Old 01-15-2013, 12:01 AM   #1
Sidm OP
Oddometer: 32
GSA 12oo which model to buy
Hi guys lookn to buy my 1st GSA, looking at 06,07,08 vintage ,which is best model to buy???
Sidm is offline   Reply With Quote
Old 01-15-2013, 12:44 AM   #2
RichBMW
RichBMW's Avatar
Oddometer: 2,104
Get the newest you can afford. Ideally a twin cam, but they didn't come out until 2010. Good luck, and don't forget to put some pictures on here once you get one.
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 01-15-2013, 01:43 AM   #3
GSMarc
GSMarc's Avatar
Oddometer: 1,107
if 06 with ABS, avoid the model with 100 little wholes.
Prefer the Z48 ring (from 08/2006)
FOR VEHICLES WITH I-ABS GENERATION 2 (CODE: X630A) :
34 52 7 680 476 SENSOR RING - Z=48 (from 08/06)
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 01-15-2013, 08:52 AM   #4
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,441
Get the '08. '06 and '07 have servo brakes.
- Stu
'09 R12GS, '05 GSX-R1000
Iron Butt # 4999, WERA/CCS EX # 666 (currently, expired), AMA Life Member
Racer, Drummer, Bassist, Software Engineer
StuartV is offline   Reply With Quote
Old 01-15-2013, 08:57 AM   #5
srpuywa
Big 'G'
srpuywa's Avatar
Oddometer: 477
09 or newer
IBA 53683
2015 R1200 RT
srpuywa is offline   Reply With Quote
Old 01-15-2013, 08:58 AM   #6
GSMarc
GSMarc's Avatar
Oddometer: 1,107
@ StuartV
not true.
Build date from 08/2006 are OK.
Visual difference on ABS sensor ring is easy to check.
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 01-15-2013, 09:21 AM   #7
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,726
No servos on my 07, nor TXjames'. But I'd look for an '08 with the "enduro transmission" if you ride anything dirtier than graded dirt.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline   Reply With Quote
Old 01-15-2013, 09:24 AM   #8
JustKip
JustKip's Avatar
Oddometer: 4,640
Originally Posted by StuartV View Post
Get the '07 or '08. Of the 3, only '06 has servo brakes.
Adjusted for reality
JustKip is offline   Reply With Quote
Old 01-15-2013, 10:50 AM   #9
Multiplicity
Oddometer: 172
I really like my 2008, but my 2013 is even better
Multiplicity is offline   Reply With Quote
Old 01-15-2013, 05:20 PM   #10
ridewv
Oddometer: 485
05, 06, are the first generation R1200GS. If these have ABS, most do, it's the less desirable "servo" ABS. 2007 is the same only with out the "servo".
2008 and 09 are the second generation having an improved (larger) transmission bearing, updated Motronic, higher compression, a few more HP, adjustable handlebars and some cosmetic changes.
As others have said all things equal the newer the better.
2015 Road King
2014 R1200GSA
2006 DR650
2000 CB750
1993 R100R
ridewv is offline   Reply With Quote
Old 01-16-2013, 01:48 AM   #11
Sidm OP
Oddometer: 32
Geez just a simple question turns into a shit fight, if only people would use forums for useful info, why dont the trolls open their own forum and solve the problems of the world there. cheers for the positive and formative replys.
Old 01-16-2013, 03:24 AM   #12
GB
Mod Squad
GB's Avatar
Oddometer: 56,767
The pissing contest has been punted...
Old 01-16-2013, 06:54 AM   #13
cliffy109
cliffy109's Avatar
Oddometer: 1,736
That is the correct answer. There is nothing "wrong" with servo brakes but given a choice, I'd opt not to have them. Given the choice, I prefer the enduro transmission that comes on the 08/09. The bars are better as well.
cliffy109 is offline   Reply With Quote
Times are GMT -7.   It's 09:22 PM.
