Old 01-16-2013, 05:31 PM   #16
woodly1069 OP
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,964
Thanks bikerfish! Just one more reason to believe...
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 01-17-2013, 06:36 PM   #17
hoss18
hoss18's Avatar
Oddometer: 123
I have heard that some pinstriping was done by the 'dealers' not always by the factory, but I think it only related to 'specials'?. I would assume that BMW put pinstriping on the outside for economic/production reasons. It is easier to paint/clear coat on a production line in one process rather than interupt to have the striping done by hand and then put tank back on the line. Remember we are going back to before modern digital dye vinyl stickers and the factory process probably used something like silk screening - better endurance? than new stickers but a lot more expensive. Current digital dye stickers dont have very good UV resistance and particulary red dye fade quickly - so modern stickers are under a clear layer to get UV protection. Back in the oldddd days of course the whole process was by hand and they could include paint additives (such as lead - good UV resistance) therefore the striping could have been under the clear or not.... but in the end does it really matter, one advantage if the paint is still good it is easy enough to replace the striping if it is on the outside (but make sure you use 'solid' (all they way through not just dye on top) coloured vinyl so it fades slower.).
BMW - a love hate relationship
hoss18 screwed with this post 01-17-2013 at 06:52 PM Reason: spelling?
hoss18 is offline   Reply With Quote
Old 01-17-2013, 09:01 PM   #18
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,551
Actually it wasn't that long ago. BMW did all their pinstriping by hand at least up until the late 70s and maybe even the early 80s.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-18-2013, 08:45 PM   #19
hoss18
hoss18's Avatar
Oddometer: 123
I suppose it all depends, I met my first girlfriend in the '70s......that feels like a loooong time ago.
Old 04-23-2015, 11:09 AM   #20
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 673
old blue tank
does anyone know the colour name of this old blue?
apologies for link could not figure how to attach photo:
http://www.ebay.co.uk/itm/Tank-BMW-R...vip=true&rt=nc
Ras Thurlo is offline   Reply With Quote
Old 04-23-2015, 11:35 AM   #21
CafeDude
CafeDude's Avatar
Oddometer: 1,574
It looks like Alaskablau (Blue) Metallic
CafeDude is online now   Reply With Quote
Old 04-23-2015, 01:58 PM   #22
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 673
are these the same colour?
the first colour looks darker
[IMG][/IMG]
Ras Thurlo screwed with this post 04-23-2015 at 02:20 PM
Old 04-23-2015, 03:16 PM   #23
CafeDude
CafeDude's Avatar
Oddometer: 1,574
[IMG][/IMG]
No, that's Monza Blue.
Old 04-23-2015, 06:23 PM   #24
garyinalt
garyinalt's Avatar
Oddometer: 74
According to the catalogues,1973 and 1974 had the green metallic and 1975 and 1976 had Nurburgring green.
77 R75/7
78 R100/7
93 R100R
garyinalt is offline   Reply With Quote
Old 04-23-2015, 08:00 PM   #25
bmwrench
Oddometer: 2,182
All the green /5s I ever saw-and I uncrated new ones-were non-metallic. I don't know whether they were clear-coated, but I find it hard to believe that they were. The pinstripe is the final part of the process.
The green bikes were not easy to sell.
bmwrench is offline   Reply With Quote
Old 04-24-2015, 03:41 AM   #26
Mal S7
Oddometer: 101
Originally Posted by woodly1069 View Post
I thought, or thought I was told, that the original process is a single stage from the factory but these guys are using a standard, up to date, two stage process with base coat, clear coat. Any thoughts on the original process that was used when the bikes were originally manufactured? Sure do love the late model look and shine but to me it doesn't seem to fit right on a 40 year old bike.
I am looking into this at the moment and have been thinking exactly the same. Modern two-pack paints, clear over base, just don't look like anything from the 70s. Wayyyy higher gloss levels. Modern paint is glorious but doesn't look period-authentic to me.
We need someone with an original BMW paint job to test by rubbing with solvent - alcohol, and then again with some acetone. If neither will shift it then its a match for modern paints. Anyone want to do this for me on their pride and joy? Anyone?
Mal S7 is offline   Reply With Quote
Old 04-24-2015, 07:01 AM   #27
Beemeup
1978 R100/7
Beemeup's Avatar
Oddometer: 330
I doubt anyone ever offered any metallic paint schemes that weren't clear coated. You would get a very uneven look when the paint wore. Also, metallic coats are sprayed thin to make them pop, they're translucent so they would need protection, including UV.
Beemeup is offline   Reply With Quote
Old 04-24-2015, 07:31 AM   #28
100RT
100RT's Avatar
Oddometer: 744
As suggested earlier, call Holt BMW in Athens, Ohio. He does professional painting and uses Glasurite paint. He is factory certified to paint new replacement parts for BMW. His name is Kent Holt and will sell you the proper paint.
100RT is offline   Reply With Quote
Old 04-24-2015, 06:34 PM   #29
Mal S7
Oddometer: 101
Oh, I don't doubt that they used clear over base in the 70s, at least on the metallics. My question is whether it was solvent (single pack) or catalysed (two pack) paint. Modern two pack paints have a depth and gloss that looks un-naturally excellent on old bikes.
Old 04-24-2015, 07:18 PM   #30
retread3
Oddometer: 1
When i had my 1973 repainted the body shop matched the paint under the side panels.
Audi Cricket Green Metallic matched.
They were surprised the original paint was base/clear.
retread3 is offline   Reply With Quote
Times are GMT -7.   It's 03:51 AM.
