Old 03-28-2013, 12:08 PM   #61
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,862
Originally Posted by fleshpiston View Post
Yeah the float valve is easy enough on it's own but looks like I'll have to pull the airbox to drain it.
I'm also concerned that gas has gotten into the cylinder/engine oil so I'll have to flush the oil a few times.
Is there an overflow vent on the carb that I'm not seeing or is it just normal to fill the airbox with gas when it does overflow?
Airbox -- turkey baster/paper towels
there IS an overflow vent (and should be a small hose attached to it) and a really spooged up float bowl could clog the vent, too.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 03-29-2013, 04:54 AM   #62
fleshpiston OP
fleshpiston's Avatar
Oddometer: 612
I tried syringe and a hose, got some of it but not all.
I'm really at loss on this...... no idea what would cause it.
Everything checks out ok with the carb. No debris, no obstructions, float valve works as it should, needle depresses easily, etc.
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 03-29-2013, 09:35 AM   #63
JBradley500
Oddometer: 60
Did that dual piston caliper bolt right up to the EBC bracket that comes with the 320 rotor?
JBradley500 is offline   Reply With Quote
Old 03-30-2013, 07:10 AM   #64
fleshpiston OP
Oddometer: 612
The EBC kit was made for the Yamaha front end I'm using.
So any ideas on the flooding issue guys? I don't know what else to look for other than the float valve which looks perfect. Guess I'll just button it all up and try again.
SRX600
SRX250
SR500
KLR650
Old 03-30-2013, 07:23 AM   #65
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,657
Yes, the vent hose is the overflow and it should run down towards the bottom of the bike.This is the hose the T mod goes in.
Make sure your vent is clear, seems crazy that much fuel in airbox !!
Sometimes the needle and seat looks good but doesn't seal, replace them.
Check float, make sure it floats.
Check float level.
ST1300 - IRON BUTT # 23,716
GAS GUY is offline   Reply With Quote
Old 03-30-2013, 07:56 AM   #66
fleshpiston OP
Oddometer: 612
Check float level.
Thanks GG
The vent hose is clear of obstructions, T mod done. The float floats,... float level is unchanged and in spec, everything worked perfectly when I took it off the road last fall.
That's what is so perplexing about this whole deal.... I just wish I could find something wrong..... find the cause
I'll try my other carb if it happens again.... just wish I knew why it happened!
SRX600
SRX250
SR500
KLR650
Old 03-30-2013, 09:36 AM   #67
KustomizingKid
Oddometer: 678
What Petcock are you using?
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 03-30-2013, 10:17 AM   #68
fleshpiston OP
Oddometer: 612
Stock petcock but converted to manual ... no diaphragm.
Hows your bike coming?
SRX600
SRX250
SR500
KLR650
Old 04-01-2013, 06:25 AM   #69
bomber60015
Oddometer: 14,862
Thanks GG
I'm bettting that it WAS clogged up somewhere (bowl. vent, somewhere), and that disassembly and reassembly, checking, poking prodding has cleared whatever the difficulty was . . . . .
Like you, I am not fond of "problems" that I fixed without knowing how . . .
Old 04-01-2013, 07:17 AM   #70
Kawidad
Kawidad's Avatar
Oddometer: 5,076
In this picture there appears to be a line on the rubber seating portion of the needle. If so, that's your likely problem. It doesn't take much. Also, I've had them stick and a sharp whack with a small hammer (carefully) will fee up the stuck valve.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 04-01-2013, 08:20 AM   #71
fleshpiston OP
Oddometer: 612
Thanks for all the input guys.
Everything is back together, I sucked 4 oz's of gas out of the airbox. Filter is cleaned and re-oiled, fresh spark plug. Some fresh oil tonight and I'll take it for a ride probably Wednesday when it warms up.
Fingers crossed!
SRX600
SRX250
SR500
KLR650
Old 04-03-2013, 01:14 PM   #72
fleshpiston OP
Oddometer: 612
Well I got out for a short blast today. Everything seems to be working fine!
I stayed close to home, I still don't trust it 100% . Took a few pics before I put the cases back on......
Wow..... what an improvement! Suspension is just so plush and controlled.
The engine really surprises me though, this old 89 motor pulls waaay stronger than the 96 did. Probably a combination of less weight, KLX needle, clean filter, the lighter flywheel, LV pipe, and me not having ridden in months
I did notice the limited steering lock while doing a u-turn in the street though. I'll grind the stops down a little more, but not anytime soon. It's a minor issue that can wait till next winter. Over all ....... I'm pretty damn pleased with the result
SRX600
SRX250
SR500
KLR650
Old 04-03-2013, 01:17 PM   #73
bomber60015
Oddometer: 14,862
Well done! Looks like big sweaty fun!
Old 04-03-2013, 01:24 PM   #74
mdlak
Oddometer: 201
Really nice job!
mdlak is online now   Reply With Quote
Old 04-03-2013, 01:57 PM   #75
brothermosley
Motorcycle Operator
brothermosley's Avatar
Oddometer: 624
Awesome bike! Good work
2008 WR250R
brothermosley is offline   Reply With Quote
Times are GMT -7.   It's 06:09 PM.
