Old 01-27-2013, 11:33 AM   #1
ride2little OP
MoveAlongNothingHere
ride2little's Avatar
Oddometer: 1,958
Fork Cap Removal Tip
Okay, so i swapped fork springs and put in some heavier fork oil. Everything wen as planned. that-is EXCEPT getting those darn fork caps removed. i buggered up cap #1 trying to get it loose. No luck. So I tired cap #2. Didn't bugger it up, but it wasn't coming loose either.
After a little break, I though about it , loosened up the top fork clamp (leaving the bottom tight) and they came of rather easily. Wish I'd have done that before I screwed up cap #1.
My tip of the day...
Loosen those top of the fork clamps FIRST. The caps should come off easily.
...proceed.
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
ride2little is offline   Reply With Quote
Old 01-27-2013, 02:11 PM   #2
Moto Mikey
Moto Mikey's Avatar
Oddometer: 443
...proceed.
Yup. I actually just installed my HyperPro front spring kit and replaced the fork seals this morning. Overall pretty easy to do, though I did the same silly mistake as you and had to reinstall the fork to loosen the top fork cap.
Riding the Americas in 2013-2014:
http://www.moto-mikey.com
https://www.facebook.com/Moto.Mikey84
Moto Mikey is offline   Reply With Quote
Old 01-28-2013, 06:59 AM   #3
ride2little OP
Oddometer: 1,958
No. I left my tubes in the tree's. But I didn't loosen the top clamp so that the caps would come off. Prob was the caps wouldn't unscrew. That is until I loosened the top clamps. But I left the bottom clamps tight until that caps were loose.
How are you liking the new springs/oil? I'm loving the feel.
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
Times are GMT -7.   It's 09:05 PM.
