01-30-2013, 10:55 AM
#16 |
fine beer sampler
Oddometer: 1,534
Don't know myself, but Eliteless installed one, on his /5, and said the spark was visibly brighter, when checking laying on the head.
1978 R100/7 Build thread 1915 Boardtrack racer replica (Electric Powered) Lots of bicycles Hemp: The strongest natural fiber in the world, and the most nutritious plant on earth.....why is this illegal again?
01-30-2013, 11:54 AM
#17 |
Confirmed Curmudgeon
Oddometer: 3,899
Outdated Sigline. :)
Or is it a Taunt???? :( --Bill
'73 R60/5 Toaster |
01-30-2013, 04:30 PM
#18 |
Dutch fool
Oddometer: 679
Have one on my Twin-spark R90.
Point ignition, booster and 2 dual Dyna coils. No more sparking over the points, fatter spark over the plugs, starts on the first push on the button, every time. Paul.
Geht net, gibbet net. |
01-31-2013, 07:00 AM
#19 |
Living the Legend
Oddometer: 11
Any pictures on installation of the Velleman Ignition Kit?
Dave H San Antonio, TX |
01-31-2013, 09:53 AM
#20 | |
ShadeTreeExpert
Oddometer: 5,020
Charlie
Never memorize something you can look up. ---Albert Einstein |
01-31-2013, 01:43 PM
#21 | ||
Oddometer: 160
http://www.vellemanusa.com/downloads/0/illustrated/illustrated_assembly_manual_k2543.pdf Quote:
(I know, it's Wikipedia, but FWIW there's a comment here on why there is an improvement in breaker point life, among other advantages) - http://en.wikipedia.org/wiki/Capacitor_discharge_ignition http://en.wikipedia.org/wiki/Ignition_coil Bob |
01-31-2013, 04:48 PM
#22 |
ShadeTreeExpert
Oddometer: 5,020
Hey, thanks for the directions. Looks like the radio receiver I was supposed to build when I was in High School but I never did. I find this sort of thing happens to me all the time that stuff from my childhood comes back to haunt me.
02-04-2013, 10:06 PM
#23 |
Oddometer: 19
Would you try one if it was free?
I've followed this thread, and many of you said the cost of the booster wasn't worth the performance gain. But what if there was no cost? I found a Dyna III on a project bike. Do these ever go bad, or need to be tested to make sure they still work? I would probably lean towards the less complexity argument, but those I have spoken to about it all leave their old ignition in place, in the (unlikely?) event one of these did fail. I am curious enough to try it, if I can figure out the installation. On an R100S, BTW.
02-04-2013, 11:32 PM
#24 |
ShadeTreeExpert
Oddometer: 5,020
You have brought up a different subject. The original subject of this thread is the use of what is known as the "Booster". These are sometimes called CDI or Capacitor Discharge Ignitions. They were common in the late Sixties and Seventies Hot Rod market. The Booster is something added to the standard ignition points ignition. It is wired into the OEM circuit. While the original ignition points are kept in place their job becomes easier and the parts last longer.
The Dyna III is an electronic ignition conversion unit. It does not keep the ignition points in place. It uses a different form of electronics to trigger the unit. This is usually a Hall sensor. The Hall sensor is grafted onto the advance unit usually rendering it useless at any future date should there be any desire to return to the OEM set up. The ignition points and the ignition points plate are not used at all. They will not be on the bike if needed for a return to OEM ignition. To answer your question, "Do they ever go bad?" Yes. The problem with a Dyna III when it has stopped working is, is it the amplifier or is it the Hall sensor? Repair is most times a replacement of the entire unit. If this problem occurs on the road and far for repair facilities there is very little likelihood of a return to OEM ignition to get the bike running again. If you have a failure of a Dyna III ignition you need a pick up truck to get back to civilization. This is the crux of the matter. The modification of a points ignition. You have several choices. 1...is the conversion of the points ignition to a modern total electronics set up that does not keep any of the OEM parts in place and should there be a need to convert back to OEM ignition will be almost impossible. Or 2...the addition of a Booster that keeps the ignition points and other parts in place and should there be a need to convert back to OEM ignition this can be done by moving a couple of wires. I like the idea of a Booster added to my 1975 BMW OEM ignition. I will not convert the bike to a Dyna III unit. If you were given one of these and wish to use it you may get many years of trouble free service from it but I would stock pile the parts needed to replace it for the day when this is needed because I think it's one of those things that's a matter of "when" not a matter of "if".
02-05-2013, 05:11 AM
#25 |
Oddometer: 1,010
Having run electronic ignitions on Nortons and BMWs since the early 70s I have yet to be convinced about the inherent unreliability of electronic ignition..........
With points ignition, assuming that you have set it up correctly, it will then drift off optimum as time goes on, the mechanical advance and retard is a crude device and much better ignition curves can be obtained using a fully electronic ignition, etc etc. crankshaft mounted ignitions can enable you to retain a back up ignition if you wish.
Charles http://i46.photobucket.com/albums/f1...ps6e61ae2e.jpg R90s 1070 replica, R90/6 1971 Commando Fastback |
02-05-2013, 10:53 AM
#26 |
Oddometer: 19
Thanks for the clarification
Dyna booster != Dyna III. That goes a long way to describe why the installation instructions weren't what I expect.
02-06-2013, 11:41 AM
#27 |
Oddometer: 135
Thanks all for your opinions. I will stay with the points only and see how long they last. Besides... they're cheap to replace.
WTB... peanut valve covers in good nick. |
02-06-2013, 08:39 PM
#28 |
Oddometer: 931
Excellent decision. Just brilliant I tell you.
02-09-2013, 12:57 AM
#29 |
ShadeTreeExpert
Oddometer: 5,020
I received my Velleman ignition kit yesterday. The directions are confusing and there will be a few extra small parts needed for the connection to the bike. I also have not decided if I will mount this with or without putting it in a small box. Over all it does look like it is intended to be, something that can be built and added to the standard ignition system of most any internal combustion engine making it more reliable and efficient.
Because this is a kit and not a finished box it is not a plug and play system such as the Dynatek Booster. It was less than half the price though. I will start another thread about this build and give more concise directions hopefully than those published by Velleman.
02-21-2013, 08:05 AM
#30 |
Oddometer: 65
Just signed up so I can throw my 2 cents on this.
I installed a Velleman Ignition kit 5 years back. It cost £10 and has been 100% reliable. Building the kit is easy, finding a suitable box less so. I mounted the unit under the tank just forward of the rear coil so as to keep the cables as short as possible. I found the supplied heat sink took up too much space and substituted a larger ribbed alloy plate as the cover for a shallow plastic box. My unit runs very cool so a large fancy heat sink mustn't have been necessary. If you haven't built it yet I would consider drilling out the cable connection holes on the circuit board so a decent gauge of wire can be used to minimise volt drop. I kept the original wiring spade connections stock so that if the unit should fail a return to normal points is easy at the side of the road. Just need to carry the original condenser. I believe a points ignition amplifier does give some improvement in the spark particularly at low revs due to the cleaner faster switching of the coils. The other big plus is my new set of OEM points is lasting a very long time with only minor wear on the heel. Maintaining the correct stock points gap is still important though as the unit has no inbuilt dwell control. Not a great picture but you get the idea.
190e screwed with this post 02-21-2013 at 08:16 AM |
