01-22-2013, 03:29 PM
#1 |
Should I buy it?
Long story short... I have an acquaintance that found out that I like BMW's... he says, "You should buy my old bike". I laugh, he looks serious. "Come, let me show you" he says as he walks to the garage.
76' R100RS in pristine condition. Hasnt been riden in about 10 years... the throttle stuck while he was on it with the misses on the back. He was able to get it under control, but that was the end of his riding. So he tells me to make him an offer. Whats this thing worth? ![]()
"We cant solve our problems with the same thinking that created them"...Einstein jc9995 screwed with this post 01-22-2013 at 03:35 PM |
01-22-2013, 03:38 PM
#2 |
flyfishandride
Oddometer: 970
OOOHHH! a 77 RS! nice. BTW, 77 was fist year for the RS. not sure what the value is right now, but they ARE worth something, and if you do buy it, PLEASE don't butcher it up, plenty of other non-collectable models around for that.
01-22-2013, 03:41 PM
#3 |
Spudly Adventurer
Oddometer: 3,254
10 years non operational can be hard on engines and brake systems. Lots of unknowns to mull over. It does look like the more desired 77 model RS.
Why not offer him a couple of grand to start and see what happens. ![]() Mike
Cogswell Rides To Big Bend See my airhead project here Time Warp Vintage Motorcycle Club The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED. Cogswell screwed with this post 01-22-2013 at 03:47 PM |
01-22-2013, 04:46 PM
#4 |
Oddometer: 704
The higher power ( whichever flavor you prefer ) of the universe has smiled
upon you by causing the events that led to the owner showing his bike to you. This is how many of the very best things in life happen. You are not looking for whatever it is, and yet there it is, dropped right in your lap. You could search for months and not find a clean original bike like this one. There is a rational way to arrive at a value for this bike. Price what a superb example is worth, and then price what the best BMW mechanic you can find will charge for going through the entire bike and putting everything in order. An experienced BMW tech will be able to tell you what is likely to be wrong. You might find that tires, a battery, a carb cleaning, front brake system rebuild, and maybe a few seals are all the bike needs to run initially, and after that you can sort out the finer points. It would be wise to add a "fudge factor" of $1000 or so for the costs of problems which may appear once the bike begins to be ridden. In any case, if you want the bike don't delay because such deals sometimes can slip through your fingers and bikes like this one do not come along every day. PS - I bet there is more to the owner's story than a stuck throttle. Maybe you can get a beer or two into him and he will tell you the rest . It'sNotTheBike screwed with this post 01-22-2013 at 05:16 PM |
01-22-2013, 05:17 PM
#5 |
Lost In Place
Oddometer: 15,975
As mentioned, an original '77 R100RS is one of the more desireable airhead BMWs.
If you don't want it, let us know the co-ordinates. ![]()
01-23-2013, 07:40 AM
#6 |
So much to ponder
Oddometer: 2,551
A 1977 for sure. Has the drum rear brake. Looks to be missing the side cover but that could be that he took it off for the battery tender. They don't make them like this anymore. I would go for it.
Originally Posted by DR. Rock once you leave the pavement, it's like entering a parallel universe... a wormhole in both space and time... sometimes you won't believe you're still in the United States, or in this century. |
01-23-2013, 09:16 AM
#7 |
Oddometer: 792
The VIN can affect the value. The first few hundred had 40mm exhaust pipes.
If it wasn't for my graceful wife, my dumbass would be banned already Doug Mc Gee 01 1150 GS 84 R100RS 74 XL350 |
01-23-2013, 09:26 AM
#8 |
British
Oddometer: 740
It is a less common model - but unless you've ever ridden a BMW, don't go too mad with your offer, they ain't all that
01-23-2013, 09:46 AM
#9 |
I like the beer idea....side benefit is if I get him drunk enough maybe the price drops greatly. :)
Also great idea asking about refurb costs. I'm pretty damn handy....but would want to learn about airheads on this bike. I will update you on what he thinks is a fair offer. Thanks for the input.
"We cant solve our problems with the same thinking that created them"...Einstein |
01-23-2013, 10:12 AM
#10 |
Oddometer: 218
Get owner comfortably sloshed and save a few for yourself cause even though you are handy you'll need an average additional 2 grand or so (depending on condition) in refreshening cost. Well worth it though just for the fun you'll be having. These bikes are are very satisfying to work on.
01-23-2013, 01:28 PM
#11 |
Oddometer: 417
I've brought back bikes that have sat for 20, 10, & 5 years with very few problems. I spray fogged the cyls first, then worked on everything else before I started them. The 20 yr one was a 76 R75/6 BMW, the 10 yr was a 73 Triumph 750 Tiger, and the 5 yr was a 76 R90/6. All are running very well and I can hop on any one and go any place I want to without a second thought. I wouldn't hesitate buying that bike for the right price.
01-23-2013, 06:44 PM
#12 |
Ran when parked!
Oddometer: 373
Yes Offer 3k
Motorcycle = Mind eraser 78 R100/7 / 70 CL350 / 71 CB350 94 Duc 900ss / 63 Suzuki 80 K10 |
01-23-2013, 09:44 PM
#13 |
ShadeTreeExpert
Oddometer: 5,002
Start at 2K but go as high as 3K. If he wants more maybe more invasive investigation can help settle the question. Things in doubt are the condition of gas tank, not the paint but rust inside from sitting with gas in it. Condition of front brake master cylinder and calipers, brake fluid attracts water corrodes inside parts. Was engine fogged when it was first stored. Things of this sort can be bargaining points.
Look in the gas tank. Any amount of gas stored in this tank for 10 years is a bad sign.
Never memorize something you can look up. ---Albert Einstein |
01-24-2013, 03:44 AM
#14 |
Confirmed Curmudgeon
Oddometer: 3,881
Not a bad find. Even though it's been sitting for 10 years it's still in the upper 90-percentile of barn-finds since it looks to be stored-inside. It'll still need the usual hydraulics-tires-rubber bits TLC, but it's compete and unmolested. Be sure to check the air cleaner assy for mouse visitors, but you'll need to work down to the carbs anyway to find and correct the throttle hangup.
Nice find, indeed. --Bill
'73 R60/5 Toaster |
01-24-2013, 05:26 AM
#15 | |
BMW Airhead
Oddometer: 235
Assume the worst!!
Airhead ![]() 1974 R75/6 & 1989 R100GS |
