Old 01-17-2013, 06:57 PM   #1
Little Bike OP
Air/Clutz Sue
Little Bike's Avatar
Oddometer: 1,304
Bent Brake Lever Protection?
Dumped the xt250 and bent up the brake lever. Beside protecting your hands do the (I don't know what to call them, I'm such a noob.....) "things" that go across the front of your grips keep your clutch and brake lever from getting curly-cued in a dump?
In your helmet, no one can hear you scream.
Old(ish) Chick on a Bike
V-Strom 650 Adventure "Maxwell"
DR-Z400s "Little Donkey2"
Little Bike is offline   Reply With Quote
Old 01-17-2013, 07:12 PM   #2
MrHix
MrHix's Avatar
Oddometer: 384
If you want protection for the levers, and your hands, you should look up handguards. They (normally) mount to the bars and in the end of the handlebars to give you protection from trees, etc.
Try searching for rocky mountain or motorcycle superstore for examples.
Welcome to the board with your 449 posts!
MrHix
MrHix is offline   Reply With Quote
Old 01-17-2013, 07:29 PM   #3
Little Bike OP
Air/Clutz Sue
Oddometer: 1,304
MrHix
449 posts - noobs ask lots of questions!!!
Old 01-17-2013, 07:50 PM   #4
Little Bike OP
Air/Clutz Sue
Oddometer: 1,304
How about the G2 Competition Ergonomic hand guards?
Old 01-18-2013, 10:57 AM   #5
eightup
eightup's Avatar
Oddometer: 126
Barkbusters would be the term you are looking for. You can get them as just the metal bar or with a plastic shield.
eightup is offline   Reply With Quote
Old 01-18-2013, 11:09 AM   #6
switchback
Eatin' Dirt Since 1982
switchback's Avatar
Oddometer: 1,485
I recommend the Tusk aluminum handguards here:
Tusk-D-Flex-Handguards
I also recommend a "Brake Snake" for your foot brake and even your shift lever.
Tusk-Brake-Shifter-Lever-Saver
David
Wind is strong and cold
Rain blurs the winding road ahead
I live on two wheels
switchback is online now   Reply With Quote
Old 01-19-2013, 11:42 AM   #7
Little Bike OP
Air/Clutz Sue
Oddometer: 1,304
Thanks all
How does the Tusk brake/lever saver work? I kept looking for pics, but could only find pics of the product, not installed.
Old 01-19-2013, 12:38 PM   #8
C/W
Oddometer: 99
Originally Posted by Little Bike View Post
Thanks all
The brake snake attaches to your shifter/brake *foot* levers. You attach an end to the end of the foot levers (drill a hole if needed), the other end will go somewhere on the engine or engine guards. These prevent sticks and plants from jamming inbetween the foot levers and the engine case. Getting stuff caught in there can cause bent/broken levers.
Guards attach to the end of the handlebar, often replacing the bar weight. The other end of the guard attaches to the inboard part of the handlbar.
I have Cycra guards on my bike, other brands are Acerbis, Barkbusters, Tusk etc...
There are plastic variants as well as aluminum ones. The aluminum guards will have a plastic roost deflector attached to them.
Keep in mind, every bike is slightly different in terms of handlebar, brake/clutch lever size, etc... This means that not all guards will fit every bike without fitment issues. You'll often have to do adjustments to get them to fit.
Best bet is to find someone with the exact bike w/ handlebar, controls and use whatever guards they are using. Then you'll know they'll fit (more or less)
C/W is offline   Reply With Quote
Old 01-19-2013, 09:18 PM   #9
Little Bike OP
Air/Clutz Sue
Oddometer: 1,304
That's good advice to find somebody with the same bike. Thanks for the rundown on how the lever savers work.
Old 01-20-2013, 04:50 AM   #10
greer
Oddometer: 3,725
Do you have a Cycle Gear nearby? I'm thinking I read the Tusk and Trackside guards were similar:
http://www.cyclegear.com/eng/product...rds/web1009960
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 01-20-2013, 05:03 AM   #11
davsato
Oddometer: 799
"barkbusters" is a specific brand but is the generic term for what you want, "handguard" could just be plastic ones that arent up to the job, and could be just the flappy elephant ear windshields.
whatever brand, go for a good metal 'barkbuster' and put a windshield 'handguard' on top for wind protection. you will see exactly what we mean when you start looking at different brands. acerbis even do some with built in indicator/winker signal things whatever you call them over there
Dave
davsato is offline   Reply With Quote
Old 01-20-2013, 10:10 AM   #12
Shockdoc
Shockdoc's Avatar
Oddometer: 47
You also should look at "highway dirt bikes" Paul is a great guy with really good stuff.
Shockdoc is offline   Reply With Quote
Times are GMT -7.   It's 02:28 PM.
