Old 01-20-2013, 02:58 AM   #1
greendy OP
greendy's Avatar
Oddometer: 22
Side stand for 2003 GSA
Does any one know if a side stand for a 2001 GS is compatible with a 2003 GSA. I buggered my side stand up in a minor gravity induced issue in Alaska last summer!! You don't know how badly you need a side stand until you don't have one.... especially fully loaded!!!!
Your not lost until you're out of gas and money!!
greendy is offline   Reply With Quote
Old 01-20-2013, 05:16 PM   #2
bemiiten
SWM Adventuer
bemiiten's Avatar
Oddometer: 4,149
Not sure about the 1150, but you can't do it on a 1200. The longer GSA side stand hits the centerstand.
bemiiten is offline   Reply With Quote
Old 01-20-2013, 06:16 PM   #3
Karlxx
Dirt Curious
Karlxx's Avatar
Oddometer: 118
I think the side stands are the same, my 1150GSA sure does lean a long way (to far IMHO), I figured it was because the stand was not lengthened when the suspension travel was.
K
2004 R1150GSA
2003 CBR1100XX
IBA 41759
Karlxx is offline   Reply With Quote
Old 01-20-2013, 07:25 PM   #4
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 7,009
The part number for the side stand on a 2003 GSA is 46537665503. The part number for a side stand on a 2001 GS is 46532335787 according to Real OEM. So the part numbers are not the same. It may work but may not.
Marc
04 R1150RT,06 KTM 450EXC, 84 R100RS LE, 89 XL600V, 2012 Stelvio, 72 Guzzi Eldorado
http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3
Lomax is offline   Reply With Quote
Old 01-21-2013, 11:24 AM   #5
jsb223
ADV Rookie
jsb223's Avatar
Oddometer: 1,004
Might have to do the hockey puck mod but would most likely work.
R1150GSA
DRZ400S
DRZ400E
jsb223 is offline   Reply With Quote
Old 01-21-2013, 11:40 AM   #6
Chev.
Final Drive ?!
Chev.'s Avatar
Oddometer: 127
The GSA side stand is longer.
Chev.
2003 1150GS
Dual spark - No servo - 33/11 FD - Adventure Öhlins - Y-piece & Remus can
Modifications on my 2003
Chev. is offline   Reply With Quote
Old 01-21-2013, 11:52 PM   #7
greendy OP
greendy's Avatar
Oddometer: 22
It looks like i bent the mounting bracket and not the actual side stand, I'm hoping the bracket will work, perhaps alittle persuasion may be needed!!!
Old 01-22-2013, 12:32 AM   #8
chromemonkey
Oddometer: 37
i just swapped a GSA 03 model side stand to my gs 02 model and it works really well , the GSA stand is a couple of inches longer ,it does just touch the center stand only by a couple of mm , and it stands the bike up at a good angle
chromemonkey is online now   Reply With Quote
Old 01-22-2013, 02:52 AM   #9
greendy OP
greendy's Avatar
Oddometer: 22
im doing the exact opposite, i may have to fab something up to make sure the bracket fits .... im hoping that it just bolts up
Times are GMT -7.   It's 10:12 PM.
