Old 01-18-2013, 01:47 AM   #1
Dickyb OP
Bewildered Adventurer
Dickyb's Avatar
Oddometer: 1,038
R60/6 Centre Stand question
Hi Folks, I'm in need of help again which isn't readily available here in Turkey
I have decided to fit a centre stand to my R60/6. The stand looks like this
The problem I'm having is trying to locate where the springs for the centre stand attach to the bike frame. I can't see any hooks on the frame. Or is there a separate part which attaches to the frame from which the springs hang?
Thank you in anticipation
DickyB
Dickyb is offline   Reply With Quote
Old 01-18-2013, 01:57 AM   #2
chasbmw
Oddometer: 2,211
DickyB
Parts no 6 and 3 in your diagram are the spring hangers, they fit between the frame and the engine on the front engine mount rod.
Charles
1971 Commando Fastback
Old 01-18-2013, 02:50 AM   #3
Dickyb OP
Dickyb's Avatar
Oddometer: 1,038
Wow, chasbmw. That was quick. Thank you very much.
So I've had a look at the bike and parts no 6 and 3 of course aren't present on the bike
I must admit that I am having trouble imagining how those springs could hold up such a heavy lump of metal from such a forward position. I've done a google Image search to try and find a pic of one fitted and my Boxer manual doesn't show one either. I wonder if anybody could post up a pic or a link to a pic so that I could see what I am meant to be looking at.
Kind Regards,
DickyB
Old 01-18-2013, 03:19 AM   #4
chasbmw
Oddometer: 2,211
On part 3 you can just see the hole that the spring clips into.
Charles
Old 01-18-2013, 03:20 AM   #5
chasbmw
Oddometer: 2,211
Try Motorworks in the UK, they will have all of the parts you need, either new or secondhand.
Charles
Old 01-18-2013, 03:33 AM   #6
Dickyb OP
Dickyb's Avatar
Oddometer: 1,038
Thanks Charles. The penny has dropped. Checked Motorworks and they have got the bits. Thank you
David
Old 01-18-2013, 05:29 AM   #7
chasbmw
Oddometer: 2,211
some photos:
Charles
Old 01-18-2013, 05:57 AM   #8
Dickyb OP
Dickyb's Avatar
Oddometer: 1,038
Charles you are a star. Got it now and also got the front spring fixing points on the frame. A picture paints..................
Thanks for taking the time
Cheers,
David
Old 01-18-2013, 06:11 AM   #9
radmeister
not there
radmeister's Avatar
Oddometer: 52
R60/6 Centre Stand Question
Dicky: I am sure that something like the following has been posted elsewhere.
After you have installed your eyelets, bolt on the centre stand. Put the bike on the centre stand. Feed one of the springs through its eyelet. Then get a zip tie or two and make a closed loop. Hook one looped zip tie over the non attached end of the spring and pull it over the notched pin on the centre stand. Repeat for the other spring. If the spring is really strong, you can make a loop big enough to take a small piece of wood to use as a lever. I did not need to do so. A few nights ago, I did initially try perform this procedure with the bike on its side stand, having secured the centre stand in the position it would be in while riding. Didnt work for me - couldnt stretch the spring far enough - and after an hour or so of cursing, I saw the light and put the bike on the centre stand. Less the five minutes later, the job was done.
BTW, love your photos and reports. As I write this, I am looking through my kitchen window at several inches of freshly fallen snow. I will be that your view is quite different.
durate, et vosmet rebus servate secundis
radmeister is offline   Reply With Quote
Old 01-18-2013, 06:45 AM   #10
Dickyb OP
Dickyb's Avatar
Oddometer: 1,038
Hi Radmeister,
Thank you for your kind and wise words. I'd have just banged away, gradually getting angrier with the more skin I shed from my knuckles
Not that good a day today. Got Jasper worried
Cheers,
Dickyb
Times are GMT -7.   It's 09:49 PM.
