Old 01-22-2013, 03:07 PM   #1
Lost on Row 1 OP
Lost on Row 1's Avatar
Oddometer: 246
Rear Shock needed for a XRL650. What fits?
I am in need of a shock for my 1993 XR650L. Does anyone know which years are interchangeable? Also if you have a shock or damper rod for sale please let me know. Thanks
1993 XR650L; 14T CS, Dave's carb mod, Modified stk muffler, Airbox Mod, Battery relocation, Bar risers, Uni filter, No passenger pegs(to make it super lite), Blue powerband.
Lost on Row 1 is offline   Reply With Quote
Old 01-22-2013, 03:15 PM   #2
mcma111
mcma111's Avatar
Oddometer: 12,585
Honda doesn't sell parts for the XRL shock like they do for the XR600. I have a XR600 damper rod available. Perhaps we should talk with parts in hand to confirm if they are the same. I think they are.
The 93 and 94 XRL shocks are 1/2" shorter than all later XRL shocks. Any shock from a 91 and up XR600 will fit but again it's 1/2" longer. The XR600 shock body ID is smaller than the XRL except the later XR600 shocks that were the same as the XRL with slightly different valving.
The reason I have two damper rods is I bought them thinking I could put them on my L but both bodies were worn out.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
mcma111 screwed with this post 01-22-2013 at 03:22 PM
Old 01-22-2013, 03:59 PM   #3
Little Faus
Little Faus
Little Faus's Avatar
Oddometer: 50
I have a 2008 XR650L shock for sale with 6000 miles on it in excellent condition. It sounds like it is 1/2 in. longer than a 1994. PM me if you are interested.
Little Faus
2008 HONDA XR650L
2004 SUZUKI VSTROM 650
1979 BMW R65
Little Faus is offline   Reply With Quote
Old 01-22-2013, 04:38 PM   #4
Lost on Row 1 OP
Oddometer: 246
I don't want to end up a half inch longer on the shock, fighting the urge to lower it as it is. Not to question anyone, but are we sure that the shocks are different? I was involved with Honda on the dealership level for many years and it doesn't make sense coming from a parts point of view.
The linkage is all the same.
From what I found seat height remains the same.
If what we are saying is right then Honda raised the seat height on a bike that already had legs.?
So has someone actually checked this out? Again, no offense.
I appreciate the response so far. I will get back with you when I am settled on the shocks lengths.
Old 01-22-2013, 04:49 PM   #5
mcma111
mcma111's Avatar
Oddometer: 12,585
Easy Peasy. Go to Cheapcycleparts and check the 93/94 XRL shock part # to any later year.
Here. I've done it for you:
http://www.cheapcycleparts.com/model...shock-absorber
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-22-2013, 04:51 PM   #6
AZ TOM
Oddometer: 4,079
My 95 also had the shorter shock. I stole one off a 2007 on E-Bay $125. He said it had been used about 600 miles. When I got it , it wasn't even dusty, not a scratch. Must have been all street miles. Much better ride now.
AZ TOM is offline   Reply With Quote
Old 01-22-2013, 04:54 PM   #7
Lost on Row 1 OP
Oddometer: 246
One more thing about the shock length. The part number only has the last 3 digits changed from a 1993 to a 1996.
Typically Honda changes more than the last 3 when there is a significant change. Most of the time the last 3 will relate to a year model change involving colors or manufacturer.
I all know is the things I know, and the things I know that I don't know. What messes me up, is the things that I don't know, that I don't know.
(There's always one in the crowd)
Old 01-22-2013, 04:55 PM   #8
mcma111
mcma111's Avatar
Oddometer: 12,585
I've tried.
Next...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-22-2013, 04:57 PM   #9
Lost on Row 1 OP
Oddometer: 246
Are you saying the 95 shock is shorter? Sorry you lost me on this one.
Old 01-22-2013, 05:00 PM   #10
Lost on Row 1 OP
Oddometer: 246
Originally Posted by mcma111 View Post
I've tried.
Next...
So you have compared these 2 side by side? Any thoughts as to why the seat height hasn't changed? Seats maybe, are they thicker on the 93-94?
Old 01-22-2013, 05:02 PM   #11
Lost on Row 1 OP
Oddometer: 246
Would you mind giving me a measurement off your shock? Center to center on the bolt holes.
Thank you very much, this will answer my questions.
Old 01-22-2013, 05:14 PM   #12
Lost on Row 1 OP
Oddometer: 246
Steve,
Check out this one
http://www.ronayers.com/WhereUsed/N/9935
Just to muddy the water.
Old 01-22-2013, 05:26 PM   #13
Lost on Row 1 OP
Oddometer: 246
Springs are the same. Linkage is the same.
Why would Honda make the change? It just doesn't line up. Sorry fellow Inmates, I am not convinced.
Old 01-22-2013, 06:02 PM   #14
AZ TOM
Oddometer: 4,079
Mine was & I now have a later , longer 2007 shock. I had the two side by side & yes the 07 was longer.
Old 01-22-2013, 06:06 PM   #15
MCCOYBOY
Oddometer: 99
93-94 xr650l shock is 14.5 inches eye to eye and a 46mm shock body.
95-current 650l shock is 14.88 inches eye to eye and a 46mm shock body.
All xr600 late model shocks 1989/90 on are 15 inches eye to eye and they are ALL 44mm shock bodies.
The difference in part numbers can be as easy as a small valving change. I haven't had one of the earlier model 650l shocks apart but I'm guessing they used a top out spring which caused the shock to have a shorter eye to eye till spring preload was added.
MCCOYBOY is offline   Reply With Quote
Times are GMT -7.   It's 03:44 PM.
