11-2013, 06:50 PM   #47
doug s.
Oddometer: 1,348
be sure you get the right rotor - when i swapped the rm front end on my bike, i used the rm's hub/axle assembly and laced the wheel to it. so i needed to get a rotor that fit the rm wheel. stock dr650 caliper works fine.
doug s.
doug s. screwed with this post 03-11-2013 at 06:51 PM Reason: info correction
doug s. is offline   Reply With Quote
Old 04-08-2013, 02:56 PM   #48
white_bear
Oddometer: 65
Question Message for Dopra
Privet!
PM/pismo sent to Dopra
wb
white_bear is offline   Reply With Quote
Old 04-22-2013, 03:25 AM   #49
dopra OP
dopra's Avatar
Oddometer: 197
Very good traction on my DR, I love this bike
dopra bike and ride - thread http://www.advrider.com/forums/showthread.php?t=855584
dopra is offline   Reply With Quote
Old 04-22-2013, 10:04 AM   #50
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Beautiful Pics!
How does she ride? Any thing you do not like about it?
Old 04-22-2013, 01:57 PM   #51
Thumper Dan
Oddometer: 328
More Pictures..............please
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 04-23-2013, 12:35 AM   #52
dopra OP
dopra's Avatar
Oddometer: 197
http://www.youtube.com/watch?v=EfVK6...ature=youtu.be
Old 04-23-2013, 03:15 PM   #53
el capitan
Oddometer: 72
Hi dopra,
you´ve done a nice job! This winter I rebuilt my 96 and also installed a KTM-front end. In fact, it´s a Husaberg front end featuring a 48 mm WP fork. I only made one shortcut by leaving the stock lower bearing race in the frame after a quick testfit showed that they matched the DR-Z400 bearings I had bought. They didn´t. I only recovered a normal feeling and good handling after I had taken the forks out once more to replace the race with the one that had come with the new bearing.
Another topic was the stock KTM 260 mm brake rotor of the new fork. OK for an offroad-bike with 30 kg less, but not OK for city-trafic, let alone 2up. I found a slightly used set of MotoMaster 320 mm floating disc plus adapter for 100 Euro and mated it with the DR master and the DR brake lines, which solved the brake-problem. I guess with the T63 mounted the tire will be the limiting factor on asphalt, but as soon as you ride this combo with more roadworthy tires you will notice how much weaker than stock the smaller disc is. BTW, stock meant SS brake lines and sinter pads with the original forks and brakes.
el capitan screwed with this post 04-23-2013 at 04:35 PM
el capitan is offline   Reply With Quote
Old 04-24-2013, 07:46 AM   #54
dopra OP
dopra's Avatar
Oddometer: 197
Originally Posted by el capitan View Post
Hi dopra,
Thank You, put here Your thread with modifications, T63 is very good tire, I do not ride very much on asphalt, 70% offroad, but I have to change my front tire. D952 was really good in my last bike, HP2 Enduro, but in DR it is not good on fast turning in sand or mud. I will change it on Pirelli Scorpion PRO. Suspensions work really good
Front brake is OK, I installed TRW pads, new brake fluid, service pump and brake caliper. Brake is OK for me.
Old 04-24-2013, 08:02 AM   #55
deathu
deathu's Avatar
Oddometer: 77
Originally Posted by dopra View Post
Hi,
Very nice work you've done on the DR
I think you are going to hurt the swingarm with that sidestand foot enlargement, if/when you drop the bike on it's left side.
Mine is already trashed from contact with the sidestand, even without the foot enlarger.
deathu is offline   Reply With Quote
Old 05-17-2013, 12:57 AM   #56
dopra OP
dopra's Avatar
Oddometer: 197
I change my rear luggage racks, from TT HP2 enduro, really nice, and not to big
Old 05-17-2013, 08:26 PM   #57
ER70S-2
ER70S-2's Avatar
Oddometer: 6,963
That's a very nice looking rack.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 05-20-2013, 09:01 PM   #58
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
Its amazing that after so years. If you look at all the bikes that have been modified, that so many parts are exactly the same. But there are so many ways of doing other things.
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 06-07-2013, 06:19 AM   #59
dopra OP
dopra's Avatar
Oddometer: 197
Old 06-07-2013, 09:58 AM   #60
Adv Grifter
Oddometer: 6,128
More great pics of the really nicely set up DR650! It looks more like a KTM with the Acerbis tank, low front fender and BIG forks. Very nice work!
Your design really "modernizes" the DR and brings it into the 21st Century.
I hope you get the chance to load up your bike and ride to Mongolia. (Bring water wings rafts ... like the other Polish guys that did it on KTM!)
Times are GMT -7.   It's 06:10 AM.
