Old 01-18-2013, 08:53 PM   #1
Ron Seida OP
Adventman
Ron Seida's Avatar
Oddometer: 1,260
This is why you put Anti-Seize on your spark plugs!
Listen up kids! Always put Anti-Seize, or any other high temperature non-seizing compound on your sparkplugs so you can avoid the three hours of nervousness i endured today removing a seized sparkplug from a /2 cylinder head. In the end i prevailed... Boo-Yah!
"¿Qué sería de la vida si no tuviéramos el valor de intentar algo nuevo?"
Van Gogh...
"Your the only guy i've met driving a BMW who isn't an asshole."
D. Irwin...
Ron Seida is offline   Reply With Quote
Old 01-18-2013, 09:26 PM   #2
Steve G.
Steve G.'s Avatar
Oddometer: 7,352
Agree totally. Very much overlooked, more so in the automotive area where cars run for years on 1 set of plugs, most with aluminium heads.
Copper never seize is better imo, not aluminium.
Steve G. is offline   Reply With Quote
Old 01-18-2013, 09:31 PM   #3
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,493
Ya good point. I'm gonna do it.
I had a "rough" feel removing one R100S plug yesterday. Threads looked ok though.
I'll follow up with some anti sieze tomorrow!
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 01-18-2013, 11:02 PM   #4
Ron Seida OP
Adventman
Ron Seida's Avatar
Oddometer: 1,260
This one was pretty scary! The metal insert is only pressed into the head. The moment it broke loose, i wasn't sure if i was spinning the plug, or the insert out of the aluminum. i soaked it with liquid wrench for 4 days and it did nothing, drilling out the spark plug was the only option. These heads are in really good shape, i feel very fortunate i got the plug out and didn't screw it up!
Van Gogh...
D. Irwin...
Old 01-19-2013, 01:39 AM   #5
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,674
Copper verses the silver stuff..
Which is the best application for each of these on our bikes? If I had to have one, I'd buy the copper stuff for the exhaust nuts and sparks plugs, but does the silver stuff have a specific use?
boxerboy81 is offline   Reply With Quote
Old 01-19-2013, 02:08 AM   #6
ritetwist
ritetwist's Avatar
Oddometer: 180
Without mentioning brand names, the kopr-kote I have says rated to 1500 deg.F,,contains copper and graphite.
The never-seez (silver) is rated to 2400 deg.F.,contains nickel, graphite,and aluminum.Both contain other petroleum
additives, etc. Both meet a military spec MIL-PRF-907E,For what its worth.
Use whatever makes you feel good.
I believe in using something,not too much.
Afraid to sleep for fear of missing something.
ritetwist is offline   Reply With Quote
Old 01-19-2013, 02:13 AM   #7
Paul_Rochdale
Paul_Rochdale's Avatar
Oddometer: 150
Surely this is what EVERYBODY does? No? 45yrs tinkering with bikes and I've done it since day one. And I didn't need to know what bloomin' Military Spec it was.
Paul_Rochdale is offline   Reply With Quote
Old 01-19-2013, 02:28 AM   #8
ME 109
ME 109's Avatar
Oddometer: 3,143
Anti-seize?
I use natural airhead technique..
It's never together long enough for anything to seize.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 01-19-2013, 05:04 AM   #9
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,625
Originally Posted by ME 109 View Post
Anti-seize?
Ya, a schmeer of oil on the threads, they will be out again soon enough.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 01-19-2013, 05:28 AM   #10
JonnyCash
turd polisher
Oddometer: 1,654
^seriously, I must have mine out 2 or 3 times a season. I don't use a torque wrench, but I am very light handed when tightening them up. I only put never-seize on stuff that's going to stay together for a long time, or highly seize-prone things like exhaust header nuts.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is online now   Reply With Quote
Old 01-19-2013, 05:59 AM   #11
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,559
I've used the Loctite nickel-based Anti-Sieze since Istarted working on VWs in the 1960s.
One problem with aluminum heads is over-tightening. Use a light touch or a torque wrench. If the plug goes in with resistance, run a sparkplug thread chaser into it-- carbon can sometimes build up on the threads.
On some years of the /2 series there was a problem with the aluminum alloy being too soft and strip-prone. Called "butterheads". I disremember which year(s); I think Vech (Benchmarkworks) has something at his website.
--Bill
'73 R60/5 Toaster
Old 01-19-2013, 06:36 AM   #12
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,607
I don't think they make aluminum anti-seize, do they? The silver stuff you're probably thinking of is nickel anti-seize. Regardless, you're right, copper is better in hot applications like this.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-19-2013, 08:50 AM   #13
danedg
Horizontally Opposed
Oddometer: 6,775
If the heat of any part of a /2 exceeds 275F you're in deep doodoo. I'd not be too worried about 1400 vs. 2400 heat resistance. I don't think my plugs have been in the bike longer than a month without being checked for something or another. And they get changed just about every year....
You DO change your spark plugs often, DON'T YOU????????
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic, '78 Honda Hawk...... the Axles of Evil!
danedg is offline   Reply With Quote
Old 01-19-2013, 08:53 AM   #14
Multiplicity
Oddometer: 172
Exactly
Multiplicity is offline   Reply With Quote
Old 01-19-2013, 09:02 AM   #15
Multiplicity
Oddometer: 172
No! If it's not a 2 stroke. Today's spark plug technology is far superior to the old copper core of yesteryear.
Platinum, Double Platinum and Iridium plugs will run for much longer and don't require frequent replacement
They also don't require as much coil saturation to get a higher KV discharge from the ignition system Today's technology has made many great changes and advancements.
The biggest benefit is better MPG and less maintenance costs.
Good high quality plugs cost more, but they run much longer. Denso plugs are marine grade. They're also coated, but I still use copper anti-seize on all spark plugs, wheel bolts and
anywhere dissimilar metals are used or has the ability to corrode from the elements.
Multiplicity screwed with this post 01-19-2013 at 09:10 AM
Times are GMT -7.   It's 04:34 AM.
