Old 01-19-2013, 03:56 PM   #1
atlthrux OP
Oddometer: 159
Good helper
It was warm out today & I had a few minutes, so I did my first solo valve adjustment. Putting everything back together, I discovered my fingers don't fit to get that one fastener on. I had to call in reinforcements.
On the right side, the ticking I'd heard was gone...for a couple of minutes. But it returned, so I'll go back in tomorrow when I have more time. I'm guessing I didn't tighten the locknut tight enough?
atlthrux is offline   Reply With Quote
Old 01-19-2013, 04:06 PM   #2
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,457
Future Airhead owner! Properly adjusted valves do tick, but also, the valve train does get louder when warm. How's your rocker end play?
Big Bamboo is offline   Reply With Quote
Old 01-19-2013, 04:29 PM   #3
Clay Spinner
Clay Spinner's Avatar
Oddometer: 640
I don't have a choice... he just grabs a wrench and starts loosening things!
Clay Spinner is offline   Reply With Quote
Old 01-19-2013, 04:54 PM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,172
When we adjust the rocker valve lash we are thinking of the space between the rocker tip and the valve tip. This is the part we set the lash of. The rocker also has up and down movement or can slide on it's shaft up and down. This should be set as close as possible to zero.
If my valves don't make any noise I think I'm overdue for an adjustment. Another vote for they should tick.
---Albert Einstein
Old 01-19-2013, 04:59 PM   #5
Beater
Dirty
Beater's Avatar
Oddometer: 3,196
Fantastic George. I had a helper ... and then she discovered the 'American Girl' doll collection.
Fred
'85 R80RT G/Sified <|> '91 R100GS Bumblebee (103K miles and climbing) <|> '73 R75/5 LWB
Airhead Zen: Ride - Repair - Ride - Maintain - Ride - Repeat
Beater is offline   Reply With Quote
Old 01-19-2013, 07:17 PM   #6
atlthrux OP
Oddometer: 159
Noob oversight. I'll check that tomorrow.
Both sides tick, but the right is definitely louder, a more 'metallic' sound.
Originally Posted by Big Bamboo View Post
...How's your rocker end play?
Old 01-19-2013, 07:24 PM   #7
atlthrux OP
Oddometer: 159
Ok thanks -- I'll read up on that adjustment. I thought I read somewhere that you do want just enough space that you can see a tiny bit of oil move in&out of the gap.
Originally Posted by disston View Post
...The rocker also has up and down movement or can slide on it's shaft up and down. This should be set as close as possible to zero.
Old 01-19-2013, 08:41 PM   #8
brittrunyon
R 100 GS F 650 GS
brittrunyon's Avatar
Oddometer: 488
Not to hijack,,,,,,,,,but
What are you referring to "rocker end play"?
I've adjusted my valves for 10 years, so I guess it's about time I addressed the bike's "rocker end play".
Where is there instructions to do this?
Is the procedure in Clymers?
Got No Helper
1992 R 100 GS (ZED)
2007 F 650 GS
My Motorcycle Videos & More @ http://vimeo.com/user2721333
Big Bend Ride Report @ http://brittrunyon.com/
brittrunyon is offline   Reply With Quote
Old 01-19-2013, 10:19 PM   #9
Big Bamboo
Big Bamboo's Avatar
Oddometer: 3,457
What year bike do you have brittrunyon ? The procedure varies depending... More info here: http://w6rec.com/duane/bmw/valve/index.htm http://largiader.com/tech/rockers/
Old 01-20-2013, 08:26 AM   #10
brittrunyon
R 100 GS F 650 GS
Oddometer: 488
Thanks for the link!
My bike's a 92 so I guess I don't have to worry about end play, from Duane's write up it's for older bikes.
1992 R 100 GS (ZED)
2007 F 650 GS
Old 01-20-2013, 09:02 AM   #11
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,898
Nice to see another generation of Airhead wrenches is being trained!
Two things to remember:
1.) Tappy valves are happy valves And
2.) Loud valves save lives.
Like disston, I go in and check the clearances when I don't hear as much tickety-tick.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 01-21-2013, 08:35 PM   #12
atlthrux OP
Oddometer: 159
Wait, huh? I don't see that's what he's saying. From Anton's description, on '85 and later, "..rocker endplay is set with shims...". That says (to me) you can have end play on your '92.
Old 01-21-2013, 08:55 PM   #13
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,463
On all airheads you want zero endplay on the rockers, but not tight enough that they bind. pre '85 you just pinched the rocker blocks together as you tighten the cylinder stud nuts. Post '85 you have to eliminate end play by using the proper shims, but pinching the rocker blocks can help if they happen to be a loose fit in the head.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-21-2013, 10:29 PM   #14
Big Bamboo
Big Bamboo's Avatar
Oddometer: 3,457
I have worked on a 1990 R100 that had a shim fail and chew up the black bushing, resulting in lots of play! It's worth a check.
Old 01-22-2013, 05:41 AM   #15
brittrunyon
R 100 GS F 650 GS
Oddometer: 488
Thanks for straightening me out on "end play".............
But back on track about "Good helper"..........
I once had a cat clean out all the mice from a tank bag that had sat on a shelf all winter, sorry no photo.........
1992 R 100 GS (ZED)
2007 F 650 GS
Times are GMT -7.   It's 06:01 AM.
