Old 11-13-2013, 05:46 PM   #1
Mohawk Unit OP
Mohawk Unit's Avatar
Oddometer: 118
Advice on spooning the rear tire on?
Holy wow, I'm having a lot of trouble spooning a new scorpion rally on the rear 800 wheel. I've done a zillion narrower tires in my life but I'm new to these wide rims and I'm sucking hard. Just spent about a whole hour trying to get the last fifth of the bead into the rim. Popped the tube and gave up on it. Chewed up a whole bunch of rubber around the bead area too. I was using this kit and plenty of lube - the last section just WILL NOT roll over into the dish no matter how hard I try to pry.
Anyone willing to share some tips with me? What a sad, sad fail
XChallenge
250XCW
Puch Magnum
Me
Mohawk Unit is offline   Reply With Quote
Old 11-13-2013, 06:07 PM   #2
SOP Dirt-Rider
SOP Dirt-Rider's Avatar
Oddometer: 692
Scorps are far easier than Heidis, just double check that the lower bead isn't up against the rim, it must be down in the rim valley., same for the upper bead that is on the rim already. These tires just don't stretch.
SOP Dirt-Rider is offline   Reply With Quote
Old 11-13-2013, 06:42 PM   #3
Hamish71
Hamish71's Avatar
Oddometer: 409
+1 Changing a tyre can take an hour of bloody hard work where you think you are going to break everything, or 10 mins, and its all about getting the bead into the valley. Try putting it on grass, and using your knees on the tyre to make sure the bead is compressed.
Now: 13 F800GS, Kalamata Olive, with all the fruit!
Previous: 08 F800GS, 09 KTM 300EXC, 05 KTM 450EXC
Hamish71 is offline   Reply With Quote
Old 11-13-2013, 06:46 PM   #4
itsatdm
itsatdm's Avatar
Oddometer: 4,938
That's the kit I use and the last 2 tires I have mounted have been Scorpion Rally's, so it can be done.
Actually pretty easy once you get the first side on. You just have to make sure to get as much of the sidewall into the center part of the rim. As you work up to the top, you may have to go back a little and redo the part closest to what you are working on. Use your hand and force it down. As you get near completion take baby bites.
Old 11-13-2013, 06:46 PM   #5
steveWFL
steveWFL's Avatar
Oddometer: 1,344
youtube videos taught me in minutes.
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Old 11-13-2013, 06:47 PM   #6
jengel451
1 Cool MotherF#$cker
Oddometer: 799
good Lube, good round spoons and small bites. As stated, make sure the opposite side bead is in the rim valley.
If you're using the flat squarish spoons, they suck.
jengel451 is offline   Reply With Quote
Old 11-13-2013, 08:18 PM   #7
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,457
three or four big zip tys can make a world of difference..
Make sure the "bottom" side is in the valley as well..then it will pop right on..
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 11-13-2013, 08:51 PM   #8
sorebutt
Oddometer: 1,901
You need more beer.
sorebutt is offline   Reply With Quote
Old 11-13-2013, 09:00 PM   #9
Lanceld
Oddometer: 4
The valve stem sticking up in the valley is enough to stop the whole process if doing by hand. Start opposite the valve stem and make certain the valve area is the last segmant where the bead will do it's final "popover"
Good luck!
Lanceld is offline   Reply With Quote
Old 11-14-2013, 05:54 AM   #10
Mohawk Unit OP
Oddometer: 118
thanks guys, appreciate it. Time to kick some ass.
XChallenge
250XCW
Puch Magnum
Me
Old 11-14-2013, 05:11 PM   #11
Mohawk Unit OP
Oddometer: 118
Yep, that made it stupid easy.
XChallenge
250XCW
Puch Magnum
Me
Old 11-14-2013, 07:54 PM   #12
SOP Dirt-Rider
Oddometer: 692
Great news!!!!!
Old 11-14-2013, 08:13 PM   #13
murph76
Oddometer: 218
grow stronger
murph76 is offline   Reply With Quote
Times are GMT -7.   It's 12:16 PM.
