Old 01-19-2013, 04:54 AM   #1
Captdan OP
Oddometer: 189
Installing swing arm on r1200 GSA
I seem to recall a thread on swing arm instaltion, but I've searched and have not located the exact info I'm looking for. After a nasty drive shaft explosion last Oct I'm nearly ready to bolt the beast back together. It seems there was someone that modified the socket needed to torque the left side bolt in such a fashion that also allows the installer to use an Allen wrench at the same time. The idea was to keep the Allen torque stable as you torqued the nut. Does anyone have any info on the modification of the socket needed for the job? Also, what are the torque specs for the left side swingarm bolt and Allen?
1965 Cushman super silver eagle, 1968 BMW R-60/2, 1974 R-90/6 cafe, 2008 R-1200 GSA.
Captdan is online now   Reply With Quote
Old 01-19-2013, 05:51 AM   #2
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,068
I think this is it...about halfway down the page in the Hall of wisdom..
http://advwisdom.hogranch.com/Wisdom...er%20tool.html
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 01-19-2013, 06:14 AM   #3
Captdan OP
Oddometer: 189
Excellent! That's it. Thanks
Old 01-19-2013, 08:41 AM   #4
kimokk
kimokk's Avatar
Oddometer: 103
I don't think this tool applies to the '08 model though.
'09 BMW R1200GSA Adventure! (gone)
IBA #49426
kimokk is offline   Reply With Quote
Old 01-19-2013, 12:08 PM   #5
Captdan OP
Oddometer: 189
Good point... Any reason why? Is it not a concern when torquing the bolt and Allen ?
Old 01-19-2013, 01:01 PM   #6
DaveyMac
AARP Trail Rider
DaveyMac's Avatar
Oddometer: 174
Because there is no allen pivot bolt & lock nut on 1200, that applies to R1100 & R1150's.
08 R1200GS
05 KTM 525exc
GS 911 pro
DaveyMac is offline   Reply With Quote
Old 01-19-2013, 02:21 PM   #7
FlyingFinn
Oddometer: 1,121
Items 7 and 8, parts fiche for 08-09 R1200GSA.
They call it a "pivot pin" but I'd say it qualifies as pivot bolt.
And to the OP, I used an alternate method on installing the left side pivot pin that didn't require any special tools.
I applied medium Loctite on the pin and turned it to the specified torque (7Nm?).
Next let the Loctite cure, marked the pin and the frame with white dots to verify if the pin moves.
Then torqued the lock nut to its specified torque (lotofNm) using a normal unmodified socket.
At the end check the marks on the pin to make sure it didn't turn with the nut. It didn't.
Mikko
"It is not when or how you die but how and if you truly were ever alive!" Dr. Jerri Nielsen FitzGerald
FlyingFinn screwed with this post 01-19-2013 at 05:01 PM
FlyingFinn is offline   Reply With Quote
Old 01-20-2013, 09:33 AM   #8
Captdan OP
Oddometer: 189
Great idea
Mikko
Perfect! Great idea and method. I liked the idea of a custom socket to tighten the bolt and not at the same time tighten the Allen bolt. Your option seems like a good common sense method. Thanks,
Old 01-20-2013, 02:13 PM   #9
mwood7800
Oddometer: 611
I told you to make a socket?
mwood7800 is offline   Reply With Quote
Old 01-25-2013, 07:52 PM   #10
Captdan OP
Oddometer: 189
Mikko
I'm curious what med lock tight is. I have used blue and red before.... What would you recommend?
Old 01-25-2013, 08:10 PM   #11
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,360
Captdan,
Did you get the shaft back from Greenbay? If so, how does it look? What did they do?
def is offline   Reply With Quote
Old 01-25-2013, 08:14 PM   #12
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,388
Medium is often referred to as Blue Loctite.
Jim
Old 01-28-2013, 09:24 AM   #13
Captdan OP
Oddometer: 189
Jim
Thanks, didn't know that.
And yes, I got Greenbay to replace the ujoints. Mine exploded so I bought a used one on eBay and sent it to MSI. The drive shaft looks new and a very fast turn around time! Mitch knows his business. Now if I can just get it back together and not have another explosion I'll be happy
Old 01-28-2013, 08:12 PM   #14
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,531
Is this the tool? Saw this on Ebay Swinging Arm Bearing Tool BMW R1200GS GT CT About $23 with shipping from GB.
HoW tool
scooteraug02 is offline   Reply With Quote
Old 01-29-2013, 04:50 AM   #15
Dan Căta
Dan Căta's Avatar
Oddometer: 1,676
This is good info. I have to change the rubber seal, # 11 in the pic above, on a friend's r1200gsa.
Whenever I have to do such a job, I tighten the adjustable pin to whatever is needed (8Nm in case you use bearings, handfeel for bushings ), then mark the pin using a black marker and then tighten the locknut to the needed torque. Then I check the pin for movement. It never moves, the mark is in the same position, every time :)
Dan.
Dan Căta is offline   Reply With Quote
Times are GMT -7.   It's 01:28 PM.
