Old 01-28-2013, 09:06 AM   #1
Beater OP
Airheaded, eg Simple
Beater's Avatar
Oddometer: 3,251
OIl Pan and Oil Filter Installation Theories
Tell me how you put these gaskets on. I have replaced many in my short carrier, and every frickin' one of them leaks. Most just a drip here and there ... but the neurosis has finally kicked in, and if I see another drip, I'm going ballistic. Seriously.
The Dobber has always leaked a bit ... but after this latest gasket change, it's a large drip. Constant, and like 5mL / day. It needs to STOP.
The requisite picture:
Fred
'85 R80RT G/Sified <|> '73 R75/5 LWB
Simply Simple and getting more so.
Beater is offline   Reply With Quote
Old 01-28-2013, 09:43 AM   #2
craydds
craydds's Avatar
Oddometer: 1,157
Are you asking about the oil pan, oil filter cover, or both?
1. Oil filter cover. http://bmwmotorcycletech.info/Oil.htm , and http://www.largiader.com/tech/filters/ .
measure this:
and this:
It is the white o-ring that seals and prevents leaks. I have no leaks on my bike. I do not use a gasket on the cover, some do, and this is addressed in Anton's article:
cover on, new white o-ring, correct thickness of o-ring and metal "shim" for the depth of oil filter canister equals no leaks:
2. Oil pan. Here is a fairly straight forward oil pan and gasket installation - http://bmwmotorcycletech.info/pangasket.htm
ABC #12947
'75 R90S
craydds screwed with this post 01-28-2013 at 10:59 AM Reason: oil
craydds is offline   Reply With Quote
Old 01-28-2013, 09:45 AM   #3
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 3,618
I lightly grease the sump gasket, both sides.
Cray- where did you come by that measuring stick, it's perfect ( & dead simple) for this?!
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 01-28-2013, 09:58 AM   #4
craydds
craydds's Avatar
Oddometer: 1,157
I can't remember; I have had that thing forever (possibly a Sears Craftsman thing?). I use it all the time, it is stone axe simple, kind of like my brain.
ABC #12947
'75 R90S
craydds screwed with this post 01-28-2013 at 10:05 AM Reason: sears
Old 01-28-2013, 11:08 AM   #5
some_guy
some_guy's Avatar
Oddometer: 144
My oil pan gasket was weeping. No drips, but the pan kept getting oily a couple weeks after a wash. Pretty much all of the bolts had loosened to just more than finger tight. I'm going to start checking these more often.
some_guy is offline   Reply With Quote
Old 01-28-2013, 11:35 AM   #6
ME 109
ME 109's Avatar
Oddometer: 2,725
First thing would be to thoroughly check both surfaces (sump) for any scratches/gouges etc.
Second, I would check the sump cover for warp.
My sump weeps, sometime in the not too distant future I'll take my own advice.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 01-28-2013, 08:49 PM   #7
supershaft
because I can
Oddometer: 9,116
Well, just to prove that I do sometimes agree with the bum. No sealant, oil or grease. Clean! Stock gasket. And now the Bum and I part. My advise is to buy and use an inch pound clicker torque wrench. Good with guessing torque? With bolts inches apart on top of such a thick gasket. No on is that good. 75inpd??? Not nearly tight enough! 100inpds. Around and around until they ALL click at the same time. Ride it just once or twice and re-torque. Re-torque them once or twice a year. You will find that there are at least a couple of bolts that need it! I have good luck with this method. My bikes have literally gone for decades thusly and not even weeped!
Old 01-28-2013, 09:39 PM   #8
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
For sure, if you just don't have the feel from daily experience, you should use a torque wrench. It will save you money. But lots of people do develop a good feel and simply do not need it for all but a very few critical fasteners on the Airheads.
DoktorT is offline   Reply With Quote
Old 01-29-2013, 03:26 AM   #9
Paul_Rochdale
Paul_Rochdale's Avatar
Oddometer: 150
Here we go again
Paul_Rochdale is offline   Reply With Quote
Old 01-29-2013, 03:36 AM   #10
georgesgiralt
Oddometer: 102
Ray,
Could you please tell me what is the device bolted into your filter housing cover and what's it's use ?
Thanks.
To the others, gluing the O-ring and shim with grease on the cover is an easy way to get the things done properly and not leaking...
georgesgiralt is offline   Reply With Quote
Old 01-29-2013, 03:39 AM   #11
chasbmw
Oddometer: 2,208
The BMW tool kit contains a short 10mm ring spanner that is perfectly sized so that you have to be really ham fisted to strip the threads. On earlier bikes the oilpan bolt underneath the oil filter is shorter than the rest so don't get them mixed up!
Charles
1971 Commando Fastback
chasbmw is online now   Reply With Quote
Old 01-29-2013, 06:04 AM   #12
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,403
Fred, I've had good luck putting a thin layer of RTV on both sides of the GASKET. I triple check the torque over a period of a few weeks. I have a silicone oil pan gasket if you want to try to layer.
Old 01-29-2013, 06:37 AM   #13
oldroadie
Two wheel addict
Oddometer: 468
Easy there, man, I've got drips too! Dry gasket, letters up, inch pound clicker and I still have tiny puddles after any week of sitting. I've got a drip sheet under the center stand made from left over roofing tar paper and life is good.
oldroadie is offline   Reply With Quote
Old 01-29-2013, 06:57 AM   #14
craydds
craydds's Avatar
Oddometer: 1,157
Originally Posted by georgesgiralt View Post
Ray, Could you please tell me what is the device bolted into your filter housing cover and what's it's use ?
It is a temperature sending unit that came with my Acewell, it can be used for water or oil temp. There are two temp readouts on the Acewell, one for ambient air temp, the other for oil (or water) temp. A few more details starting in post #393 here - http://www.advrider.com/forums/showt...527749&page=27 .
ABC #12947
'75 R90S
Old 01-29-2013, 07:16 AM   #15
georgesgiralt
Oddometer: 102
Thanks !
Times are GMT -7.   It's 01:58 AM.
