Old 01-17-2013, 12:13 PM   #16
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 984
Originally Posted by Andy_unaventurous View Post
Greetings knowers of more than me!
My R80G/S has a totally worn out rear hub, brakes dragging or being ridden on I suspect. Anyway , gotta do something about it for rego. The great guys at BM Ringwood talk of machining out the hub and pressing in a sleeve internal diameter ( when surfaced down) same as a stocky. They are pretty straight guys , but I'm just checking what else is out there? Must have happened to other 31 year old bikes I guess
Anyone hear about this or have any knowledge of any other way, or indeed (ha ha ha ) have a second hand 3 bolt hub for sale?
Andy
Hi Andy,,,say HI to Chris for me...great guy and took care of my G/S when I stored it at his shop a long time ago. Any chance you've seen a white G/S, Harrison brake, panniers that used to belong to a yank a while back ;-).
I've got 2 hubs at a shop in the US midwest who will grind the surface smooth and "spray" a metal coating layer by layer to build up the surface back to stock. Then the brake shoes and surface will be cut to fit. Expensive but a lot less than a new wheel or hub.
The other short term option would be to have the ridge ground down to the current level and have a GOOD brake shop custom fit a softer, thicker brake lining to the shoe to take up the gap. Standard procedure for the bigger brake shops.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 01-17-2013, 12:52 PM   #17
dm635
Let's Roll
Oddometer: 382
Reading this helps me realize that my bike must have the low mileage the seller indicated. He says under 12K. He owned from '94 & the title then had 9K. He also says he couldn't have put more than a couple K on it the whole time. The odometer somehow got scrambled & all digits do there own thing riding. I did get the trip odo working correctly so I'll check off every 999 miles on the maint. log I keep. The seller had 3 beemers when I made this one mine. I hardly ever saw him on it in the 8 yrs I've known him. He was either on the 75 or 76 R90/6 or his '85K100RT.
When I pulled the rear wheel there no ridge on the hub or the drive. No wear there either. I feel I got the best of his 3. The R90 is very clunky I had had no interest in the K bike. The R80 is what was offered to me. Finally having an air head is what brought me here. Now if I can get it ready for spring I'll be a happy boy. Fresh tires, dual brakes & a few pricey items to be safe.
1978 R80/7
dm635 is offline   Reply With Quote
Old 01-17-2013, 12:59 PM   #18
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,512
What shop?
What material?
How much?
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-17-2013, 01:47 PM   #19
peterman
cop magnet
peterman's Avatar
Oddometer: 13,716
I made a fixture for holding the rear drive in my lathe.
the one in the pic was sleeved and re-bored to repair the bearing fit.
I have done a few of these.
peterman
___________________________
"Your God, your rules,,YOU go burn in hell!" LLV
peterman is offline   Reply With Quote
Old 01-20-2013, 11:10 AM   #20
8jest
Oddometer: 18
I have local shop that will reline brakes for $10-20 a shoe. Cheaper than a new set.
8jest is offline   Reply With Quote
Old 01-22-2013, 02:15 AM   #21
Andy_unaventurous OP
Lost but not fearful
Andy_unaventurous's Avatar
Oddometer: 77
Hi, I'll certainly drop your name next time Im out that way. They are good blokes indeed. Hmm cant recall your bike but Im always looking
A
For a hundred, a girl would lend you her Bartok records, have dinner, and then let you watch while she had an anxiety attack.
Andy_unaventurous is offline   Reply With Quote
Old 01-22-2013, 02:17 AM   #22
Oddometer: 77
Thanks Everyone I'm heartened
Hi everyone, sorry for the delay in getting back. This is good news and I'm feeling optimistic that I got the extent of the wear on my rear hub wrong. The bike is not here but she'll be back soon and I'll get back in and look again
Andy
Old 01-22-2013, 02:38 PM   #23
dm635
Let's Roll
Oddometer: 382
Originally Posted by supershaft View Post
Brake drums are a problem for us. Too bad every airhead ever sold didn't have the brake shoe lining replaced with a lining that actually wears versus the drum! Those linings don't get old and hard. They come brand new like that. The drum wear isn't necessarily from high miles or maladjusted brakes. It's from the linings. A curve dug into the center of the drum? I call that a glaciated drum. The same basic U shape as a glaciated valley. It's from those rock hard stock brake shoes. I see it ALL the time on all the beemers I have been around.
Are there any replacement shoes that do wear instead of the drum? One's that are softer.
1978 R80/7
Old 01-22-2013, 03:21 PM   #24
Airhead Wrangler
Adios Mexico
Oddometer: 6,512
Yes and no. Pretty much all the aftermarket friction material is softer (as it should be), but all the aftermarket shoes seem to use the same defective castings that don't fit right. They can be cleaned up with a file to work, but for the amount of trouble involved it's probably easier to just have your oem shoes fitted with new pad material.
Old 01-22-2013, 03:27 PM   #25
supershaft
because I can
Oddometer: 9,116
The only way I have seen it dome properly was sending your shoes to a brake/clutch relining place and have the stock shoes relined. Softer? From what I have seen, ANY shoe lining is a lot softer and works a LOT better from the reports I have got.
Old 01-27-2013, 12:51 PM   #26
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,704
saw a possibility of used hubs in the UK, Motorworks BMW
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 11-16-2013, 02:55 PM   #27
LoJack
LoJack's Avatar
Oddometer: 1,593
I have a drum brake that needs some work. Is the shoe material that Bench Mark Works sells something that will not wear the drum as quickly? The pad thickness on my shoes is about the same as what they have.
Anyone get anywhere with the plasma coating?
LoJack is offline   Reply With Quote
Old 01-28-2014, 07:26 PM   #28
One Less Harley
Oddometer: 4,704
I've contacted a company (Plasma Coatings Arlington, TN) which does plasma coating and will report back when I hear something. I'm not sure if the drum will have to be turned....if so that will create another issue. I'm guessing it will need to be done. I have two rear wheels. I haven't measured the ID but pretty sure one is worn past the limit. I need to measure them both.
Hub spec is- Min- 200mm
Max- 201.5mm
The hubs I have measure 201.676mm ( 124K miles)
. 200.406mm (miles n/a)
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 01-29-2014 at 10:23 AM
Old 01-30-2014, 06:38 AM   #29
acap650
acap650
acap650's Avatar
Oddometer: 681
I'm currently working on a friend's G/S that has a set of freshly relined oem shoes. They do not conform that well to the drum. We will do a short break-in ride then pull the shoes and sand the high spots, just need to be careful not to overheat and glaze the lining.
acap650 is offline   Reply With Quote
Old 01-30-2014, 02:49 PM   #30
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,047
Two questions in my mind:
Is the Midwest company referred to Millenium Technologies by any chance? They have always been one of the top rated outfits for recoating Nikasil cylinders.
Does anyone know if a process I've known as sub-arc welding is suitable for building up the steel lining in the drum? I saw it used on the prop shafts (Monel) of my CG patrol boat in Runyans Shipyard in Pensacola back in the 80s. Due to electrolosys the shafts had sections that had to have several inches diameter turned down on a (very big) lathe. Then the sub-arc machine deposited new metal layer by layer as the lathe turned the shaft at about 1-2rpm. I'm not sure how much heat was generated and transferred to the shaft itself, but one of the shipyard supervisors made it sound pretty low with no visible arc going on.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Times are GMT -7.   It's 02:31 AM.
