Old 01-30-2013, 09:50 AM   #1
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 673
TAG frame mods
I am currently having my R100GS frame strengthened/modified with TAG in Italy.
Their strengthening is basically along HPN lines, their mods are more interesting.
Their basic package includes changing the rake by 2 degrees, through alteration of the headstock that will require a longer t-clamp stem.
They also move the engine position forward within a bandwidth of approx 5-10mm, depending on fork length and rear swing arm used.
The way this has been explained to me is that in most "unholy union" mods the front gets jacked up disproportionately to the rear, with the effect that the center of gravity gets moved backwards. The engine relocation is done to mitigate this effect.
I will be going for the rake change, but am still considering the engine move. Initially the move felt counter-intuitive for a dirt bike, but I get the argument about rebalancing mass.
At this stage I am also put off by the practicalities of the engine relocation on things like exhaust and swing arm.
I would assume that there is enough overlap on the exhaust pipe junctures that you can reclaim 10mm overall, the swing arm is a bigger problem.
TAG's make their swing arms specifically to deal with this issue, I assume by being +105-110mm. My issue is that I have a shiny new +100mm mono from Moorespeed that I got before focusing on the frame.
So my first question is whether there is an obvious way to use my +100mm swing arm for a repositioned engine while keeping shock mounting points where they were intended to be.
The two ways I could think of are either at the front or back of the drive shaft:
- on the front you could simply put a (10mm) spacer onto the front flange of the drive shaft. This seems easy enough in theory, but problems could arise given extent of movement on this juncture. Also the rotating section behind the flange would be sitting further inside the swing arm and I dont know if this is ok.
- alternatively on the rear you could just live with a less deep overlap on the rear coupling. There seems to be approx 5cm of depth there, so would 4cm be sufficient?
I would be grateful for any input on this.
if its all too much brain damage can live with OEM engine location, but its worth thinking through before ditching idea.
Ras Thurlo screwed with this post 02-01-2013 at 07:15 AM
Ras Thurlo is offline   Reply With Quote
Old 01-30-2013, 10:15 AM   #2
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,756
I know this may be the easy way out, but why not just sell your extended SA and use the one that is engineered to work by the company that has engineered the product. I'm sure you could recoop your purchase price on the swing arm. You are already dropping some serious cash on the bike, so what's a little more??
It might end up saving you money and frustration going with what TAG has developed. They have worked out the fitment issues.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-30-2013, 10:37 AM   #3
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
I'd sell the moorespeed one and go with TAG's. It looks a lot cooler too.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-30-2013, 10:54 AM   #4
One Less Harley
Oddometer: 4,756
AW would buy it
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-30-2013, 01:04 PM   #5
Prutser
Prutser's Avatar
Oddometer: 1,021
Do both mods(more speed and TAG) end up with the same wheel travel ?
Could it be that the TAG mod with the U-joint further from the swing arm gives room for more swing arm movement ?
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 01-30-2013, 02:27 PM   #6
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,278
What does TAG say?
Old 01-30-2013, 04:39 PM   #7
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,606
Originally Posted by AntonLargiader View Post
What does TAG say?
I'm gonna bet TAG says, "Buy our parts." "Sell other parts."
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 01-31-2013, 12:48 AM   #8
Clay Spinner
Clay Spinner's Avatar
Oddometer: 715
Hey Ras, does TAG make any fairings or other bits other than the frame mods, swing arm and tanks?
Clay Spinner is offline   Reply With Quote
Old 01-31-2013, 01:12 AM   #9
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,583
This thread is useless without pictures.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 01-31-2013, 01:25 AM   #10
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 673
TAG Tanks
Goodies:
they make 3 types of tanks, two are variants of the stock g/s tanks, the third is a monster 56l made to work with their fairing kit.
All are made of kevlar and have internal baffles to limit petrol slosh. You will also see the front scoops so as to allow for USD forks.
I bought the 35l G/S PD variant, as this has the side steps brought forward by approx 40mm from the stock version, to allow for longer legs.
[IMG] photo tagserbatoiopiccolo_zpsf502032c.jpeg[/IMG]
[IMG] photo tagserbatoiomedio_zps51a05cb7.jpeg[/IMG]
[IMG] photo serbatoiorallyfaraoni001_zps823ecca4.jpg[/IMG]
Old 01-31-2013, 01:28 AM   #11
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 673
more goodies
As previously posted swing arm and fairing kit:
[IMG] photo forcellonetag_zps46851854.jpg[/IMG]
[IMG] photo tagrallyfaraoni005_zps16a7c806.jpeg[/IMG]
Old 01-31-2013, 03:06 AM   #12
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,583
Trust the Italians to get the styling right, check out the angle of the muffler to the rear shroud, perfect.
Would the tank on that have two filler caps?
David Hunn:
Old 01-31-2013, 03:26 AM   #13
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 673
Yes two (BA) caps, and obviously two separate compartments in addition to the baffles.
I have to admit tanks of this size do it for me- the issue on this one is that it is really designed to go with their fairing, so the front portion is too 'cut-off' to look right naked. Am trying to persuade them to do a version for un-faired bikes....
[IMG] photo serbatoiorallyfaraoni003_zps5ea0af76.jpeg[/IMG]
[IMG] photo serbatoiorallyfaraoni004_zpsa96763c2.jpeg[/IMG]
Old 01-31-2013, 03:46 AM   #14
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,583
So they are still available? Probably would be as dear as poison.
David Hunn:
Old 01-31-2013, 04:06 AM   #15
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 673
yes all available
EUR 550 for the 19l, EUR 750 for the 35l and approx EUR 950 for the 56l (all pre tax)
my sense is that the 19l OEM is available at reasonable prices, but the 35l OEM is approx EUR 1,050 new and difficult to get secondhand- so cost is relative
Times are GMT -7.   It's 08:31 AM.
