Old 06-17-2013, 08:07 PM   #301
jasonmt
Oddometer: 541
Originally Posted by Gryphon12 View Post
I really like the flexibility of changing front (countershaft) sprockets to easily change gear ratios, depending on where I'm going on any particular trip. The lack of this easy flexibility on this bike is really troubling. A very small thing, I know, but it has major ramifications for me.
The co-axial CS / swing arm pivot was an Enduro race concept in the original BMW engine / frame design. I my opinion, it hurts this bike's intended performance envelope, rather than helping it.
Without a factory installed, wide-ratio, 6-speed transmission, this bike is not looking like it will meet my expectations. I'm willing to wait and see, since I can't afford a new bike at the moment, but I will never buy a new bike with the need to split the cases for an essential upgrade (5-sp to 6-sp).
To CCM: If you please, we need the Primary gear ratios as well as the internal ratios for each gear to properly evaluate gearing. TIA.
If the CCM frame uses the Husky style split pins for the swingarm it is a under 10 minute job to change the CS sprocket. If CCM are really thinking they will have a longer than required rear brake line and then you would not have to remove the rear wheel to change the CS Sprocket.
Seeing as how CCM has already said they were homologating the bike with the existing 5 speed gear set the primary and internal gear ratios have already been posted multiple times in this thread.
I personally have no huge issues with the bike coming with the BMW gear set as the bike is not handicapped with meagre power output like a CRF 230F (3.78 gear spread and it suffers from it, the little bastard has one) or a 600cc+ displacement and the corresponding lower peak power RPM and rev limit. Change the gearing to 14-44 and if you are planning on having to spend a long time cruising at 105km/h+ then take 10-15 minutes and put a 15 tooth CS sprocket on. It will cruise along at 105km/h at 5500RPM (which is ~1/2 of the rev limiter RPM) and it is not a KLR where nothing much really happens after 5500-6000RPM.
Not saying a little bit wider gearbox would not be appreciated but to me it is not a show stopper.
jasonmt is online now   Reply With Quote
Old 06-18-2013, 12:49 AM   #302
Gryphon12
Gryphon12's Avatar
Oddometer: 1,333
Sorry, but I haven't seen the primary gearing on this thread. I may have missed it, but the TE449/511 have 2.618:1 primary ratios - between the crank and the transmission input shaft. (This is approximately 76:29).
I don't have numbers for the G450-series - and I've searched the web for them on multiple occasions. They may be in the owner's or technical manuals, but I haven't seen anyone posting that information on other threads.
[Sometimes Primary and Final gearing refers to countershaft and rear wheel sprockets, respectively, but that's not the formal meaning of "primary" gears.]
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 06-18-2013, 07:11 AM   #303
minkyhead
minkyhead's Avatar
Oddometer: 352
as said the final desision on the gearbox has not been made
i actually spoke to ccm in person and options for the final gearbox spec and spread were still being considered
they specifically asked me not to say anything about it so im not going to ..as its NOT YET SET
.if it proves to be the g450x box ..it wont stop me buying if for sure .
but i sure as heck wouldnt be objecting to a overdive 5th or 6th though if it was possible ..
i think we are close to reaching a point where we can stop speculating
.and then everone can make up their mind if it fits their bill
ride reports should be coming on stream from different buyers and press riders in mid july ..that will also help people to get a real feel for the machine .. from different riders with different prospectives
i guess the crunch will come in how the real bike feels and performs on real road and trails ...
any way i have a 450 x 2009 manual if that can help until we know for sure i would expect the 2010/11 to be the same but i really dont know im afraid
.... gearing taken straight from the manual
regards steve
you must have been flying!! iwas going real fast when ipassed you
minkyhead screwed with this post 06-18-2013 at 07:40 AM
minkyhead is offline   Reply With Quote
Old 06-18-2013, 10:23 AM   #304
jasonmt
Oddometer: 541
Whoops - thought I had posted it but the BMW G450 & Husky TE/TXC/TC/SMR 449/511 all have the same primary drive ratio of 2.618:1:
PRIMARY DRIVE
Drive pinion gear . . . . . . . . . Z 32
Clutch ring gear . . . . . . . . . . . . Z 22
Transmission ratio. . . . . . . . . . . . . . . . . . . 2.618
regards steve
From post 232 it sure looks like they are planning on going with the BWM spec 5 speed transmission to homologate and get the bike into production.
