Thread Tools Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 03-21-2013, 06:46 PM   #166
jdiaz
Oddometer: 32,246
Woot! You've got a VR5 now.
jdiaz is offline   Reply With Quote
Old 03-21-2013, 06:50 PM   #167
Mrmerlin
K1300S fast as shi..
Mrmerlin's Avatar
Oddometer: 335
Hi Cole this sux man,
thats not good what you found and from this point swapping in new rod bearings will be a waste of time and cash.
I think you have to get into the block and clean it out good and find out where that small piece of metal came from that was clogging the tensioner.
Beyond that the engine needs to be cleaned from all of the metal that has been running through it ,
the lifters are toast as they are contaminated.
Simply cloth sanding the crank isnt going to cut it.
The crank throws are all filled with metal,
the oil cooler if it has one is filled with metal .
So this is a slippery slope on one hand you may need to find a new crank I have never been good with cutting them down ,
Though you may be able to get it polished and see if the journal is still in spec the throws will clog up with cutting material so that you need a bore brush to clean out all of the crud after polishing the crank.
OTOH
You may have to be looking for a used engine thats in good condition.
If you go the route your on now your only going to be throwing good money after bad, what may look like a huge expense may in fact be the least expensive way to go,
New engine time!
PM me your number and we can talk further
Mrmerlin is offline   Reply With Quote
Old 03-21-2013, 08:26 PM   #168
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,046
Rebuilt Long blocks are about $6500
I haven't found a single Euronan VR6 24v parts van yet. Most the used 24vs I've found are in the $3500 range.
No way I'm spending that kind of money on the VR6 if I find a reasonably priced block I'll run it. Until then.
I'll put it together best I can and shop for the diesel swap parts.
06 KTM 950 Adventure(The Fainting Goat)
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn is offline   Reply With Quote
Old 03-21-2013, 09:28 PM   #169
Mrmerlin
Mrmerlin's Avatar
Oddometer: 335
what other cars have this engine? or is this engine exclusive to the Eurovan?
Old 03-21-2013, 09:55 PM   #170
troidus
Oddometer: 14,638
Save your cash. The whole engine is full of metal shavings, and you have to replace that con rod, meaning you're pulling off at least one head. If you try to just put bearings in it, the next time it spins one (and it will) it might put the rod through the side of the block, and if you're lucky it'll be as you back out of your driveway and not when you're trying to merge in front of a semi.
Anything you do from this point that does not involve complete engine removal, disassembly, machine shop work, and new/reconditioned parts is a complete waste of time and materials.
Last time I built a four it was $900. An eight was $1200. I would hope you could fully rebuild your six for under $3000, since you can do everything except the machine shop work.
troidus is offline   Reply With Quote
Old 03-22-2013, 04:04 AM   #171
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,046
Eek
This engine code is specific to the Eurovan. There are other versions of the engine out there that could be made to work, but it's still a bunch of swapping parts around. The Eurovan motor is tilted forward 30* where all the others are straight up and down. The cams are specific to the van for more low end, intake, oil pump, oil, pan, etc.
I've been searching literally worldwide for a replacement from any comparable version since this started with no luck. I could even use the 3.2l long block from a Cayenne or Touareg if I can find one.
Cheapest motor I've found so far is about $3500 shipped with 123k on it and out of a van that was hit in the FRONT
I may just have to get a "parts motor" and piece together good used stuff from both motors to make one good one. There is a Passat 12v motor for $500 in Denver. The crank should fit but that's the only usable part out of it for a 24v motor, maybe
The connecting rods surface is smooth. The van was only run for about a mile on the freeway with the knock. I pulled over as I heard it develope.
The engine is not "full of metal" as everyone is saying. Geesh! There was an EXTREMELY FINE dust of it in the oil, which came out with the oil. Most of it was in the pan. Enough to replace the missing bearing material. There are not a lot of secret hidden passages in here to hide metal chunks. Pretty easy to flush them out before reassembly. I've got it all open right now and can see through the passages.
Funny you mention semis, they run on re-bearinged motors all the time.
Maybe. But it's $58 to try. Bottom line is that the parts are so hard to find for the diesel swap right now that this van HAS to go back together until I can find them or a replacement VR6.
I can't leave it just sitting in pieces in my garage for 6 months to track down the parts. So it must go back together so that it can be moved out. So I may as well try to fix it.
Yep, some motors are that way. Not this one. I've priced some of the parts. The rods alone were $1250, head gasket $250, cams $850 etc, etc. There is a reason a long block is $6500 and not the $1500 of a domestic V8
I've rebuilt engines before and if this could be done for under $1500-$2,000 I'd of had it done weeks ago
The lack of finding a cheap replacement or reasonable rebuild cost is what has me considering trying to just do just the bearings. which of course may or may not work. I fully realize the "ideal" way to do it is a complete rebuild or a nice new engine. Anything else is a gamble, including a replacement out of a wreck.
