Old 02-12-2013, 10:39 PM   #46
Beezer
Oddometer: 5,874
the flasher also need the right load in order to flash. both lights have to be working, one is not enough. adding a resister would make the stock system worse. switching to LEDs means changing the flasher or there is no electrical gain other tha just having LEDs.
sometimes the flasher is just bad too
Beezer is offline   Reply With Quote
Old 02-13-2013, 05:51 AM   #47
fleshpiston OP
fleshpiston's Avatar
Oddometer: 612
Originally Posted by michael weiss View Post
Just put it in pork and you won't have to deal with it.
That only works on auto trans yellow Miatas :ymca
Thanks Beezer.
I'm not using LEDs or a resistor.
Right signals are wired grey/ground
Left signals wired green/ground
Dash indicator light is wired grey/green
The flasher is marked 12.8 v and my battery was down to 11.7 v so I can see why they weren't working before.
I charged the batt and tried again, this time with 12.86 v ....... still not flashing. I guess I still need more juice?
Oh, and I've tried two different flashers that worked fine before. Another odd thing is the dash indicator light only comes on with the left signals.
I have a feeling everything will work fine once the bike the bike is running..... wishful thinking? It would just be nice to know before I "permanently" install the harness.
I'm ok at spinning wrenches but I completely suck at electrics (that should be obvious by now) so I really appreciate everyone's input.
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 03-13-2013, 09:08 AM   #48
fleshpiston OP
Oddometer: 612
Well, been makin some slow progress. It starts and idles beautifully. I'm a little surprised since I just installed the KLX needle. Haven't revved it much but seems pretty crisp so far!
I finally have the dash hooked up and working.
Here it is at idle......
And at idle again but with high beam on and grips at high setting.....
Sorry about the crappy flash pics, still pretty cold here.
The goal is to have it roadworthy by April 1st ..... so far so good.
I'm still having the same problem with the turn signals though. They won't flash, just steady on. Any ideas? What am I missing?
SRX600
SRX250
SR500
KLR650
Old 03-13-2013, 09:18 AM   #49
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,266
Looks great!
You might try upgrading the turn signal flasher to an LED style flasher, even though the are not LED flashers. If the load from them is lower than stock, you may never "trip" the flasher, but an LED flasher should do just fine, assuming that's the problem. LED flashers will work with incandescent turn signals. I had one on my old XT250, even after I decided to not go to LED signals.
sandalscout is online now   Reply With Quote
Old 03-13-2013, 09:35 AM   #50
fleshpiston OP
Oddometer: 612
Originally Posted by sandalscout View Post
Looks great!
Thank you.
You mean something like this?
http://www.superbrightleds.com/morei...asher/787/842/
SRX600
SRX250
SR500
KLR650
Old 03-13-2013, 09:47 AM   #51
mdlak
Oddometer: 201
Looking great FP!!
mdlak is offline   Reply With Quote
Old 03-13-2013, 09:50 AM   #52
sandalscout
blah blah blah
Oddometer: 2,266
Thank you.
Exactly. That's the EXACT one I used on my Yamaha, but I believe the pre-08 KLR is of the round style....
This thread http://www.klr650.net/forums/showthread.php?t=94533
Says that this flasher fits the KLR250, I suspect it'll fit the 650 also. http://www.superbrightleds.com/morei...c-flasher/193/
Good luck, I'm sure you can find a flasher that'll be plug and play, or at least mostly p-n-p, I'm just not sure which one it is.
Old 03-13-2013, 09:51 AM   #53
sandalscout
blah blah blah
Oddometer: 2,266
This'll help!
http://www.advrider.com/forums/showthread.php?t=353934
Old 03-13-2013, 09:59 AM   #54
fleshpiston OP
Oddometer: 612
You're the man! Thank you, I'll order one up!
SRX600
SRX250
SR500
KLR650
Old 03-13-2013, 10:00 AM   #55
fleshpiston OP
Oddometer: 612
Originally Posted by mdlak View Post
Looking great FP!!
thanks man, and thanks again for the inspiration to start this whole project
SRX600
SRX250
SR500
KLR650
Old 03-15-2013, 09:14 AM   #56
fleshpiston OP
Oddometer: 612
Picked up an electronic flasher at the auto parts store last night and the signals now flash, best $11 I ever spent! Thanks for the tip Mr. Scout
SRX600
SRX250
SR500
KLR650
Old 03-15-2013, 01:15 PM   #57
sandalscout
blah blah blah
Oddometer: 2,266
Old 03-28-2013, 07:42 AM   #58
fleshpiston OP
Oddometer: 612
Some good news....
...and some bad.
The weather finally cleared up a bit so I was able to take the bike for a short shake down run. It fired right up and ran perfectly, idled nice and steady, pulled strong, etc.
I rode it about a 1/4 mile up the road and stopped to let it idle while I checked for leaks, everything looked good but I turned around and headed back anyway.
Got back to the driveway and again let it idle while I checked things over......then it just died and wouldn't restart.
I wheeled it back into the garage and noticed a little drip from one of the airbox drains. It's gas.
I pulled the filter and found the that the front portion of the airbox is full of gas! Full right to the bottom of the metal screen. WTF?
I pulled the spark plug and it's wet too. Now I'm guessing there is gas in the oil as well?
The only changes I made to the carb are the KLX needle so I'm thinking stuck float/float valve? The carb did sit dry for the winter.
Any thoughts? Any other things I should be looking at besides the float needle?
Oh, and the good news ...... even though it was a 1/2 ride I can already tell the suspension is incredible! Just sublime ..... can't wait to try it again.
SRX600
SRX250
SR500
KLR650
Old 03-28-2013, 07:51 AM   #59
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,614
I'm with you -- check the float . . . . . .
bad news, you have to.
good news, if that's what is wrong, easy peasy fix.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 03-28-2013, 10:55 AM   #60
fleshpiston OP
Oddometer: 612
Yeah the float valve is easy enough on it's own but looks like I'll have to pull the airbox to drain it.
I'm also concerned that gas has gotten into the cylinder/engine oil so I'll have to flush the oil a few times.
Is there an overflow vent on the carb that I'm not seeing or is it just normal to fill the airbox with gas when it does overflow?
SRX600
SRX250
SR500
KLR650
Times are GMT -7.   It's 11:03 PM.
