Thread Tools Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 03-20-2013, 10:25 AM   #151
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,051
Originally Posted by jerdog53 View Post
Might as well do rings and valves while your at it…
You guys are looney! You're all talking about the difference in 5-6 hours of labor and a few hundred bucks vs. Thousands of dollars and 40-80 hours of labor.
Getting the block out of one of these is kinda an epic job and just gaskets and seals are insanely priced.
06 KTM 950 Adventure(The Fainting Goat)
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn is offline   Reply With Quote
Old 03-20-2013, 10:26 AM   #152
jerdog53
Crop Dusting Everywhere
jerdog53's Avatar
Oddometer: 5,762
Originally Posted by troidus View Post
That's what I would do, but OP may be on a budget. I'd at least inspect the rings and make sure there aren't shavings embedded in the lands.
and more work pulling the heads of
13 Hyperstrada 09 696 Monster
"Shorter of breath and one day closer to death"
jerdog53 is offline   Reply With Quote
Old 03-20-2013, 10:27 AM   #153
jerdog53
jerdog53's Avatar
Oddometer: 5,762
Originally Posted by Xtremjeepn View Post
You guys are looney! .
You asked....
Old 03-20-2013, 10:38 AM   #154
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,051
Thumb
You asked....
Just pointing out that there is always an "ideal" way to do something but that way may not make the most sense for all kinds of reasons like cost/benefit /time etc.
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-20-2013, 10:44 AM   #155
jerdog53
jerdog53's Avatar
Oddometer: 5,762
We could add a supercharger....
Old 03-20-2013, 10:45 AM   #156
jerdog53
jerdog53's Avatar
Oddometer: 5,762
We could make it 4 wheel drive....
Old 03-20-2013, 11:57 AM   #157
ducnut
Oddometer: 3,317
I think yer' fallin' off the wagon.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 03-20-2013, 11:58 AM   #158
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,051
That is a part of the ultimate plan. I just need to source the parts and it can't be done with the vr6. So need to make the vr6 last until I can source all the parts.
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn screwed with this post 03-20-2013 at 12:37 PM
Old 03-20-2013, 02:40 PM   #159
husqzilla
husqzilla's Avatar
Oddometer: 163
I hope you can get this all done by the time your daughter gets her license and starts driving.
husqzilla is offline   Reply With Quote
Old 03-20-2013, 03:03 PM   #160
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,051
Unfortunately the Eurovan will probably be the last of my cars when will want to drive
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-20-2013, 05:51 PM   #161
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,430
Check the mains, if good, button it with new rod bearings. Change oil a lot more in the future. May want to run some ATF before each oil change to clean up engine. Good luck.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 03-21-2013, 03:18 PM   #162
Keith
Slabbing it
Keith's Avatar
Oddometer: 894
I'd try the bearings, just to see if it'll work. Assuming, everything looks good with the Micrometer.
Hopefully all the stuff that thrashed your bearings has been removed by the oil filter and isn't roaming around the engine, waiting to toast another set of bearings.
I'd be interested to see what that filter contains, I bet it looks a lot like the oil you took out. There might even be some bigger junk in there.
Random Crap
Keith is offline   Reply With Quote
Old 03-21-2013, 03:48 PM   #163
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,051
Eek
Good news...I've definitively found the bad news (and also confirmed that I have way too much practice at this sort of thing and that my initial diagnosis was correct based on what I heard when it happened)
It always bugs me when you can't find that "ah ha moment" of diagnosis. Well, I finally pulled the rest of the rod caps off it measure the journals and found the #3 rod had spun its bearings.
The unfortunate thing is that this journal has some slight ridges when felt with your finger nail. They seem to be from the bearing material though. So going to try to polish this one journal up first and check it again to see if it smooths out.
FWIW, all the journals measures the same at just about 0.007 under the factory new spec, including the #3 with the spun bearing.
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-21-2013, 05:19 PM   #164
vtwin
vtwin's Avatar
Oddometer: 7,430
I hope that piece there is the old bearing and not the crank! Polish, plastigauge, check oil pump, if all good, button up and enjoy.
Monroe.
unknown
Old 03-21-2013, 06:22 PM   #165
husqzilla
husqzilla's Avatar
Oddometer: 163
As is often said on this forum: It'll buff out.
Thread Tools
Times are GMT -7.   It's 11:51 PM.