I would much rather have a hydro clutch and lots of mapping options to get rid of that shown below (and run low octane fuel possibly) than a non OEM spec gear set in the transmission.
Old 06-18-2013, 02:44 PM   #305
minkyhead
minkyhead's Avatar
Oddometer: 352
Laugh
im undrstanding here that you have run a g450 this way ../??or the six speed husky ??
and found it alright ?? ..its good to hear about the sprockets .
.ive read a few threads saying its pretty easy to do once used to it ..and no big 32ml nut to worry about
your wrong about the klr though .. nothing much happens before 5500 revs as well after ..... ..she does a job though
minkyhead screwed with this post 06-18-2013 at 02:56 PM
Old 06-18-2013, 03:58 PM   #306
jasonmt
Oddometer: 541
14-44 is pretty close to 15-48 (stock BMW Gearing) but gives you the option of going up to a 15 tooth CS sprocket when needed as I do not believe a 16 tooth CS sprocket is available (or if it would fit).
My Husky 449 spends most of the time with a 13-51 combo on it (tops out at ~125km/h) but I could not see any issues with a well mapped one pulling 15-44 gears for highway work as long as third gear power wheelies were not your expectation.
Old 06-18-2013, 04:52 PM   #307
minkyhead
minkyhead's Avatar
Oddometer: 352
now thats a real cute idea ..lateral thinking ....thanks .. does the chain link count and adjusters
cover such a big spread of sprocket changes ie 14/44 13/51 or is their a limtation with the combos you can use on the original length chain .. there is a big gap between enduro and road for sure
how do you rate 14/44 for general duel sport riding ..as opposed to goat tracks and gnarly rooted tracks if you see what i mean
thanks for the heads up ... from what i can tell thre are few people that have ridden this engine in a duel sport way ..it mostly flat out reports i see ...so im very interested on what you think ..a few words on the lugabilty side of the engine would be welcome ..as its not generally what the doner bike was intended to do .. stalling and pick up a problem for instance ..clutching required ..that sort of thing ??
thanks steve
minkyhead screwed with this post 06-18-2013 at 05:14 PM
Old 06-19-2013, 11:04 AM   #308
WhiskeyTangoM3
I WANT!
Oddometer: 10
If they bring these to the US I will definitely own one. This looks great so far, very excited!
Being new to the scene I'm actually surprised there aren't more like this with a 450.
WhiskeyTangoM3 is offline   Reply With Quote
Old 06-23-2013, 03:12 PM   #309
minkyhead
minkyhead's Avatar
Oddometer: 352
first picture i have seen of theccm being ridden
abeit in a parade to be featured in the uks top gear tv programe
at least shes up and running ..looking pretty lean too ..apart from that can at the back .. which seems pretty big taken in perspective ..but looking pretty good i think ..the rider looks really small ..its comparable to a crf 250 to sit on the crf seat being 7ml closer to the ground
,,first ride for me early july on the factory open day
minkyhead screwed with this post 06-23-2013 at 03:32 PM
Old 06-23-2013, 07:19 PM   #310
Wasca
Adventurized!
Wasca's Avatar
Oddometer: 599
OH Man! I'd really love to own one of these, please bring them to OZ!
Riding a DR-Z400E
Wasca on YouTube | UPDATE! - Import GPX - Garmin Zumo350LM
Wasca is online now   Reply With Quote
Old 06-23-2013, 07:32 PM   #311
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I'm starting to think I should just pick up a TE 449/511.
IMS has a tank, and a mini fairing can be done.
Neat looking bike, but it will be a red headed bastard in the US.
johngil is offline   Reply With Quote
Old 06-23-2013, 07:40 PM   #312
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,819
That's the ticket!
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 06-23-2013, 09:42 PM   #313
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,113
Minky did you see the rider? Is he exceptionally small?
It sure looks nice and lean!
rickypanecatyl is offline   Reply With Quote
Old 06-24-2013, 12:27 AM   #314
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,787
Wasca, your misses says you can't have one, your already on your second bike in 12 months
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee screwed with this post 06-24-2013 at 01:41 AM
BygDaddee is offline   Reply With Quote
Old 06-24-2013, 01:39 AM   #315
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,199
Foot peg to seat hight looks wrong
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Times are GMT -7.   It's 06:08 PM.
