Old 01-23-2013, 03:41 PM   #31
Katoom72
Katoom72's Avatar
Oddometer: 912
Originally Posted by TcRulz View Post
Hi, Check the six rotor bolts for loctite and that they are tight. My 03 950A bolts came out at 73000km, no loctite (should be green 648) and was told TSB done.....killed my rotor and stator and left me stranded.
The complete oil pressure regulator is cheap (Part no 60038010133) and you can bet if the piston is scored the bore will be too.
Check the top bearing in the left cover (supports the starter). These are only lubricated by an oil mist and I've had several that felt notchy.
Clutch bolts will be checked when you do the oil regulator. Have you replaced the clutch push rod with the one piece one. Replacing the balance shaft seaI should fix the oil retention issue. l think the rest you have covered.
That's a b*tch...
Katoom72 is offline   Reply With Quote
Old 02-02-2013, 04:10 AM   #32
35xj OP
Oddometer: 936
well, an update....
replaced:
water pump. Original looked fine. no leak, minimal wear
oil pressure valve spring and plunger. spring was a touch shorter than new one, otherwise looked fine
fuel pump facet.
fuel filter
fuel hoses
H2W jett kit. with prefilter etc
everything inside the motor loooked great. no strange signs of wear, no bits laying around
cleaned the carbs really well, no real dirt etc inside. jets did not appear clogged. installed the new jetts. balanced carbs(they were way off!)
set valves on the loose side of the allowable specs, tripple checked everything for vaccum leaks, re torqued everything.
Stator bolts had no visible signs of loctite, now they have the magic 648 installed!
Fired it up yesterday afternoon, and it ran like a top!
so, while its pretty frustrating not knowing exactly what the cause was, ive chosen not to worry too much about it, and go ride the damn thing!( i think it was all fuel pump)
thanks guys! on the upside, i feel really confident about the condition of the bike after all this! Gonna keep this one for a while!
35xj is offline   Reply With Quote
Old 02-02-2013, 04:58 AM   #33
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
I'd say if your stator bolts didn't have LocTite on them that it was worth the failed trip just so you could catch it. Better to break down in a garage than have your stator explode in the middle of nowhere.
Glad it's running well now.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Times are GMT -7.   It's 01:14 PM.
