Old 02-16-2013, 08:50 AM   #31
Britome OP
Get Free
Oddometer: 723
Did a few upgrades to the bike. The covers and the extensions. Had I had the extensions, I believe the damage would have been far less extensive. I put these on my son's bike and have ordered a pair for mine.
Britome is offline   Reply With Quote
Old 02-16-2013, 08:54 AM   #32
Britome OP
Get Free
Oddometer: 723
Noticed that my gap on the left side between the cooler and the bar isn't as much as the right side. I took the precaution of zip tying some rubber in case they touch.
This was a result of a calculated risk to not replace the front extension frame. It saved me hundreds. If you look closely at the plastics when bolted on, you could maybe notice a discrepancy in some of the gaps. However, it looks good and is functional for a bike that has a salvaged title.
Britome screwed with this post 02-18-2013 at 05:52 AM
Old 02-16-2013, 09:02 AM   #33
Unstable Rider
World Wide Inmate
Unstable Rider's Avatar
Oddometer: 2,120
Great original post brother. Glad the pilot is ok, right?
Very neat project on a great bike. The end result will be something you know more about than you might have ever cared to, but there will be more attachment and appreciation for the beast as a result, me thinks
Remember, safety first, wear protection & keep us updated.....
Unstable Rider is offline   Reply With Quote
Old 02-16-2013, 09:52 AM   #34
Britome OP
Get Free
Oddometer: 723
Thx, bro. My son was riding to work on a 25 degree morning. On a curve, he low sided. The bike skid and hit a curb which threw it upright into a tree. He was geared up except for jeans which afforded a small scrape on his left knee. He is fine.
I did this post because I was looking for such a post and couldn't find one. I hope that in the future someone faced with a similar decision can learn.
Yes..major benefits to rebuilding your own bike. Ill talk about this in a concluding post where I highlight finances, total parts list and learnings.
Old 02-16-2013, 03:04 PM   #35
Britome OP
Get Free
Oddometer: 723
I'm finally done buying parts. Here is an exhaustive list of all expenditures (new parts and used). In upcoming posts ill share finances and big learnings. I am including all of this not because I want Internet fame but because I couldn't find something like this when I needed it. I hope someone down the line profits from this project. Here is Learning #1: There are ALWAYS MORE PARTS NEEDED THAN YOU EXPECT!
Right side trim
Bmw Badge
Front fender
Spark plug cover
4- ISA screws for valve cover
Fork Stantion
Guide Bush for slider
Gasket Ring for slider
Windshield bracket left
Windshield bracket right
Handlebar grip left
Set of hand protectors and hardware
Throttle cable
Painted beak panel
2mirrors
Handlebars
Left lower crash bar
Right lower crash bar
Left valve guard
right deflector singlet
Windscreen bolt
Inner and outer gaskets
Front wheel rebuild from woody's
Front abs sensor
Adv Design crash bar extensions
Right and left switches
Clamps
Oil Cooler (in transit but may not use)
Left side Coil
Machine art Moto Head covers and mud guard
200$ Professional Tech Labor to initially assess and coach
Britome screwed with this post 02-16-2013 at 04:48 PM
Old 02-19-2013, 04:09 AM   #36
Britome OP
Get Free
Oddometer: 723
After running the bike for 100 high rpm miles I have good news and bad news. The bike has truly never run better. However there is some micro pinhole in the bottom of the oil cooler that I can't even see. I know it is there because I wrapped and zip tied paper towels around various segments of the oil system. I had seepage in the fore mentioned area.
I have a used cooler on the way. I just wish I hadn't wasted money at the welder.
Old 02-19-2013, 04:37 AM   #37
Unstable Rider
World Wide Inmate
Oddometer: 2,120
Dang!
That is good yet baad.
At least you know the end solution to the problem by the sounds of it.
That is excellent that it's running well--that would be gratifying.
Old 02-19-2013, 04:57 PM   #38
Britome OP
Get Free
Oddometer: 723
Dang!
Yes. You are right. I was a bit bummed but then realized that the biggest X Factors (bad engine damage, bike pulling because of unseen bent elements, etc.) were passed with flying colors. I should be ecstatic with the grand picture in mind.
Old 02-28-2013, 05:04 AM   #39
Britome OP
Get Free
Oddometer: 723
Finally got the new oil cooler from England. I hope to have it on tomorrow.
Old 03-01-2013, 06:52 AM   #40
Britome OP
Get Free
Oddometer: 723
The rat bastard from England sent me a cooler that has a mount bent! It obviously is off of another wrecked bike. He told me it was a rear end collision. I'm pressure testing it to see if it leaks while bitching for a refund.
Old 03-01-2013, 09:15 AM   #41
krellheat
Devil's Advocate
krellheat's Avatar
Oddometer: 1,296
did the photos shoe the bent tab? if not, he misadvertised and its against ebay rules. file a complaint.
Just remember, once you're over the hill, you begin to pick up speed.
Devil's advocate. Hell conscientious and informed and downright argumentative dissenter.
krellheat is offline   Reply With Quote
Old 03-01-2013, 11:37 AM   #42
Britome OP
Get Free
Oddometer: 723
I didn't buy it from here. Meanwhile, I ran it for 5 minutes with a fan blowing on the engine and a towel wrapped around the oil cooler.
This is what was on the backside of the towel.
I've blown it and wiped it several times. It is hard to know if this is fresh oil being blown out of a hole or if it is still residue from the fins from when it was shipped. The oil inside the cooler flowed out and filled the zip lock bag I was shipped in. What do you all think?
Old 03-01-2013, 11:38 AM   #43
Britome OP
Get Free
Oddometer: 723
Old 03-01-2013, 01:55 PM   #44
krellheat
Devil's Advocate
krellheat's Avatar
Oddometer: 1,296
i thought you bought it through ebay. ebay does not care what country but that its policies are followed. also there is ebay protection.
I would wash the exterior with a good detergent. let it dry then powder it with baking soda or flour so there is some powder residue on the cooler. run like you did before. the oil will show up on the white residue before it drips onto the paper towel. hope that helps.
krellheat screwed with this post 03-01-2013 at 02:00 PM
Old 03-01-2013, 03:08 PM   #45
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 11,254
this might be a stupid suggestion.. but
are both connectors barbed hose ends on your cooler?
( I ask because my 1995 bike has threaded fittings)
if they are barbed, Id goto your local auto parts store and buy a "stacked plate" transmission cooler that fits the hole and be done with it.
"A little inaccuracy sometimes saves a ton of explanation."
- H. H. Munro (Saki) (1870-1916)
mouthfulloflake is offline   Reply With Quote
Times are GMT -7.   It's 08:58 PM.
