01-29-2013, 03:41 PM
#16 | |
because I can
Oddometer: 6,045
01-29-2013, 03:45 PM
#17 |
Oddometer: 1,025
so if you were to engage an X and a non X gear the teeth will not mesh properly while matching gears will ?
In other words, matching gear teeth will engage fully, down to the root of the tooth, while non matching gears won't. |
01-29-2013, 03:51 PM
#18 |
because I can
Oddometer: 6,045
I have seen it done numerous times working hear and there. They fit together just fine. They do make a bit more noise from the get go. From what I have seen, it takes 5 or 10k miles for them to eat themselves. That they will do! Very unfortunately, I have seen some pure unobtainium close ratio intermediate shafts F'ed up for it. Man I wish I had those F'ed up shafts now that I know you can swap those gears!
01-29-2013, 04:43 PM
#19 |
Oddometer: 1,025
I would have thought that if the tooth angle is different that non matching gears would not engage the same depth as matching ones. What I'm getting is that You have a couple of shafts in your hand and you're trying to figure out whether you can replace one with the other by engaging the two gears and looking at how deeply they engage. I'll probably be doing that on Saturday since I have to replace the gear on an input shaft and will be looking at some used shafts to source the parts from.
01-29-2013, 05:30 PM
#20 |
Oddometer: 20
01-29-2013, 05:46 PM
#21 | |
because I can
Oddometer: 6,045
01-29-2013, 06:29 PM
#22 |
Oddometer: 1,025
01-29-2013, 06:53 PM
#23 |
because I can
Oddometer: 6,045
yup
01-30-2013, 07:36 AM
#24 |
ShadeTreeExpert
Oddometer: 4,980
Yes it has been done this way. It is mentioned on Snowbum's site but I don't think he talks about what happens with the push rod length. Does it also get chopped? I'd have to compare myself to be sure. I think the push rod stays as is. But I'm not sure.
Do use some kind of an air powered rotory tool with a fresh cutting wheel. Or I guess make do with what ever you got. Also bevel the edge of the cut. Big advantage of course is this can be done with the trans assembled.
Never memorize something you can look up. ---Albert Einstein |
01-30-2013, 09:03 AM
#25 |
Oddometer: 996
You probably need to use the later pushrod. The tip is hardened
Charles http://i46.photobucket.com/albums/f1...ps6e61ae2e.jpg R90s 1070 replica, R90/6 1971 Commando Fastback |
01-30-2013, 10:03 AM
#26 |
ShadeTreeExpert
Oddometer: 4,980
I don't think so Charles. My understanding is the push rods are different lengths, they go with the cover, bearing set up, so I don't think you can use a later push rod unless you use a later cover. I might be wrong though.
Mr Bum makes no mention of the push rod. I guess I should think this means it works as is. I don't think he ever passes up an opportunity to add a couple extra paragraphs to his web pages, does he?
01-30-2013, 10:27 AM
#27 |
Oddometer: 996
Dissiton,
I have a feeling that you are right.
01-30-2013, 12:08 PM
#28 |
because I can
Oddometer: 6,045
Like a lot things on mr. bum's site, going on and on about something does not necessarily mean that it has been done at all and if it has been done it certainly does not mean it will work as well as other methods if it works at all.
It sounds like it would work. In practice? I bet cutting that shaft is easier said that done. Especially without ruining the temper on those splines. |
01-30-2013, 12:19 PM
#29 |
ShadeTreeExpert
Oddometer: 4,980
