Go Back   ADVrider > Riding > Regional forums > Canada
Old 01-20-2013, 09:02 PM   #1
Mr. Canoehead OP
Eat Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,093
Any Calgary Area Machinists?
I need a couple of adapters/spacers machined up for my fork swap project. Is there anyone who is an amateur machinist with a lathe in their garage who can help me out? Alternately can anyone recommend a small machine shop that would do the work?
I used to deal with a small machine shop in the ATCO industrial park but it is gone now.
2005 GS1150 Adventure - Range Rover, 2002 DR650 SE - Land Rover
"Not all who wander are lost" - JRR Tolkien
Mr. Canoehead is offline   Reply With Quote
Old 01-20-2013, 09:38 PM   #2
dieselpete
dieselpete's Avatar
Oddometer: 68
I always use Humphrys on Blackfoot Trail. Used them for years, always done right.
dieselpete is offline   Reply With Quote
Old 01-21-2013, 07:40 AM   #3
MCMXCIVRS
Begining the Adventure
MCMXCIVRS's Avatar
Oddometer: 997
What sort of adapter exactly? I have a lathe and milling machine and might be able to help you out as long as it's not too complicated. I'm still pretty much a novice at running them.
Ed
2009 BMW F800GS, 2008 BMW K1200GT
MCMXCIVRS is offline   Reply With Quote
Old 01-21-2013, 07:59 AM   #4
Mr. Canoehead OP
Eat Gunnels!
Oddometer: 1,093
I need an aluminum circular spacer with 29mm ID, 41mm OD and 13mm height. I found an old bearing inner ring that is working temporarily:
I also have a new brake caliper mount that I installed to take a larger disk and the disk isn't as centered in the caliper as I would like and I am thinking of getting 1 - 2mm milled off to center it better:
If it is something that you could manage, it would be worth lunch or beer to me!
Old 01-21-2013, 11:35 AM   #5
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 997
If you can source the aluminum for the space it should be pretty straight forward to make. I have a bit of smaller aluminum on hand, but currently nothing of that diameter.
As to milling the brake mount, that too is likely doable as long as I can get it mounted up in the mill
Ed
Old 01-22-2013, 07:55 AM   #6
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 997
I had a look in my metal bin yesterday, and I do have a small chunk of round 6061 aluminum that would be suitable for your spacer if you're still in need.
Ed
Old 01-22-2013, 08:17 AM   #7
Mr. Canoehead OP
Eat Gunnels!
Oddometer: 1,093
Yes, thanks. I was looking at Online metals last night and I can buy a foot of T3 2011 in the right size but shipping was going to be silly, so I was going to call around town today. If you have something, that would be fantastic.
I'll send you a PM.
Old 01-22-2013, 04:36 PM   #8
dieselpete
dieselpete's Avatar
Oddometer: 68
For small pieces, check the Metal Supermarket. 3716 56th ave S.E. 403-720-2267.
Old 01-22-2013, 05:41 PM   #9
Mr. Canoehead OP
Eat Gunnels!
Oddometer: 1,093
Thanks, I'll check them out.
Times are GMT -7.   It's 05:38 AM.
