01-16-2013, 09:28 AM
#1 |
Rough Rider
Oddometer: 829
Tcat gps ?
I'm in the early planning stages for riding the TCAT (Trans Canada Adventure Trail ) this Summer.
I'm going to need a GPS that can store 200 tracks. At present I'm using a Nuvi 550, which if I'm not mistaken will not support uploaded tracks. Would someone recommend a suitable GPS or is it possible to load the tracks on a micro SD card and use my Nuvi I also have a Garmin Zumo 450, could I use this ? Thanks, Max
Da oggi la strada é senza limiti |
01-16-2013, 11:14 AM
#2 | |
Having a Nice Time
Oddometer: 13,961
Some common units that have mass storage that will handle up to 200 tracks include the Garmin 62 series, Oregon series, and Montana series. I use a Garmin 62S and an Oregon 450 when I require a capacity more than 20 tracks. If I was going to ride the TCAT in a fashion that required that many track segments being loaded on a unit all at once, I'd buy a unit that takes mass storage. It is a small investment as compared to the scale of undertaking the ride. I'd also ride with others that had mass storage in the event one of these units fail. I should also add that the number of waypoints could start to approach 1,000. Some units have a limitation on the number of waypoints that can be loaded. Rather than rely on work arounds, I would just buy a unit that takes 200 tracks and at least 1,000 waypoints. There are some other issues about powering a unit off the bike. The Montana series may offer the best set-up for that out of the three units I mentioned.
Cannonshot.net |
01-16-2013, 05:14 PM
#3 | |
Oddometer: 1,138
Garmin Map 78 with free shipping for $199 from West Marine. Bruce mcnut screwed with this post 01-16-2013 at 05:30 PM |
01-17-2013, 08:29 AM
#4 | |
Rough Rider
Oddometer: 829
My question arose from reading one of your posts in the making of the TCAT thread. Is it possible to convert the tracks to multiple routes and have then in a micro sd card for my nuvi. I'm not trying to be cheap, I really like the 550 nuvi's screen size and units weight. I'll most likely wind up just building a route from the existing tracks. Max
01-17-2013, 09:40 AM
#5 | |
Having a Nice Time
Oddometer: 13,961
But, you could build routes for some long segments and use your Nuvi for those while relying on another unit for the other sections. Once problem with building routes is recalculation. Some units will automatically recalculate when you upload the route and the recalculation might not be visible to you as it may be way further down the line. You have to really pin down the route as you build it. That introduces the potential for the limitations of via points on a route and the number of routes you can store in your unit. Then there is the issue of getting off route and recalculating manually along the way (easily avoided if you are careful). The best course of action for the TCAT is to get a unit that takes up to 200 tracks and follow the tracklines.
Cannonshot.net |
01-18-2013, 05:31 PM
#6 |
Rough Rider
Oddometer: 829
Looks like I'll use the nuvi for general route finding.
I'll be riding out to the start from Idaho, 4,000 mi. and take your advise and use a Oregon 450 for the TCAT ride. What map set would you load in the 450, a 24k topo of Canada, or ? Would you suggest loading the whole set of tracks on the SD card or directly into the GPS memory ? Thanks, Max
01-19-2013, 05:22 AM
#7 | |
Procrastinators
Oddometer: 5,804
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
01-19-2013, 08:38 AM
#8 | |
Rough Rider
Oddometer: 829
After checking the Montana's out, it looks like the 600 would be best for the trip. What maps would you suggest. I see Garmin has the topo Canada set. I'll be riding solo so I need the most robust GPS I can get. Max
01-19-2013, 09:09 AM
#9 |
Procrastinators
Oddometer: 5,804
Topo Canada is pretty good and it is auto-routing so if you only get one Canada map, that would be a good choice. It's cheap, generally costing around $70 at GPSCIty and GPSCentral. Also, it's not locked so you can use it on any/all of your gps units.
01-19-2013, 12:08 PM
#10 |
Having a Nice Time
Oddometer: 13,961
I agree that Topo Canada is a good choice. It is what I use.
Someone inquired about this so I'll mention it now. There will also be an image file available from the TCAT site that contains the tracks converted to a map overlay that will be visible over the top your background map. Think of this as a piece of acetate with the track on it taped the the top of your map. It will show the path as if it was part of your background map and will not rely on track lines loaded onto your GPS. I plan to share this without waypoints (although waypoints can be posted to the overlay). This could allow people with a more basic unit that takes only 20 tracks to load the image overlay of the path (as a map), load the waypoints, and not load the 130 tracks. I sometimes load the overlay on one unit and run the actual tracks on another. You can load the overlay map of the path onto a Nuvi.
Cannonshot.net Cannonshot screwed with this post 01-20-2013 at 05:02 PM |
02-21-2013, 09:43 AM
#11 |
Non-n00b
Oddometer: 11
Tcat to map convert!?
MAXVERT---Why not just take that TCat track set and convert them to a map then you can use it in any Garmin GPS seems odd to have 200 some odd tracks with a zillion different points!? I did this with my snowmobile tracks I had a ton of and wanted one track so if your handy with a computer and google its a rather simple process! Here is one link below and there are several more online. Hope this helps someone not having to buy an extra GPS to go on a certain trip..LOL
http://www.keenpeople.com/index.php?...tid=4&Itemid=3
(Retired) Canadian Pro Freestyle Motocross Rider oh and serious DS Rider! ~ Its Better To Die On Your Feet, Then Live On Your Knees ~
02-21-2013, 09:50 AM
#12 |
Non-n00b
Oddometer: 11
Topo Canada Maps
I'm sure this has been pointed out already but really good free Topo Canada maps for Garmin unit available here:
http://www.ibycus.com/
