01-26-2013, 09:05 AM
#1 |
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,094
"Clocking" airhead drive shaft?
Just wondering if I need to reassemble the drive shaft from my R75/5 in any relative position? See when we had it in the press and were heating it up, it went BOOM! Knocked my buddy on to the floor and then I fell down laughing at him
Problem is, I guess my dumb ass must have baked the markings right off the parts... I see that there is a small hole in the largest part of the OD on the spline connection and since there is just a taper for a press fit it can line up with anything...any thoughts?
If you can't fix it with a hammer, you've got an electrical problem! |
01-26-2013, 09:55 AM
#2 |
Oddometer: 816
Correct, it can line up anywhere. Make sure you completely clean up the mating surfaces!
"No hour of life is wasted that is spent in the saddle." =Winston Churchill= |
01-26-2013, 10:11 AM
#3 |
More tacos than you
Oddometer: 5,106
...and whatever you use to clean make sure it evaporates completely. Assemble it clean and DRY.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
01-26-2013, 01:42 PM
#4 |
Oddometer: 1,094
OK guys, how about brake clean? thanks a bunch!
01-26-2013, 05:47 PM
#5 |
Stay Horizontal
Oddometer: 1,603
Then wipe it down with a white spirit which evaporates completely.
R100RS Gallery, over 800 pictures... |
01-26-2013, 05:52 PM
#6 |
ShadeTreeExpert
Oddometer: 5,011
What is a white spirit?
Never memorize something you can look up. ---Albert Einstein |
01-26-2013, 05:55 PM
#7 |
Oddometer: 1,094
MMM...moonshine!
01-26-2013, 07:12 PM
#8 |
Oddometer: 816
Acetone will work too
01-26-2013, 07:27 PM
#9 |
Oddometer: 2,369
01-27-2013, 02:27 PM
#10 |
A proud pragmatist.
Oddometer: 2,860
If you have any of them surface preparation products, to be used "before and after sanding" to remove waxes and sillycones before painting, it is also white spirits/naphta/Coleman fuel.
Yep bought some specialized Rustoleum product before I figured it out. Well figured out that I could have used my Coleman fuel would have saved me $10.00. Only had to smell the Rusto to find out.Should have done that at the store.... ![]() Someone gave me a BMW Zippo lighter....guess what's in it? Sure ain't overpriced lighter fluid aka Naphta.
Have tools, will travel!
01-29-2013, 07:35 AM
#11 |
Oddometer: 1,094
OK ready to go, clean and assembled. Should l attempt to "hold" the u-joint and torque the nut in place or bolt it to the transmission first? I think bolting it up makes more sense but I don't want to damage the tranny. Of couse I would hold the drive shaft while torquing...
01-29-2013, 10:50 AM
#12 |
Grin!
Oddometer: 4,429
Hmmm... iirc that nut takes a huge amount of torque, and I am not sure I would want to be torquing the u-joint at the other end... if you bolt up to tranny to stabilize and hold that end of the shaft, I would still immobilize the shaft somehow between the u-joint and the bell end...
01-29-2013, 11:09 AM
#13 | |
Oddometer: 816
01-29-2013, 11:19 AM
#14 |
Oddometer: 1,094
OK, thanks guys, guess it's a good thing I haven't put it in the bike then
01-29-2013, 11:22 AM
#15 | |
Grin!
Oddometer: 4,429
