01-14-2013, 07:19 PM
#1 |
Oddometer: 86
oil filter on 2012 F800GS
Hey all
I have seen and read a few different articles i am sure this has been addressed before but cant get a firm answer. So..... I ALWAYS use the oilfilter from the dealer however this time it did not have the bmw logo on it and looked alittle different i went on a quick ride no issues at all. My question is i have heard of and seen guys using car filters on their bikes, how much different is it? There are alot that fit my bike and are few dollars cheaper, would it hurt the bike to use a quality car oil filter? Can some one explain the diff? Is it pressure? Also not to start an oil thread but is it true u are to use conv oil first 8000 miles or can i switch to syn? |
01-15-2013, 12:15 AM
#2 |
Oddometer: 470
You can use any oilfilter of any brand as long as it is designed for your F8. It may be a good idea to buy known brands instead of no name parts.
You can change to fully synthetic oil any time after running in phase. Lots of old myths you should not believe as they refer to engines built between 1950 and early 80ies Cheers Steve Sent by Samsung /Tapatalk |
01-15-2013, 06:57 PM
#3 |
Oddometer: 86
Thanks steve i will switch to synth next change. As far as filter goes do u see using car filters as an issue or stick with the oem ones?
01-15-2013, 11:38 PM
#4 | |
Oddometer: 470
Sent from Samsung w. Tapatalk |
01-16-2013, 08:03 AM
#5 |
Crash Tested
Oddometer: 243
I have found these sites to be helpful
Check out Calsci. He makes windscreens but has a good discussion of filters in general here and bike specific cross reference here. I have used Mann filters from Beemer Boneyard with good effect. I have used Bosch 3330 car filters as well.
For more info on lubricants you can go to BITOG
Good judgement comes from experience. Experience comes from bad judgement. |
01-16-2013, 07:36 PM
#6 | |
Oddometer: 86
01-17-2013, 06:34 AM
#7 |
Native Viking
Oddometer: 781
"Be Always Sure You Are Right - Then Go Ahead" 2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße |
01-17-2013, 03:49 PM
#8 |
Oddometer: 296
01-17-2013, 09:44 PM
#9 |
Read Ride Reflect recycle
Oddometer: 146
Great deal
Yes, I think it's a 17mm socket. They are less than $9 on Amazon right now. I've been using them for the last 4 changes. Nice not to have to mess with an oil wrench.
I noticed a bad review from one of the previous links but my experience has only been favorable.
Kyle twitter.com/ducumph 3Rrr = Read, Ride and Reflect 09 BMW F800GS 03 TTR 225 89 Kat GSX600F |
01-18-2013, 04:37 AM
#10 |
Muskokatard
Oddometer: 3,893
Now here's another question.......Can I remove the oil filter without having to remove most aftermarket Bashplates?
Which ones?
"Now this is the shit!" Drcool I can no longer wheelie..
01-18-2013, 08:02 AM
#11 |
Oddometer: 146
Coverage
I would say that the bash plates worth having you will need to remove. Most - if not all come off in a matter minutes.
I take it as a good time to check out the condition of the plate and bolts. The circle of GS'rs that I ride with use the Black Dog Cycle plate. It and Mod would be my recommended form the coverage and build quality and material. That said, I am currently running the Ricochet plate which has held up well. It doesn't have the same coverage as the two mentioned above but when I was on a tight budget it fit the bill. Looking at some the more adventurous rides I have planed in the future I will be going to a MOD or BDC plate. Important thing to note is compatibility with crash bars. For some testimonials of the BDC plate check out GS Riders of Go AZ facebook page.
01-18-2013, 08:18 AM
#12 |
Muskokatard
Oddometer: 3,893
I'm leaning towards the MOD plate. Great price, made in Canada and compatible with the ALTrider crashbars.
01-18-2013, 05:02 PM
#13 | |
Native Viking
Oddometer: 781
So we covered the filter part, here is the oil part (this is what I feed the F8GS and my wife's F650GS): Summer: ![]() Winter: No I am not starting a oil discussion, but simply stating what I use, with superb result. I also have an 2005 ST1300 / 100K, and the engine is silky smooth. No issues. (15w50)
01-18-2013, 05:33 PM
#14 |
Muskokatard
Oddometer: 3,893
01-18-2013, 06:55 PM
#15 |
Oddometer: 86
Where do i buy this i cant find it in AZ. Is it online only. Also i am a bit of an oil snob i dont like going cheap on it i have seen a quart of this before at a bike shop in CA forr 15 that means my oil change would be 50for just oil is it really worth it, and how long will this oil last?
