Old 01-16-2013, 12:58 PM   #1
centdukesfan OP
Oddometer: 62
crazy things youve seen on parts bikes
maybe there are others out there like me, but I bought an r100 frame with the engine transmission and the drive train... but wait a minute...
centdukesfan is offline   Reply With Quote
Old 01-16-2013, 12:59 PM   #2
centdukesfan OP
Oddometer: 62
Old 01-16-2013, 03:00 PM   #3
RobboJ
Oddometer: 63
I had a family of mice nesting in my air box. They had ran down the intake, through the carb and somehow squeezed through the open valve to make a little nut store in the L/H cylinder. I was amazed when I saw it, shame I had to replace the cylinder as it had rusted where they had pee'd!
I think I have a photo on my phone I will try and upload
RobboJ is offline   Reply With Quote
Old 01-16-2013, 07:45 PM   #4
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,782
I bought a 250 Ducati Monza years ago, at a garage sale. It had the spark plug removed, and had been outdoors. Something had put it's youngster into the cylinder via the plug hole, and fed it until it was too big to get out.
Nothing but bones, when I took it apart.
Old 01-16-2013, 09:50 PM   #5
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,799
EEEeeeeewwww... (imagination going amuck.....)
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 01-16-2013, 09:59 PM   #6
RustyStuff
RustyStuff's Avatar
Oddometer: 769
Thats pretty wild.
Kyle.
1980 Suzuki GS450 Confused bitsabike.
RustyStuff is offline   Reply With Quote
Old 01-17-2013, 12:09 AM   #7
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,541
Not on a motorcycle, but I bought a VW Bus that had sat for awhile. It had one cylinder about 2/3 full of dead ants...
Big Bamboo is online now   Reply With Quote
Old 01-17-2013, 01:29 AM   #8
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,597
Rear suspension on a 60's Triumph I bought years ago. The previous owner though it looked really cool
Rob Farmer screwed with this post 01-17-2013 at 01:41 AM
Rob Farmer is offline   Reply With Quote
Old 01-19-2013, 08:52 AM   #9
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
This lovely speciman sported "mini apes".
An overstuffed short-shag carpeted seat.
A fender mount trailer hitch...the PO had bolted a big chunk of scrap iron under the fender to reinforce it.
The front alloy turn signal housings had big holes drilled in them and fairing support bushings / brackets bolted in.
The right valve cover had a giant blob of epoxy bandaging a (probably) fatal wound.
There was a big hole drilled in the frame below the seat, on the left side, with a plastic pulley bolted up...evidently the PO had a cable / pulley system to retract the side stand.
The throttle grip was one of those ones with a vertical "tumor" eminating from it.
There were probably 5 different places on the frame with various chunks of metal welded on...washers, angle irons, and other unknown tid bits.
Sometime in its' life it "mated" with a Suzuki.....
The throttle control was Suzuki, with a jury rigged throttle cable.
The stock MotoMeter face plate had a Suzuki odometer / speedometer grafted into the unit.
On the MotoMeter faceplate, the owner had scratched the function of each dummy light in the bezel....and his handwriting was very poor....
The rear tail light was a vintage Suzuki "GT" issue.
I fully expected to find a hole in the fuel tank with a dipstick, but no.....maybe that was the next modification on the list before the PO went to the funny farm...
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
bmwhacker screwed with this post 01-19-2013 at 09:06 AM
Old 01-19-2013, 09:19 AM   #10
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
Showed every trait of a .22 caliber bullet wound -
It had been plugged and "bondo'd" over.
Wow...maybe Elvis used to own it?
ABC# 1992
Old 01-19-2013, 09:33 AM   #11
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
"Proper" winter storage for your BMW Project....NOT.....
ABC# 1992
Old 01-19-2013, 10:53 AM   #12
Big Bamboo
Big Bamboo's Avatar
Oddometer: 3,541
I don't have a picture, but when I went to look at a 1973 BMW R75/5 advertised on the local craigslist ($3800 "runs great") I found headers that had been beaten into the heads with a hammer, no battery box (it was tied to the frame with a bungee cord and cracked), bent forks, thumb prints in the bondo on the tank (which still had dents), headlight with multiple coats of sagging, cracked, peeling rattle can paint, instrument cluster painted black, mismatched front fender and it barely ran with the choke lever 1/2 on ("it runs better that way") etc
Old 01-19-2013, 12:29 PM   #13
photorider
photorider's Avatar
Oddometer: 292
Originally Posted by rob farmer View Post
rear suspension on a 60's triumph i bought years ago. The previous owner though it looked really cool
wow...
photorider is offline   Reply With Quote
Times are GMT -7.   It's 12:17 PM.
