Old 01-27-2013, 10:47 AM   #1
houlster OP
houlster's Avatar
Oddometer: 109
Help with footpeg measurement
Looking for some compatible footpegs. Can someone tell me what the width of the clevis for the footpegs is on an F800GS? The inside width. Trying to figure out if I can use some aftermarket pegs made for this bike.
thx
--Dan
houlster is offline   Reply With Quote
Old 01-27-2013, 11:58 AM   #2
3Rrr
Read Ride Reflect recycle
3Rrr's Avatar
Oddometer: 170
Prescision Engineering and others
thx
--Dan
There are lots of options Pivot Pegz that rotate with your foot. Others that provide same ride height but a wider stance.
I chose Precision Engineering pegs which were almost 2"x4" for a nice large stance AND have a 2" drop. This worked well with my Rox Risers to get me where I needed to be for those longer days off road. I'm 6'2" and welcomed the drop. Hasn't been an issue for clearance. Didn't miss the rubber inserts on the hwy. Not sure if the vibration dissipated over larger surface area.
If you need the full 2" drop Precision is a great option. If not Pivot Pegz are probably the way to go. Black Dog are known to be bullet proof.
Kyle twitter.com/ducumph
3Rrr = Read, Ride and Reflect
09 BMW F800GS
11Husqvarna TE 449
3Rrr is online now   Reply With Quote
Old 01-27-2013, 01:51 PM   #3
houlster OP
houlster's Avatar
Oddometer: 109
Sorry, but my post wasn't clear. I'm looking for the clevis width for the peg mounts. I don't have a GS, just trying to figure out if the aftermarket peg options for it will work for me.
--Dan
Old 01-27-2013, 08:33 PM   #4
Flashdog
Oddometer: 368
The inside measurement of the footpeg mount clevis is .985". Just under an inch. I installed Pivot Pegs MK3's on my F700GS and they came with a spacer to make up the difference. Hope this helps.
Flashdog is offline   Reply With Quote
Old 01-28-2013, 06:08 AM   #5
houlster OP
houlster's Avatar
Oddometer: 109
Yes, thanks.
--Dan
Times are GMT -7.   It's 06:33 AM.
