Old 01-19-2013, 09:19 AM   #16
Ron Seida OP
Adventman
Ron Seida's Avatar
Oddometer: 1,256
Ive used both copper and silver/nickel with similar effects. I really don't think their temperature ratings really apply to us as they're both rated well beyond their expected duty in our case. These heads were dug out of a pile of parts, im really glad the previous owner didn't try to forcefully remove those plugs.
While were on the subject of cylinder heads, heres a question for you ole' timers. At what point did BMW put larger steel inserts in their heads? One of the heads in my possession has larger holes than i was expecting.
"¿Qué sería de la vida si no tuviéramos el valor de intentar algo nuevo?"
Van Gogh...
"Your the only guy i've met driving a BMW who isn't an asshole."
D. Irwin...
Ron Seida is offline   Reply With Quote
Old 01-19-2013, 09:20 AM   #17
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,600
Originally Posted by Multiplicity View Post
No! If it's not a 2 stroke. Today's spark plug technology is far superior to the old copper core of yesteryear.
Platinum, Double Platinum and Iridium plugs will run for much longer and don't require frequent replacement
Very true. Even a quality (Bosch, NGK, ND, . . .) base level "fat" core plug will last a long time in these engines assuming all else is well. It's not a race bike.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 01-19-2013, 09:32 AM   #18
danedg
Horizontally Opposed
Oddometer: 6,665
Platinum, Double Platinum and Iridium plugs will run for much longer and don't require frequent replacement.
Only problem is, these plugs won't work well in a slash 2. They're not 0 resistance. That leaves the Bosch and NGK that still utilize the Old Technology.
I like the idea of some slippery stuff on the threads.
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
danedg is offline   Reply With Quote
Old 01-19-2013, 09:34 AM   #19
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,729
"Butterheads"
The heads that had problems with the metallurgy were from 1962-67. The information is on Duane Ausherman's website: http://w6rec.com/duane/bmw/head/index.htm
Big Bamboo is offline   Reply With Quote
Old 01-19-2013, 03:14 PM   #20
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,545
Originally Posted by Airhead Wrangler View Post
I don't think they make aluminum anti-seize, do they?
I used to use Wurth AL1100, but it's a bit expensive for me these days, so just use a copper antisieze.
http://www.wurth.co.uk/product/al1100
motu is offline   Reply With Quote
Old 01-19-2013, 03:44 PM   #21
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,662
I use this one
It's the Permatex Anti Seize compound in the jar with a brush. I only have several of these because I would over the years not be able to find the last one I bought and so I bought another one. I've been using the same Anti Seize for over 40 years. It's the one I was told to use when I did Volkswagen work and I don't see any reason to change now.
Permatex's Web Page says this has Aluminum, Copper and Graphite in it. It's the silver one.
I have not used any Anti Seize on spark plug threads on my Airhead. I've not had a problem except when I first got my bike 12 or 13 years ago and the threads on one side were messing up. I rethreaded the Aluminum with the KD spark plug threader and have never had a problem since. I think I have now done both sides with the same threading tool which is part of my on board tool kit.
I have recently been thinking I will add a small touch of Anti Seize. Good stuff. I just never bothered before.
---Albert Einstein
disston is online now   Reply With Quote
Old 01-19-2013, 05:20 PM   #22
Yakima
DL 650
Yakima's Avatar
Oddometer: 381
NGK says...
http://www.ngksparkplugs.com/pdf/tb-...1antisieze.pdf
Be yourself. Everyone else is already taken.
Yakima is offline   Reply With Quote
Old 01-19-2013, 05:22 PM   #23
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,790
I never use anything, as I love Helicoils, and keep hoping my plugs will strip, giving me an excuse to pull out the coil kit!
I am a big fan of Permatex Anti Seize (as Disston posted) other stuff may work well too, but this is for sure going to work!
Don't use much, a little dab will do, and damn is it messy when you use too much!
Old 01-19-2013, 06:44 PM   #24
villageidiot
Oddometer: 1,827
i like to take some of that silver permatex, and cut it with a silicon grease.
called affectionately by one of my gone mentors "mother in laws vaseline"
i put it on plugs, wheel studs, brake bolts, anything that has dissimilar metals, or heat.
makes it much easier for the next guy to work on, because it might be you.
villageidiot is offline   Reply With Quote
Old 01-19-2013, 07:17 PM   #25
Ron Seida OP
Adventman
Ron Seida's Avatar
Oddometer: 1,256
Originally Posted by Yakima View Post
Thats really interesting . Thanks for the link.
Van Gogh...
D. Irwin...
Old 01-20-2013, 08:37 AM   #26
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,510
Originally Posted by disston View Post
I use this one
Same stuff I have been using for about... ah hell, a long time.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 01-20-2013, 09:12 AM   #27
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,822
Not antiseize, but, when in trouble removing the part as in Post #1, I have had good luck with KROIL and the BlueWrench (use your propane torch to heat up the aluminum head, which expands more than the steel... AFTER a good soaking of KROIL)
...ymmv, imho, all the standard disclaimers are summoned......
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 01-20-2013, 10:53 AM   #28
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,885
An Antiseize Thread is a subcorollary of the dreaded Oil, Tyre or Battery thread. :(
I've never seen a sparkplug thread break from overtorquing when using antiseize, but I've seen many stripped aluminum threads from NOT using it.
Your call. :)
--Bill
'73 R60/5 Toaster
Old 01-20-2013, 11:37 AM   #29
Ron Seida OP
Adventman
Ron Seida's Avatar
Oddometer: 1,256
Your call. :)
--Bill
I have to agree Bill, i've never seen a broken plug like the one shown... ever! I think you would need to be a ham-fisted hooligan to do that kind of damage .
Van Gogh...
D. Irwin...
Old 01-20-2013, 11:41 AM   #30
Ron Seida OP
Adventman
Ron Seida's Avatar
Oddometer: 1,256
In all cases of aluminum i would agree, except this one. If you look closely, you can see there is a steel threaded insert pressed into the aluminum. If i were to heat up the head, i would only expand the head more than the insert, increasing the chance of spinning it out of its hole. In fact, i did the opposite, and left the head outside in the winter cold before torquing out the spark plug.
Van Gogh...
D. Irwin...
Times are GMT -7.   It's 03:13 AM.
