Old 01-29-2013, 05:41 AM   #16
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,900
Originally Posted by Dan Căta View Post
This is good info. I have to change the rubber seal, # 11 in the pic above, on a friend's r1200gsa.
Is it necessary to pull the Paralever at the pivot point to change the front accordion boot? Maybe by just sliding the driveshaft u-joint splined adapter rearward off of the gearbox output shaft (which you'll have to do anyhow) you'll have enough room to remove the old boot and slip the new one into place.
Current: 2014 R1200GSW & 2007 DR650
jdub is online now   Reply With Quote
Old 01-29-2013, 06:06 AM   #17
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,217
would love to hear an answer to this.. I should replace my boot as well.. the one farthest back #11, I have been avoiding it because I am unsure of the tear down necessary to do it... so I just ignore it.. seems like a good plan
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 01-29-2013, 06:56 AM   #18
Tiz
Tiz's Avatar
Oddometer: 628
I couldn't replace the #11 boot on my 2005 with the swingarm on place, shock and driveshaft removed. Had to remove the swingarm. JVB was trying to help me with suggestions but I couldn't get anything to work without removing the swingarm.
--Kevin
FJR1300-2008
ex-2005R1200GS
ex-DL650K5
ex-2001 XR400
ex-2002KLR650
Tiz is offline   Reply With Quote
Old 01-29-2013, 01:20 PM   #19
Disco Dean
Disco Dean's Avatar
Oddometer: 1,283
I have an 06 Adv.
I have replaced the booth without removing the swing arm.
It is tight and a pain and your fingers will hurt. Hint you can use standard zip ties (the BMW versions are narrower to fit in the grooves) but you have to gently file down the two sides of the locking portion.
You do have to slide the drive shaft back though - which means dropping the FD down.
But much more simple than pulling the swing arm.
Dean
youmoveyou
As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?
Disco Dean is offline   Reply With Quote
Old 01-29-2013, 03:50 PM   #20
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,555
Originally Posted by Disco Dean View Post
I have an 06 Adv.
Dean
Dean, do you have the 1150, or 1200?
Jim
JimVonBaden is online now   Reply With Quote
Old 01-29-2013, 07:08 PM   #21
Captdan OP
Oddometer: 206
I need to verify the torque specs for the swing arm job, I was told 40 nm for the Allen bolt, and 65 nm for the socket ( left side). Are there specs on the right three bolts that hold in the pin ( right side )? I'm installing all the replacement parts tomorrow.
1965 Cushman super silver eagle, 1968 BMW R-60/2, 1974 R-90/6 cafe, 2008 R-1200 GSA.
Captdan is offline   Reply With Quote
Old 01-30-2013, 05:13 AM   #22
Disco Dean
Disco Dean's Avatar
Oddometer: 1,283
Jim
1200 Jim. Did I miss something?
youmoveyou
Old 01-30-2013, 05:48 AM   #23
JimVonBaden
"Cool" Aid!
Oddometer: 54,555
Yeah, maybe. on the 1200 the part that usually won't fit doesn't have any kind of straps, it fits inside the swingarm and has a retaining clip on it, unlike the 1100/1150.
Jim
Old 01-30-2013, 11:36 AM   #24
Disco Dean
Disco Dean's Avatar
Oddometer: 1,283
I thought he was talking about the boot between the swing arm and the tranny???
Dean
youmoveyou
Old 01-30-2013, 04:16 PM   #25
JimVonBaden
"Cool" Aid!
Oddometer: 54,555
Dean
I am.
That front part is not the issue. It is getting the rear part to line up and stay in place that people have trouble with.
Jim
Old 01-30-2013, 04:23 PM   #26
Disco Dean
Disco Dean's Avatar
Oddometer: 1,283
I am.
Jim
So we are on the same page - yes - many bruised and cut fingers and much swearing to get that baby in but figured it out without removing the swing arm.... that one in your picture is pretty fracked up - it is a strangely tough and somewhat brittle rubber piece for there I think.
youmoveyou
Old 01-30-2013, 06:47 PM   #27
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,620
Mine is way worse than pictured..but really, other than cosmetics, it doesn't do much..water just runs out the bottom..
I'll fix...someday..just not worth the hassle to mess with now.
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 02-04-2013, 01:55 PM   #28
Captdan OP
Oddometer: 206
Update
Well, I got my newly refurbished drive shaft and new ( used via eBay) swing arm installed last week. Really, I was read for a real job but in the end it all worked out well. FYI, I did not have a need to buy or make a special socket, or use lock tight to install the pivot and nut on the left side swing arm. I simply torqued the pivot pin, marked it, and installed then torqued the nut. The Allen pivot pin never moved. Installing the drive shaft was easy, and stabbing the final drive back into place was a snap as well. Did a road test of around 100 miles yesterday and all seems ok. Thanks to all for the info and suggestions...
Times are GMT -7.   It's 07:06 AM.
