Old 01-28-2013, 05:22 AM   #1
Dmaster OP
Dmaster's Avatar
Oddometer: 257
Final drive weigth reduction
I've searched the internet and this forum but couldn't find any info I'm looking for.
Did anyone ever tryed to get some weigth out of the final drive?
Does anyone know of someone doing it? Any picturs available?
What could you take away, drill/machine/whatever?
Dmaster is offline   Reply With Quote
Old 01-28-2013, 05:35 AM   #2
JonnyCash
turd polisher
Oddometer: 1,604
I've seen people put holes in the aluminum housing, but i think that's more for the look than anything else. I'd imagine that one could pare some weight from the ring gear, like you would with a flywheel. That said, when I pick up a BMW final drive, I feel like it is pretty light, for what it is. Go pick up one from a Guzzi, it's much heavier, and then you'll be happier with the weight of the BMW part!
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 01-28-2013, 11:29 AM   #3
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,760
Jim Roche aka "Dr. Curve" did some lightening of his White Dog racer. Not a huge weight savings, but it is some...
Big Bamboo is offline   Reply With Quote
Old 01-28-2013, 02:02 PM   #4
Dmaster OP
Dmaster's Avatar
Oddometer: 257
The housing (is that the right name?) isn't the heavy part its the "gears"
why not cut the red parts?:
this isn't gonna help much but why is it here anyway?
I'm sure I can get some material of the small gearing but how much will it be.
Someone must have tried this before.
I know about "lightweight gearboxes" (drilled holes in anything) why not the final drive
Old 01-29-2013, 02:42 AM   #5
chasbmw
Oddometer: 2,283
The later final drives look lighter.
Just think of what would happen if your final drive locked up......declutching won't help.....
Charles
1971 Commando Fastback
Old 01-29-2013, 04:52 AM   #6
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,602
Like chasbmw says, transmissions are risky places to lighten.
Weight savings is always about the sum of little bits (bites?), but in some places reliability and maintenance aren't good tradeoffs. I would want to talk to a rear end specialist prior to removing any metal.
There's weight to be saved in the hub, I think.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 01-29-2013, 05:34 AM   #7
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,548
The gears are heavy, but out of a total weight of 17 pounds they only account fo about 6 pounds, so theres a lot of metal just in the housing.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-29-2013, 04:41 PM   #8
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,716
Leave off every other nut, bolt or stud.
Leave out the rear brake shoes and other parts of the brakes.
Leave off every other spoke on the rear wheel.
Buy a skinny tire.
Of course you could also buy a Honda?
---Albert Einstein
disston is online now   Reply With Quote
Old 01-30-2013, 09:43 AM   #9
RonZacapa
RonZacapa's Avatar
Oddometer: 64
The sum of parts is all in the unsprung weight. When I went from a tubed tyre to tubeless and junked the heavy duty tube on the rear wheel on my 1985 R80 monolever I threw away 3.65 lbs of weight. I would rather look at weight savings elsewhere on the bike, it can be done.
R80 Monolever roadbike = 175kg dry with an empty tank (385lbs for you imperial guys) I got another 6kg to go - 169kg no fuel. However I will not be reverse engineering important mechanical bits & pieces I know not much about. If you are obsessed with weight reduction (so am I) lets start with the easy bits.
RonZacapa is offline   Reply With Quote
Old 01-30-2013, 10:16 AM   #10
Airhead Wrangler
Adios Mexico
Oddometer: 6,548
The point here though is that it's not JUST weight reduction, but suspension performance as well.
Old 01-30-2013, 01:11 PM   #11
Prutser
Prutser's Avatar
Oddometer: 1,017
I know that the suspension performance is his main purpose.
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 01-30-2013, 02:13 PM   #12
supershaft
because I can
Oddometer: 9,116
I believe the later FD's are heavier. Dr. Curve's modification is about all you can do. The gears are too hard to work with. I would leave the internal oil baffling alone. If I know Dr. Curve, that's a magnesium wheel. THAT's the solution. I wish it wasn't such a pricey solution!
Old 02-12-2013, 01:39 PM   #13
Dmaster OP
Dmaster's Avatar
Oddometer: 257
Originally Posted by supershaft View Post
I believe the later FD's are heavier.....
Later? twin shocks vs mono arms vs para levers?
Tell me more, i wanna know all
....that's a magnesium wheel. THAT's the solution. I wish it wasn't such a pricey solution!
I'm into offroad,. somehow I want spoke wheels in a offroad. Don't know why either.
Old 02-12-2013, 02:09 PM   #14
AliBaba
AliBaba's Avatar
Oddometer: 372
Gjendem's bike has a lighter final drive and gearbox (and loads more). There are some pics here but they don't show the details: http://advrider.com/forums/showthread.php?t=30044
HPN has also done the same thing, there is a crappy picture of a modified gearbox somewhere at www.hpn.de
AliBaba screwed with this post 02-12-2013 at 02:49 PM
AliBaba is offline   Reply With Quote
Old 02-12-2013, 03:03 PM   #15
jackass dave
jackass dave's Avatar
Oddometer: 96
how about the rider going on a diet ,that would lighten the overall weight !!!
jackass dave is offline   Reply With Quote
Times are GMT -7.   It's 01:41 AM.
