Old 01-17-2013, 03:12 PM   #1
photorider OP
photorider's Avatar
Oddometer: 301
R80GS Tank question
Hello All,
I have a '96 R80GS. I often use the bike to run errands and sometimes to get dirty. Although I like the big tank, I don't really need it for shorter rides and was thinking about getting something smaller/lighter for that purpose. Does anybody know what other tanks would fit my bike? I know it's kind of an unusual model in the states because they were never imported here, but from what I understand it's basically a R100GS with an 800 top end. Thanks in advance,
Alex
photorider is offline   Reply With Quote
Old 01-17-2013, 03:22 PM   #2
bikerfish
flyfishandride
Oddometer: 1,655
any tank from r80g/s, st, r65.
bikerfish is offline   Reply With Quote
Old 01-17-2013, 04:30 PM   #3
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,569
A 6 gallon steel R100GS tank would also fit, but would leave a ~3/4" gap at the bottom front edge of the saddle, with the top making contact. Perfectly functional, but not aesthetically pleasing to some. The R80ST / G/S tank is just too small for my liking. It hits reserve around 120 miles and only has one petcock and thus traps a lot of gas in one lobe which you have to lean the bike way over to use. I was able to get 240 miles out of the GS tank on a couple of occasions, including reserve.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-17-2013, 04:43 PM   #4
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 838
Google R80GS Basic, fitted with small tank as standard.
https://www.facebook.com/#!/groups/AirheadsAustralia/
Bulldust is offline   Reply With Quote
Old 01-17-2013, 04:47 PM   #5
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,813
Nice tank, yeah you need a beater tank!!!! I've got three tanks for mine. The stock little R80 G/S, a R100GS tank, less seat hook. these are nice tanks, plus the beater 43l HPN which I don't have to fill completely plus half full it carries the weight low.
I have a tank from an R65, which has been sealed and is in primer ready to paint.No dents. It's a little larger than the small G/S tank by about 1/2 gal. It does fit a G/S, but is snugger at the seat. PM me if interested.
Plus here's list of tanks.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 01-17-2013 at 05:03 PM
Old 01-18-2013, 06:08 PM   #6
photorider OP
photorider's Avatar
Oddometer: 301
Thanks for all the info, guys. Very helpful.
OLH, I sent you a PM.
Old 01-19-2013, 01:01 AM   #7
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
The ST tank is the only one to go for. The R65/45 tanks look very similar but have a different fit, you'll need to take a hammer to the underside to get them to fit past the electrics tray and even then there will be a slight conflict with the rear of the tank and the side panels. The rear of the tank is also slightly longer forcing the nose of the seat back.
Not the best shot but you can see how the sidepanels just touch the 65 tank. The seat looks slightly baggy where the nose of it presses against the tank. The ST tank on the other hand is a perfect fit.
I put this on as a temporary while I got a leak fixed on my ST tank, unfortunately it's still on there.
Nice bike BTW The Basics are much sort after machines. They have a unique rear subframe that's similar to the early Mono one but made from stronger tubing and with tubes in slightly different places to allow the paralever mudguard and side panels to fit. this is the Basic subframe next to a mono one.
Rob Farmer is offline   Reply With Quote
Old 01-19-2013, 07:29 AM   #8
photorider OP
photorider's Avatar
Oddometer: 301
Thanks for that, Rob! Looks like I need to hunt down an ST tank.
Follow-up question:
Will the R80G/S saddlebag mounts fit? Or do I need to look for R100GS mounts? Maybe neither will work?
Thanks for the input.
Old 01-20-2013, 08:38 PM   #9
Other Bob
Other Bob's Avatar
Oddometer: 450
Photorider,
I have the opposite problem and, so, perhaps the perfect solution for you. I have an '85 R80 mono on which I run a later model R100GS 6.3 gallon tank. Fits perfectly, has a nice pleasing look like it belongs there proportionally. Easy 220+ range + reserve without carrying the extra 12lbs of fuel up high in your bigger tank.
Me? I'd like that extra capacity and range of your tank and I don't mind the weight. So, interested in a trade? There's only a few hours of highway between us ... meet for lunch and sniff tanks??
Bob
(248) 703-0662
Other Bob screwed with this post 01-22-2013 at 01:35 AM Reason: Doh! Extra 2-gal x 6-lb/gal = 12-lbs, not 30-lbs ... f'ing advanced math!
Other Bob is offline   Reply With Quote
Old 01-21-2013, 07:16 AM   #10
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,911
Originally Posted by MotoKaw View Post
Photorider,
I have the opposite problem and, so, perhaps the perfect solution for you. I have an '85 R80 mono on which I run a later model R100GS 6.3 gallon tank. Fits perfectly, has a nice pleasing look like it belongs there proportionally. Easy 220+ range + reserve without carrying the extra 30lbs of fuel up high in your bigger tank.
snipped
Howzabout a PICTURE?
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 01-21-2013, 09:09 AM   #11
photorider OP
photorider's Avatar
Oddometer: 301
Thanks for the offer, Bob.
Unfortunately, the bike is located in Guatemala.
Old 01-21-2013, 03:29 PM   #12
_cy_
Oddometer: 6,370
leave it alone .. put less fuel in
_cy_ is online now   Reply With Quote
Old 01-21-2013, 06:12 PM   #13
photorider OP
photorider's Avatar
Oddometer: 301
Don't get me wrong. I love the tank. I'm just afraid of trashing it while off-roading. As OLH suggests, I need a "beater".
Old 01-21-2013, 07:22 PM   #14
Other Bob
Other Bob's Avatar
Oddometer: 450
Photorider, check your PM's for a link to another tank.
Bpeckm, I'll post some pictures of mine tomorrow (wrong computer at the moment).
Bob
Old 01-21-2013, 11:09 PM   #15
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
Follow-up question:
The left hand pannier frame is the same as the g/s one but the right hand one is unique to the Basic. You also need the g/s rear rack to attach them to. Hepco and becker used to make a system to suit.
Rob Farmer screwed with this post 01-21-2013 at 11:18 PM
Times are GMT -7.   It's 03:06 AM.