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn screwed with this post 03-22-2013 at 04:11 AM
Old 03-22-2013, 04:13 AM   #172
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,046
Now if only I could make it run that way.
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-22-2013, 05:42 AM   #173
ducnut
Oddometer: 3,316
I'm with polishing the crank and changing the bearings. You've got nothing to lose. My only concern is what may have caused the spun bearing, to begin with. Myabe, there was a piece of something in the passage that got chewed up by the spun bearing. I'm wondering if you blow compressed air through the furthest away oil passage, to dislodge any debris in the crank. Maybe, somehow plug the other passageways and just have #3 open and the one you're blowing into. IDK, just brainstorming. I don't know what an oil pump costs, but, I think I'd throw one in it. And, plan on bunch of early oil changes, with filter cutting during each one.
You've previously mentioned using engine flush. I've never been comfortable with dilluting engine oil with anything. I can remember being in class and the instructor putting Dexron in an engine, to help clean out sludge. My dumbass neighbor dumped in 2qts of flush, on top of an already full oil pan. He ran his van around a couple weeks, like that, before he told me what he was doing. When, I pulled the filter, it weighed ~4lbs. I was inside the top-end of the engine, a few months later. It was definitely clean. I use SeaFoam products and know they have an engine flush. I'm on the fence with this idea, but, just throwing my limited experience out there.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 03-22-2013, 06:27 AM   #174
eric2
®egister this:
eric2's Avatar
Oddometer: 3,797
Been following this thread. Had a type 2 camper for a while but sold it because I never used it that much; and it was a real dog on the highway.
Anyway, why not install a crank kit, assuming this is a 2.8 liter and that the spun rod journal is still round?
great thread!
Eric
'06 R12GS, '13 s1000RR
Originally Posted by Big Steve View Post
I've yet to see a poor person driving a real gas hog......
lottery: A tax for people bad at math
eric2 is offline   Reply With Quote
Old 03-22-2013, 06:56 AM   #175
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,046
great thread!
They only list a crank up to 99 which was the 12v motor. Mine is the 24v 02 motor.
My understanding from reading forums is that the early crank is forged and the later cast but either will work. But that is just going off what misc people on a few forums say. So I'm not ready to bank on it just yet.
Swapping the crank is an option, but at that point I have to remove the trans again, and dissassemble the head and front of the engine. May as well change the one rod at a minimum to be sure.
So if the crank kit is $200, head gasket $250, rod?, and a ton of labor. I may as well get some sort of upgrade for the work
Which starts to lead me down the path of a 1.9 tdi swap or a 2.4d converted to turbo swap. Which would also gain me the more reliable manual transmission I found a donor Jetta that might be a good deal at $1,800 and have a friend outside the country trying to find me a complete parts van to steal part from for me.
Then I would only have to do the labor once.
Still debating the whole thing.
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-22-2013, 07:36 AM   #176
Mrmerlin
Mrmerlin's Avatar
Oddometer: 335
a Ebay deal
not really sure if it fits but its low mileage
http://www.ebay.com/itm/Volkswagen-V...fe3ca6&vxp=mtr
Old 03-22-2013, 07:38 AM   #177
Mrmerlin
Mrmerlin's Avatar
Oddometer: 335
1999 Volkswagen VW Eurovan - $5 (Denver, Winter Park)
What we have here is a 1999 Eurovan in decent shape. Clean interior with few little imperfections, exterior has some dings and dents too (see the picture).. Good: Super strong motor, smooth 4 speed automotic transmission in very good mechanical shape. Looking for 5000 obo. Email, call, txt me at 970. fivethree1 eight28 2. Thanks
Old 03-22-2013, 07:42 AM   #178
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,046
Cool2
a Ebay deal
Thanks. (Already in my watch list)
Using a new Eurovan oil pump, ($300), and the Eurovan cams, oil pan, intake etc this would work.
Trying to find a similar deal on a 3.2l version of the motor. It's exactly the same jast bigger bore and stroke. Figure by scaling the injectors and maf the computer would never know its there.
Probably gain 20-30hp which of course would help at this altitude. (I'd still be running below the stock seal level output for the 2.8l)
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-22-2013, 07:49 AM   #179
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,046
Laugh
....not a Poptop! That was a ton of work! Not sure I want to do that again.
This one is more equal to mine.(except for the running part) The 24v motor started in 2001.
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-22-2013, 08:43 AM   #180
Ko
Observant as never
Ko's Avatar
Oddometer: 1,110
Given the uncertain reliability if fixing this one on the cheap- why not roll it out the garage and save the pennies/invest time in finding a donor engine-especially since you seem to have some leads?
Ko
no snowflake ever feels responsible for the avalanche...
Ko is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 03:49 PM.
