Old 01-20-2013, 07:14 AM   #1
Orangecicle OP
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,281
Crankcase vent to airbox drain???
Maybe this is a stupid idea. I wanted to bounce it off the forum before I do it. I want to remove the crankcase vent from the top of the air box (for numerous reasons). After considering all options, I'm thinking that a simple solution would be to just reroute the vent tube back to the airbox drain tube with a T to join the two. Any thoughts before I start hacking. Oh wait, it's 10 degrees in my garage. I think I have awhile before I start cutting.
Orangecicle is offline   Reply With Quote
Old 01-20-2013, 07:18 AM   #2
Vicks
gets stuck in sand
Vicks's Avatar
Oddometer: 3,204
The aix box vent is on the "dirty side" and you will have a bunch of crap accumulating in your crank-case soon after.
Don't do it.
Instead, find a cheap inline fuel filter for cars/automobiles and shove it into the crank case vent pipe after removing it from the air box cover. Seal the fitting on the air box cover properly.
and oh, everyone. was away for the last two weeks. Had a Dakar to run
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally and 2012 KTM Adv990
530Exc Adventurization re-build
Vicks is offline   Reply With Quote
Old 01-20-2013, 09:11 AM   #3
Dogtown
Dogtown's Avatar
Oddometer: 410
airbox vent tubes
Ive got (maybe) a related question/comment.
My 07 990 is making some weird throaty air box noises intermittintly....Totaly weird!? I kept the bike running and as far as I can see the 1/2 inch drain tube came out of the bottom of the air box and thats the cause....I think?? Its routed down the side of the bike to drain anything out that might get in I guess. Have not re connected yet but why is the sound intermittent??
Oh! i have ectomy'd all the SAS and such
OH 7 990
Marin County To Cabo!
Dogtown is offline   Reply With Quote
Old 01-23-2013, 04:02 AM   #4
Vicks
gets stuck in sand
Vicks's Avatar
Oddometer: 3,204
I'd say you are having an intermittent air leak in your air box. Alongwith the weird throaty noises, do you also have un-steady idle and running issues ?
The drain tube should be attached to the air box, but disconnecting will not cause any noises/issues. Why not re-connect it and see if it changes anything (ideally, it should not) ?
Times are GMT -7.   It's 01:00 AM.
