Old 02-19-2013, 06:11 PM   #16
Flashdog OP
Oddometer: 261
My new Leo came in today so I mounted without the Db Killer. It's got a nice bark to it but I may put the Db Killer back so as not to piss off the neighbors. I have a question about the perforated round disc that was loose in the packing box. It's stamped 58. It looks like a spark arrestor but very restrictive. Is it a spark arrestor?
Flashdog is offline   Reply With Quote
Old 02-19-2013, 07:31 PM   #17
itsatdm
itsatdm's Avatar
Oddometer: 4,825
No it is a db killer for the Euro's. Quieter than stock and a real HP killer. Fits between the mid pipe and Front of the muffler.
Old 02-19-2013, 07:39 PM   #18
ebrabaek
Oddometer: 4,712
Yeppers.... That thing is hideous.
Erling
Old 02-19-2013, 08:05 PM   #19
Flashdog OP
Oddometer: 261
Thanks, glad I left it out!
Old 02-20-2013, 03:19 PM   #20
wortho
Oddometer: 49
Does a slip on exhaust require fuel mapping change and would it affect warranty?
I was looking at these Italian made GPR exhaust but as my bike is only a few months old I don't want to have warranty or fueling issues.
http://www.ebay.com/sch/i.html?_odkw...+f800&_sacat=0
wortho is offline   Reply With Quote
Old 02-20-2013, 03:43 PM   #21
DoWorkSon
Oddometer: 267
No, it shouldnt
DoWorkSon is offline   Reply With Quote
Old 02-20-2013, 03:58 PM   #22
itsatdm
itsatdm's Avatar
Oddometer: 4,825
The F800gs Ecu will accommodate most any muffler. The oxygen sensor will indicate when the fuel ratio is stoich (14.7 A/F) and the Ecu will supply a map to maintain that in closed loop. Open loop will be richer.
If you live in the US (fill in your profile) an after market part will not void your warranty unless it is the direct cause of whatever problem you have.
Aftermarket mufflers should not cause any problems for the bike. There is a rub, because the dealer initiates the warranty process. I would suspect a lot of engine problems might fall into that gray area if he so chose. How good is your dealer?
BMW has officially approved an Akrapovic aftermarket muffler. You can tell because it cost $981. BMW probably gets a piece of the action for recommending it. It is not that special, but in some European countries they cannot add aftermarket parts willy-nilly. They can only add parts approved by the manufacture.
I have a carbon Leo Vince and like it.
itsatdm screwed with this post 02-20-2013 at 06:50 PM
Old 02-21-2013, 02:55 PM   #23
wortho
Oddometer: 49
Thanks for that info. I'll check the third party parts warranty issue with the local dealer as I suspect the rules here in Oz may be similar to Europe.
Times are GMT -7.   It's 10:29 PM.
