Old 01-22-2013, 05:01 PM   #1
bens109 OP
Oddometer: 47
RPM gauge install on G650X
I have a Trail Tech digital rev gauge to install to my XChallenge. I have a similar setup of a couple of Hondas - just wrap the wire from the gauge around the spark plug lead a few times and tape up. On the BMW however there are two coils each sitting directly on top of each plug without any lead in between
Has anyone installed a rev counter on a G650X before? Can I just wrap the wire around the sparkplug boot?
bens109 is offline   Reply With Quote
Old 02-12-2013, 08:50 AM   #2
aprilian
Can I change this?
aprilian's Avatar
Oddometer: 460
I have installed it two ways.
1) just wrap around base of rubber boot (easier on the right hand plug - feed wire from below)
2) expose copper lead and splice into brown power wire in 3 wire harness leading into the coil (either coil)
#2 seemed to be the faster response time, so I left it that way.
There is no such thing as bad weather, only inadequate clothing.
aprilian is offline   Reply With Quote
Times are GMT -7.   It's 11:45 AM.
