Old 01-19-2013, 06:32 AM   #16
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Let's talk dirty!
Old 01-20-2013, 07:14 AM   #17
vtbob
wanderer
Oddometer: 615
just a point of reference. I just replace my chain at 30k miles. the O ring on one link failed and that one link wore badly( ie stretch almost 1/8 inch) so I had to replace the whole chain. I did replace the front sprocket...it was slightly worn...did not need to but it was cheap and easy.
Looking at the comments here, I do much LESS maintenance....lube about every 1000 miles, clean much less frequently.
why I think this is ok and seems to have worked
there are two wear/lube point on the chain
1) the contact between roller and sprocket,
This is the one every one sees, over lubes...build up dirt and dust. using a Scott oil in my mind is installing a dust and dirt magnet...dumb. Using a limited amount of Wax based oil do reduce this wear....using heavy oil just makes everything dirty
2) the more important between the pins internal to the rollers and the side plates of the chain. It is these second, more important that are lubed at the factory and the lube is kept in place by the O ring (or X rings). It is important that these O/X rings are not damaged and the factory oil does not leak out.
Protecting the O rings.....No harsh brushing, No pressure washing No solvents like WD40 to dilute and flush out the factory lube behind the O rings...you get the idea
Using a lubricant like the dupont teflon helps the O rings stay healthy.
Just my 2 cents
vtbob is offline   Reply With Quote
Old 01-20-2013, 09:00 PM   #18
moe.ron
Pig. Can. Fly.
moe.ron's Avatar
Oddometer: 3,065
I have the same bike. If I bother with chain maintenance at all I soak a rag with WD40 for cleaning, then use this for lube...
Mine gets the treatment every 1000 miles or so, probably step that up a bit as I intend to spend more time in the dirt.
"There's a force in the universe that makes things happen. All you have to do is get in touch with it, stop thinking, let things happen, and be the ball." - Ty Webb
moe.ron is offline   Reply With Quote
Old 01-22-2013, 01:18 PM   #19
GH41
Oddometer: 822
You should try the Dupont chain cleaner. It is compatible with Dupont lubes. I have no use for WD-40 other than for making things rust! GH
GH41 is offline   Reply With Quote
Old 01-22-2013, 03:12 PM   #20
moe.ron
Pig. Can. Fly.
moe.ron's Avatar
Oddometer: 3,065
Never had a rust issue. Use it to clean the crud from my wheels too, works great.
Old 01-22-2013, 03:46 PM   #21
RobbieO
Muskokatard
RobbieO's Avatar
Oddometer: 9,106
Screw it!
Just do like the final drive crowd does...........ignore it till it busts, then whine to your dealer about getting it fixed under warranty!
Only a biker knows why a dog sticks his head out of a car window.
RobbieO is offline   Reply With Quote
Old 01-22-2013, 03:58 PM   #22
moe.ron
Pig. Can. Fly.
moe.ron's Avatar
Oddometer: 3,065
I never actually bothered with it much, but I have recently started covering them in mud. It gets really dirty, really fast!
Old 01-23-2013, 01:09 PM   #23
monkey-butt
Oddometer: 32
I Oil My Guns in Church, just to save on the hassle. But I clean my chain every 1000 or more if it looks grungy. I then do a light spray of chain wax. Chain life also depends on the environment you are `riding in too. remember your milage may vary.
Cheers
monkey-butt is offline   Reply With Quote
Old 01-25-2013, 07:58 AM   #24
biodieselandon
biodieselandon's Avatar
Oddometer: 358
What about This? I am sure there has been plenty of discussion, but this is what I am considering. I notice if I don't maintain my chain frequently it creates a lot more drag and heat.
2013 BMW F800GS, Cordoba Blue, ASC, ESA, ABS
2012 BMW G650GS - 13,000 miles ***SOLD***
"If you're not mixing gas, you're not hauling ass!"
"A clean GS is a dirty shame."
biodieselandon is offline   Reply With Quote
Old 01-25-2013, 08:35 AM   #25
holckster
dougholck
Oddometer: 885
One more thing to maintain and if you don't notice it's empty or has quit working you have an unmaintained chain.
I like the idea of visually checking the chain daily.
So at the end of each day's ride while the chain is still warm I spray with PJ1 Blue Lable.
http://www.motorcycle-superstore.com...hain-Lube.aspx
Doug Holck
Lodi, CA
3 Continents - 7 Countries - 50 States
04 BMW 1150GS Adventure
08 DR650
02 BMW K1200LTe
05 Yamaha TW200
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
holckster is online now   Reply With Quote
Old 01-25-2013, 09:03 AM   #26
biodieselandon
Oddometer: 358
I would still visually inspect and clean my chain if I had the auto oiler. Just wondering how it holds up in off road riding.
Old 01-25-2013, 09:18 AM   #27
guavadude
de-composer
guavadude's Avatar
Oddometer: 902
I ran across this video showing the DuPont vs another chain lube.
http://www.youtube.com/watch?v=Ukigr...e_gdata_player
guavadude is offline   Reply With Quote
Old 01-25-2013, 09:24 AM   #28
guavadude
de-composer
guavadude's Avatar
Oddometer: 902
This is the DuPont chain saver product. I've been using the dupont Multi use spray but will definitely try this out if I can find it.
Times are GMT -7.   It's 11:49 PM.
