Old 01-29-2013, 09:27 AM   #1
tar356 OP
tar356's Avatar
Oddometer: 83
R1100 caliper question
I have an odd issue with the left front caliper on my '99 R1100. I can't seem to get the bleeder to stop weeping???
I flushed and bled the system recently, and was very careful not to overtighten the bleeder, but now it weeps just a bit around the threads. I'm wondering if the seat has been scored/galled from overtightening in the past? The bike has been serviced by dealership in the past...hmmm.
Anyone had a similar problem?? I'm thinking that if the seat area is bad, then I'll need another caliper, unless someone has a good solution.
Todd Rudaitis
tar356 is offline   Reply With Quote
Old 01-29-2013, 11:52 AM   #2
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Even though you already bled the system, I think your only choice is to pull the bleeder, check it, check the caliper also for scoring, and maybe try to replace the bleeder first, just to see.
My local AP store has metric bleeder nipples in stock, so you may find a test one cheap.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 01-29-2013, 02:45 PM   #3
tar356 OP
tar356's Avatar
Oddometer: 83
I should have added in my post that I've tried a new bleeder. I'm thinking it's scored down in the seat.
I may try and reface the seat in my mill.
Hate to buy another caliper, but....
Todd Rudaitis
Old 01-29-2013, 04:52 PM   #4
bikecat
bikecat's Avatar
Oddometer: 1,122
Try new copper washers?
bikecat is offline   Reply With Quote
Old 01-29-2013, 04:54 PM   #5
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,811
no copper washers on bleeder
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-29-2013, 06:22 PM   #6
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,906
Are you sure the weeping is ongoing? - it could be some residual liquid appearing to seep out for a few days. Give the area a good wash and see what it looks like after it's dried out.
If it really is weeping, there is a tool to recut/reface the seating surface in the bottom of the bleed nipple thread. You could also pull the nipple out to check for any grit or corrosion or perhaps a sliver of metal from a thread sitting across the seating surface.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast screwed with this post 01-29-2013 at 06:28 PM
slartidbartfast is offline   Reply With Quote
Old 01-29-2013, 06:52 PM   #7
tar356 OP
tar356's Avatar
Oddometer: 83
slartidbartfast - my thoughts too...brake fluid is thin slippery stuff...could be residual coming down the threads from the new bleeder I installed. Everything is bone dry right now...will monitor.
I'm curious about the tool you mentioned....have any info?
Todd Rudaitis
Old 01-29-2013, 07:19 PM   #8
slartidbartfast
Oddometer: 4,906
I'll be darned if I can find any reference to such a thing now (but I know I saw one somewhere before). There's also a repair kit where you drill the nipple hole oversize and tap for an NPT thread so you can screw in an insert with a new nipple in it. Google "nipple therapy"
... Maybe try "brake nipple therapy"
Old 01-29-2013, 07:59 PM   #9
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,547
You could thread an adapter/copper washer into the bleeder port and install a bleeder in the adapter. But, I would try your mill first....just a touch with a cutter to reface the nipple seat and you'll likely be fine....sorta like refacing an engine valve seat however, the angle is not as critical.
def screwed with this post 01-29-2013 at 08:11 PM
def is offline   Reply With Quote
Old 01-30-2013, 01:28 PM   #10
matey peeps
Bead Buddy
matey peeps's Avatar
Oddometer: 3,333
Maybe a little teflon tape around the threads of the bleeder screw?
matey peeps is offline   Reply With Quote
Old 01-30-2013, 02:36 PM   #11
kellymac530
motorcycle addict
Oddometer: 1,052
NEVER ever under any circumstances should you put Teflon tape on a tapered seat fitting. ALL of the seal needs to be on the tapered seat and NOT on the threads.
If you find a tapered seat ream in the size you need, I would remove the caliper and push out the pistons and make sure it is completely debris free and clean before reassembly. you would not want a small metal chip down in the seal of the caliper piston, tearing it and blowing your brake fluid out all over your pads...not to mention loosing all stopping pressure.
You probably already knew this, but worth a mention.
I was thinking if you took off the caliper, shined a small light in the bleeder port, you might be able to see the issue. Possibly...at your own risk of course, be able to take a drill bit JUST with your fingers though NOT a drill motor, and gently use the angle of the cutting edge of the drill bit to re-surface the taper, kind of like burnishing and ridge or burr off and then a fresh new bleeder screw and see if that works. Free too...except the new bleed screw..
Old 01-30-2013, 02:41 PM   #12
def
def's Avatar
Oddometer: 10,547
This needs further amplification.
As mentioned above, never use teflon tape on any brake system fitting. The teflon may come loose and cause brake failure.
Brake fittings should seat and be drip tight otherwise, repair appropriately.
Old 01-30-2013, 02:48 PM   #13
kellymac530
motorcycle addict
Oddometer: 1,052
def,
Did I finally get something right?
Old 01-30-2013, 03:09 PM   #14
baloneyskin daddy
bikaholic
Oddometer: 2,161
Just put a solid bolt in the hole.
baloneyskin daddy is offline   Reply With Quote
Old 01-30-2013, 06:30 PM   #15
def
def's Avatar
Oddometer: 10,547
def,
Yes, BIG TIME!
Times are GMT -7.   It's 12:41 AM.
