Old 01-26-2013, 12:45 PM   #1
JTS1 OP
Oddometer: 54
Ktm 950
Does this allow you to adjust fuel mixture or just slide/butterfly position?
Flex Jet 2 kit
JTS1 is offline   Reply With Quote
Old 01-26-2013, 01:16 PM   #2
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 2,572
Flex Jet 2 kit
fuel mix at idle. You've already got a cable control for the idle speed (i.e., butterfly position.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 01-26-2013, 09:49 PM   #3
JTS1 OP
Oddometer: 54
mixer
Copy only the mixture at idle. Your right I do already have the idle adjuster. Are these worth the install?
Old 01-27-2013, 05:15 PM   #4
slackmeyer
slackmeyer's Avatar
Oddometer: 2,572
Since you're in florida, and not seeing much elevation change, it's kind of hard to imagine it would be. I don't have any, and I've had my carbs out numerous times to make small adjustments- but once they're set, I don't really have much need to adjust the idle mix. It's just a money vs. pain in the ass question. I'm cheap, so I deal with taking the right side tank off and popping the carbs up enough to adjust the fuel screw.
Zak
ktm
old bmw
others
Old 01-27-2013, 08:55 PM   #5
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,154
I would consider them if you spend time above or below your normal elevation. They will not solve all of the issue, however will help in the lower RPM range. If you are planning a long trip that perhaps will take you over a high mountain pass or into a area where the average elevation is 4k and higher, then they are really nice to have.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is online now   Reply With Quote
Old 01-28-2013, 03:54 AM   #6
Orangecicle
Orangecicle's Avatar
Oddometer: 1,195
Depends
I find them very useful. The KTM carbs are hard to get "perfect." The FlexJets help a great deal and give you a chance to try different idle settings without having to remove tanks to get to the the carbs to turn the idle screws. Also, I live at 850 ft. above sea level, but I try to go over to Colorado at least once a year. I found that I needed to turn the idle screws down just a quarter of a turn to get the idle just right. I also ride in temps up to 100 and down to 20. I find this bike does need minor idle mix adjustments at either extreme. Again, the KTM carbs are just very picky.
All in all, I find them very useful. But others comment are correct; if you get your carbs set and never leave the same elevation, you might not see the advantage.
"Do not follow where the path may lead. Go, instead, where there is no path and leave a trail." -- Ralph Waldo Emerson
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is offline   Reply With Quote
Old 01-31-2013, 06:28 AM   #7
JTS1 OP
Oddometer: 54
jets
Thx for the input.
I had a performance problem this summer in Colorado when I got about 3/4 way up a trail that took me to 11300ft. Almost couldn't get it started again. This of course is to be expected without a jet change from sea level but wondering if the flex adjusters would even have helped. Is that elevation going to be a high speed / low speed jet change or do the flex adjusters actually change the opening in a jet orifice? Lots of questions I know but if I could see what the end of the flex's look like that might answer my question. I guess I can answer all these questions by diving into my carbs but I haven't taken the bike apart much since I have only owned it for one summer.
Old 01-31-2013, 09:27 AM   #8
Orangecicle
Oddometer: 1,195
Thx for the input.
The FlexJets are just replacements for the IMS screws, so they adjust the gas/air mix at idle. I say "idle," but it adjusts the mix at lower RPMs. So would that help you at high altitudes getting the bike started? I would guess yes. When I go from 850 ft elevation to Golden, CO, I turn down my IMSs one quarter of a turn, and I'm good to go. That's very easy to do with the FlexJets but hours of work otherwise.
With fairly "normal" main jets in the bike, you will not need a jet change at any altitude change. See my thread on jetting of my bike: http://www.advrider.com/forums/showthread.php?t=625328 In particular, look at post #19.
Old 01-31-2013, 10:44 AM   #9
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 678
The tubes the FlexJets run through melted/disintegrated after about a year after install. Installed along with the H2W jetting and pre-filter kit.
I would suggest replacing the stock tubing with a thin-wall fuel line (the transparent kind) at the time of install to avoid having to do this later.
For me, after initial setup for my home elevation, they have been more peace of mind knowing that if I ever find myself in higher elevations I'll be able to adjust things to suit the situation.
As for utility, I've ridden from near sea level in Texas to the top of the Smokies (dirt and paved roads near the Cherahala Skyway, Dragon, BRP) and not felt any need to tweak things. I can see myself making a Colorado trip that could benefit from this adjust-ability.
13 TRIUMPH TIGER 800XC . . the new kitty in the litterbox
04
KTM 950 Adventure . . . .
Farkelization Completed - soon to be up for adoption
00 SUZUKI DRZ-400E. . . . . . DS Plated
MotoTex is offline   Reply With Quote
Times are GMT -7.   It's 03:25 PM.
