Old 01-21-2013, 12:31 PM   #1
Bishop8pi OP
Oddometer: 3
BMW R60/5 Instrument Repair
I had the chance to buy a Franken-Beemer over the winter for a pretty good price. This is my first motorcycle rebuild.
The bike is a 1972 BMW R60/5 with a 1970 R75/5 engine. Frame is straight but every pc of chrome and steel is rusted. The bike had been sitting in a garage since 1994 with a full fuel tank. Amazingly having a full tank of old non-ethanol era fuel kept the tank and internals in good condition. With the exception of oxidation the engine is in pretty clean on the inside. As for everything else im going to need new rear shocks, wheel bearings, brakes, tires, seat, and anything plastic or rubber on the bike... it's going to be a fun project.
After rebuilding the carbs twice (i missed the fact the first time around that the bowls did not match the 1970 Bing CV carbs) the bike starts up and runs. The idle is fast but I believe I can slow that down once i adjust the cables.
Right now I'm looking for someone who can rebuild a speedo and tach. I also have shorts in both handlebar switches as well as the front brake lever.
Bishop8pi is offline   Reply With Quote
Old 01-21-2013, 12:37 PM   #2
jbcaddy
Oddometer: 1,211
try wirespokes, he posts frequently here.
jbcaddy is offline   Reply With Quote
Old 01-21-2013, 12:41 PM   #3
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,541
Get new tires first, before you are tempted to take it up to speed. The high idle could just be a sticking advance unit, remove, clean, lubricate with special grease and replace. It probably needs it anyway. There are currently reproduction speedometers available for about what you'll pay for someone to "maybe" fix yours right...
Big Bamboo is offline   Reply With Quote
Old 01-21-2013, 02:00 PM   #4
backdrifter
Wannabe rider
backdrifter's Avatar
Oddometer: 1,368
This. Wirespokes restored mine to as-new condition quickly and for a very reasonable price. Highly recommended!
"We are very good at preparing to live, but not very good at living."
-Thich Nhat Hanh
1973 BMW R60/5:
http://www.advrider.com/forums/showthread.php?t=608166
backdrifter is offline   Reply With Quote
Old 01-21-2013, 02:21 PM   #5
Bishop8pi OP
Oddometer: 3
Tires and shocks are on the list to be changed before it leaves the driveway.
I'll take a look at the advance. Thanks
Old 01-21-2013, 02:25 PM   #6
Bishop8pi OP
Oddometer: 3
PM sent... thanks
Old 01-22-2013, 01:00 AM   #7
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,127
Got the PM!
As for the reproductions - I haven't seen one for the /5. The one for the R80G/S didn't impress me - more than just the absence of a trip meter.
Old 01-22-2013, 10:41 AM   #8
Big Bamboo
Big Bamboo's Avatar
Oddometer: 3,541
Originally Posted by Wirespokes View Post
Got the PM!
Uli's has them for 283 Euros, but only in kph : http://www.ulismotorradladen.de/uli/...M-counter.aspx
Big Bamboo screwed with this post 01-22-2013 at 10:51 AM
Old 01-22-2013, 11:50 AM   #9
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,358
If this bike hasn't been driven yet how do you know the instruments don't work?
No fuses on a /5 I guess, I don't know. But you can check the wiring and the cables for the speedo and the tach. Actually I guess if the rear wheel is off the ground on the center stand and if not put some blocks of wood under the stand then the spedo can be checked.
Has the idle come down yet with cleaning the advance unit?
---Albert Einstein
Old 01-22-2013, 02:14 PM   #10
JonnyCash
turd polisher
Oddometer: 1,569
^ late /5s do have a couple of fuses in the headlight bucket. I think the break was at the same time they went to the LWB, but I'm not sure. I doubt that a 72 has fuses, but it's easy to find out.Mine is a 71 and it does not have fuses. When I got mine, it was not running because the entire wiring harness was fried, because it didn't have fuses.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 01-22-2013, 03:44 PM   #11
Big Bamboo
Big Bamboo's Avatar
Oddometer: 3,541
I have a '72, no fuses.
Old 01-22-2013, 09:40 PM   #12
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
02/72 SWB R75/5 = 2 fuses in headlight
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 01-22-2013, 09:47 PM   #13
backdrifter
Wannabe rider
Oddometer: 1,368
Mine is a 1973 R60/5 and also has two fuses in the headlight. They are the two blocky/tubular things located at about 5 o'clock in this photo:
-Thich Nhat Hanh
1973 BMW R60/5:
Times are GMT -7.   It's 02:35 AM.
