Old 04-23-2014, 01:10 PM   #1
Beer OP
950 SE
Beer's Avatar
Oddometer: 358
choke cable stuck SE
as above....went to go for a blast on the mighty SE early evening and the choke cable seems to be stuck.....guess its a tank and air box etc off tomorrow - unless anyone has some bright ideas.....
cheers....
Size matters.....
http://950superenduro.com
Beer is offline   Reply With Quote
Old 04-23-2014, 01:44 PM   #2
buzybraza
buzybraza's Avatar
Oddometer: 379
cable luber
Fist check that the problem is not at the lever.
If it is really the cable, the only option is to lube with something like:
http://www.motionpro.com/motorcycle/partno/08-0182/
If it doesn't move, then yes, you will have to get tank and airbox out of the way to get to work!
buzybraza screwed with this post 04-23-2014 at 04:12 PM
buzybraza is offline   Reply With Quote
Old 04-24-2014, 12:36 PM   #3
Beer OP
950 SE
Beer's Avatar
Oddometer: 358
thanks Buzy.....worked from the lever backwards...now have had to take the carbs completely out....they come out easy don't they
..rear cyclinder choke pin stuck like a gooden.....job for next week now as away this weekend...
Size matters.....
Old 04-26-2014, 10:53 AM   #4
buzybraza
buzybraza's Avatar
Oddometer: 379
Yes, that airbox is so easy to work with I got rid of it!!!
Old 04-26-2014, 06:45 PM   #5
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,591
If you have sprayed brake cleaner anywhere near your clutch master cylinder it may have run down the choke cables and ......
Fused the little steel cylindrical piece inside the plastic tube that joins both cables together just up from the carbies.
Don't ask me how I know this.
The little metal bit is suppose to slide inside the tube.
Hodgo Spot
My North America Trip
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E & lots more
Hodgo is offline   Reply With Quote
Old 04-29-2014, 02:43 AM   #6
Beer OP
950 SE
Beer's Avatar
Oddometer: 358
power of the forum help please...
got the choke loose it was the rear pin that had jammed inside the carb
now putting it all back together and just about to refit the tank and have this loose connector??
looks like it's supposed to connected to something but can't see what.....its coming out of the right had side as you sit on the bike - but may have been originally on the left before i took the carbs out...
Size matters.....
Old 04-29-2014, 03:10 AM   #7
johnno950
Oddometer: 1,076
I got a connecter same as that 2 wire red/yellow,doesnt connect to anything on my bike,yours doesnt look like its been connected to anything for a while either from the dust etc on it.
johnno950 is offline   Reply With Quote
Old 04-29-2014, 03:24 AM   #8
Modder
Modder's Avatar
Oddometer: 17
Was the SAS system removed?
Then there should be an identical connector dangling near the rear cilinder head.
I shrink bikes
Modder is online now   Reply With Quote
Old 04-29-2014, 03:54 AM   #9
Beer OP
950 SE
Beer's Avatar
Oddometer: 358
yes it has been removed - that's it then - was connected to all that emmisions garbage
cheers lads - get yourself a virtual pint - bars open....
Size matters.....
Old 04-29-2014, 12:02 PM   #10
Tom_C
pinned underneath
Oddometer: 122
Have that same connector, and I still had all the SAS stuff on it, and it was not connected to anything. You can even see the connector not connected to anything on "Gary's" SAS removal on the Hall Of Wisdom.
I wonder if it was for the Euro models that had that additional emissions stuff on it??
Its funny, I was redoing some accessory wiring on the bike yesterday and decided I needed to ask the question about the connector.
07 KTM 950 Super Enduro R pilot -lunatic fringe 1%er of the gravel travel ADV crowd.
Tom_C is offline   Reply With Quote
Old 04-29-2014, 12:41 PM   #11
Modder
Modder's Avatar
Oddometer: 17
Sorry I mixed things up.
It's from the EPC, the thing that limits the power in lower gears.
You can just disconnect it or remove it completely and plug the holes.
I shrink bikes
Times are GMT -7.   It's 05:35 AM.
