Old 01-21-2013, 09:45 AM   #1
1reddawg OP
1reddawg's Avatar
Oddometer: 2,292
Is this the Hall Sensor?
Is The Hall Sensor "A" & "B" in this diagram.I am trying to get a Part # to replace mine. If you could PLEASE give me a part #. if this is not it.
Reddawg
Current ride
2012 BMW Triple Black GSA
1reddawg is offline   Reply With Quote
Old 01-21-2013, 09:52 AM   #2
Riteris
Dessert Runner
Location: A place many ADV Riders fear: The Nation's Capital
Oddometer: 2,935
You got it right. (Assuming you are wanting it for a 2004 1150.)
I double checked on the Max BMW webpage. I do not know why there is no #1
02 12 11 7 673 277 IGNITION SENSOR 0.35 1 $312.86
Chris
I am taking the advice of all those people that told me, "Hey kid, why don't you go play in traffic!"
Riteris is offline   Reply With Quote
Old 01-21-2013, 09:59 AM   #3
Jim Moore
Jim Moore's Avatar
Oddometer: 13,948
The part is part 1 or part 2. The A and B refer to the plug, which is different for the 1100 and 1150 models. EuromotoElectric also sells them for cheaper.
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 01-21-2013, 09:59 AM   #4
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 464
You may look at Beemer Bone Yard for a good price on a suitable Bosch replacement part. If you are ordering from a BMW dealer, prices may be a lot higher.
Cheers!
ElMartillo is offline   Reply With Quote
Old 01-21-2013, 10:09 AM   #5
1reddawg OP
1reddawg's Avatar
Oddometer: 2,292
Thank You Fellas.I will look into Beemer Bone yard and Euromotoeletric to find a less expensive replacement
Current ride
Old 01-21-2013, 10:57 AM   #6
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,405
In an engine that uses electronics to provide fuel and ignition information, the control unit (Motronic or other) must know the position of the crankshaft in order to deliver fuel and spark at the proper time. The HES assembly provides this engine position information....sorta like the ignition points we used to change on older engines.
Before I spent a lot of money on a replacement HES assembly, I would ascertain that the actual HES devices are electrically inoperable.
It is somewhat rare that the actual HES device(s) fail. Most often, the wiring is at fault causing intermittent shorts or an open circuit. Either will leave your boxer dead.
Checking the HES assembly for proper operation is not challenging...it just takes some patience and could save $100s.
def is offline   Reply With Quote
Old 01-21-2013, 11:04 AM   #7
def
def's Avatar
Oddometer: 10,405
BTW, there have been some recent threads dealing with the HES installation and associated problems achieving correct engine/HES timing.
Your model likely requires that the HES rotor be glued to the alternator pulley and that the HES rotor is installed in the correct orientation to provide the correct "crankshaft" timing information.
I am quoting from my 2001 GS BMW REProm. I would refer to the factory information for your model in this regard.
Old 01-22-2013, 09:07 AM   #8
Uncledeadly
Oddometer: 169
+1 on the diagnose prior to ordering the new part!
I had a bad sensor a while back and found that the original wiring was very brittle and the sheathing would just flake off when bent. The "lead" wiring from the pickup is good (if I remember... high temp silicone?) but then it's spliced with some lower grade wire from there up to the plug. This is where the trouble occurs.
I ended up replacing the pickups for around 20 bucks each, mounted them on the existing plate and got good , high temp wire from an avionics shop at the local airport for 10 bucks .....works GREAT!
'97 R1100GS
'71 Norton Commando
Uncledeadly is offline   Reply With Quote
Old 01-22-2013, 09:43 AM   #9
def
def's Avatar
Oddometer: 10,405
Bingo.
Old 01-22-2013, 12:05 PM   #10
mcstark
KaTooM convert
mcstark's Avatar
Oddometer: 1,148
I recently attended a tech session at Budd's BMW in Hamilton, ON. The service manager there, JP, confirmed this was the typical failure on the HES. The sensor itself is usually fine, but the wires dry rot and short out. He recommended exactly what you did: rebuild it with silicone insulated wires, and then wrap with an appropriate high-temp sheathing.
Regards,
Mark
2004 KTM 950 Adventure
Black is the new orange
mcstark is offline   Reply With Quote
Old 01-22-2013, 12:25 PM   #11
ultane
sqeezin the bag
ultane's Avatar
Oddometer: 1,214
Thanks def...
I might be wrong... Just ask my X...
If a man speaks, and there is no woman present to hear him,... Is he still wrong?
Sent from my party line rotary dial iPhone using Tapatalk
I might be wrong, just ask my X...
Is he still wrong?
ultane is offline   Reply With Quote
Old 02-24-2013, 09:57 PM   #12
MsLizVt
pfft ...
MsLizVt's Avatar
Oddometer: 1,619
1reddawg, hi!
Hope you don't mind me reviving this thread, but just curious how you made out?
Liz
MsLizVt is offline   Reply With Quote
Old 02-24-2013, 10:17 PM   #13
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,118
Not only cheaper but has the updated wire which has a higher temperature rating
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Times are GMT -7.   It's 01:36 PM.
