Old 01-21-2013, 04:18 PM   #1
madpuma13 OP
Oddometer: 109
Altrider Crashbars Installation
Has anyone done the installation of these crashbars themselves? I am talking about their new version that doesnt have any separate brackets (other than the bracket to hold the two sides together).
I recently got them and attempted the install, where they advise you to remove a large bolt by having somone sit on the bike (or stand on its own against the wall) and have two (2) 18mm sockets on each side to remove the nut.
It was a PITA to remove by myself but it was done. After removing all the bolts and nuts that were supposed to be removed, they tell you to mount the bars to the bike. Everything till this point is fine. But then when trying to install that large bolt back into the bike, I can not do it.
The problem lies in the fact that the bars create a type of sleeve to go into the large hole that the bolt resides in to make it more sturdy. The sleeve, however, does not allow my 18mm socket to fit and so I can not tighten the bolt.
I have tried looking around for a socket that might fit but I can not find anything. Any suggestions? How did you do it? Is there something else I can do to tighten it down?
Here is a picture of the sleeve that is causing the problem. If more pictures are needed for context let me know.
tl;dr 18mm socket wont fit in the hole. What now?!
madpuma13 is offline   Reply With Quote
Old 01-21-2013, 05:25 PM   #2
lanceputnam
Hayden's Dad
lanceputnam's Avatar
Oddometer: 445
Go to napa or sears and get a " thin walled" 18 mm socket. They are specifically made for thing like this and for putting spark plugs into cylinder heads.
So others may live...
2012 BMW R1200 GS-Rallye
COBDR, AZBDR
lanceputnam is offline   Reply With Quote
Old 01-22-2013, 03:42 PM   #3
madpuma13 OP
Oddometer: 109
Laugh
Yeah wow....
One of the sockets I tried was an 18mm spark plug socket.
I figured if a plug socket couldnt get in there (since I figured it would be thinwall) what would?! Turns out it isnt thinwall. Thanks for helping me
Old 01-22-2013, 09:35 PM   #4
Ayrshire Bull
why the hell not?
Ayrshire Bull's Avatar
Oddometer: 2,617
they're a bit tricky to go on - but worth the fight ...... keep at it Puma .....
"It's not what you look at that matters, it's what you see." - HDT
Ayrshire Bull is offline   Reply With Quote
Times are GMT -7.   It's 02:38 AM.
