Thread Tools Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 05-21-2013, 09:44 AM   #301
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,047
Originally Posted by Willius View Post
I noticed and had been wondering about it. Looks good and makes it subtly different from the other EVs out there. Something you or the previous owner did? What's the stroy on it?
PO had it done. Its really subtle. Probably the first time in my life I've been okay with a pinstripe.
06 KTM 950 Adventure(The Fainting Goat)
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn is offline   Reply With Quote
Old 05-22-2013, 05:40 PM   #302
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,047
Photo taken by my friend Max at the VW show. Pretty much describes the pack structure here;-)
02 KTM 520 EXC
04 KTM 351 EXC
Old 05-23-2013, 08:55 PM   #303
Giggity
Giggity's Avatar
Oddometer: 753
^^^^^Fantastic pic
Giggity is offline   Reply With Quote
Old 05-24-2013, 06:13 PM   #304
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,047
Thumb
Since my friend John's Porsche 993 steering wheel has been sitting here I felt compelled to do something about the boring plasticy steering wheel.
The 993 wheel felt MUCH better than the stock VW one but despite having the right splines the holes for the airbag wires and turn signal cancel were all wrong. Not impossible to make work but the 993 wheel just looked too similar and was too expensive to be worth modifying to work.
But.....now that I knew exactly what I was looking at I figured a Audi Sport wheel from a S4/S6 would work. The spines are wrong but conveniently VW/Audi made a factory spline adapter that can be found on MK3 Jettas/Golfs.
I found a deal on a 2001 Audi S4 wheel on craigslist for $50! Then immediately ran off to the pull-n-save to snatch an adapter.......which would be its own adventure!
For those of you with a short attention span.......oh squirrel!......I mean here is the cliff notes picture! The thick three spoke weighted sport wheel feels MUCH nicer to drive with!!! I had no idea a weighted wheel would make such a difference. I swear it handles better!
Now, for those of you with nothing better to do and want to know the silly tech and my follies at the junk yard, keep reading!
For quick reference this is the part I'm after. It's only $42 at the dealer. Figured it would be about $1 at the junk yard.
I read all these posts on various VW forums about how to get these off. Some said they could get it off with a screw driver....B.S!!
I went to the junk yard with a fairly well equipped bag of tools, including a bearing puller, gear puller etc. My bearing puller wouldn't grip onto the part, I even figured out that a wrench between the puller and the spine adapter would create the grip needed but the wrench would just grind into the soft metal adapter! Boo! I messed with the stupid thing on two cars for about 1.5 hours with no luck!! One of the cars someone else had obviously already tried to remove the spline adapter with no luck. They even tried drilling out the safety bolts to remove the whole column with no luck. I left the yard last night defeated by such a simple part.
Ghetto fab trail fix attempt at its best.
After reading the forums some more I came up with an idea........I returned to the junk yard today with 1 tool.....a BFH!!
Trip back to the junk yard......wasn't a bad deal for the aussie!
So I figured out from reading the forum that the steering column is collapsable and the spline adapter is sitting on top of the upper spring. Which lead me to my evil thoughts about how to get it off. I figured I'd try my evil plan on the first car where I had already destroyed the adapter. Take a massive swing at the steering shaft with the hammer and it collapses the column and the spine adapter jumps off like a grashopper. I had so much fun with this method that I picked up three adapters in 3 minutes of work, SO MUCH FUN!!! Hope nobody was in need of a good steering column.
The spine adapter is actually just a touch too long for use on the Eurovan shaft. So it must be trimmed by this much...
After doing the very precise measuring I went over to my high dollar CNC system and trimmed it down!
Perfect fit!
The airbag/horn plug is identical. So is the airbag unit installed in the airbag cover. Plugged right in and didn't throw any coded. However, something on the horn is contacting and causing the horn to stay on. Didn't have time to sort it out today but I'm sure its an easy fix. I think the wheel mounted at this angle allows the weight of the horn to activate itself. So a little trimming of the connectors should cure it.
It's amazing how much of a difference this wheel makes in the overall feel of the van.
02 KTM 520 EXC
04 KTM 351 EXC
Old 05-24-2013, 09:59 PM   #305
MasterMarine
Oddometer: 1,584
Nice!
MasterMarine is offline   Reply With Quote
Old 05-25-2013, 05:34 AM   #306
ducnut
Oddometer: 3,316
Nice that you include your dogs in day-to-day life.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 05-25-2013, 06:47 AM   #307
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,047
Laugh
Is there any other way?. They go everywhere they can with me. It's the only thing I don't like about motorcycles.
02 KTM 520 EXC
04 KTM 351 EXC
Old 05-25-2013, 07:29 AM   #308
RocketJohn
Hook em' Horns!
RocketJohn's Avatar
Oddometer: 11,331
While I think my 4 spoker would have looked great, the 3 spoke S4 wheel looks awesome.
RocketJohn is offline   Reply With Quote
Old 05-25-2013, 03:18 PM   #309
hyperboarder
Potato Farmer
hyperboarder's Avatar
Oddometer: 1,024
That's what sidecars are for brotha :).
Current: 08 Yamaha WR250R, 05 Suzuki DL1000, 92 Ford E250 Motohauler
Gone but not forgotten: 2008 KLR650, 2000 GSXR1000, 1999 ZX6R, 2000 GSXF600, 2004 Ural Tourist, 99 Suzuki DR650
Quarter Life Crisis 2011 Ural National Rally
hyperboarder is offline   Reply With Quote
Old 05-25-2013, 09:41 PM   #310
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,047
Wicked
02 KTM 520 EXC
04 KTM 351 EXC
Old 05-25-2013, 09:44 PM   #311
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,086
Looks great! This is one of the upgrades I plan on doing to my van as well...just need to find the right one.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 05-26-2013, 08:55 PM   #312
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,047
Talking
Finally! After all this work we got to do a first round test run of the van! Just to see how well it works as a camping tool!
The VR6 is doing well. It easily holds the 65mph speed limit on the steep high elevation climbs here in Colorado. (That is Loveland Ski Area in the distance)
Found a nice little spot on Dillion Reservior for the night!
A must have for camping with a 4 month old is a star generating night light turtle
Think before she gets older I should just make the whole top clear acrylic!
Popped the top, set up camp and enjoyed. Few bugs to work out and more mods ahead!
02 KTM 520 EXC
04 KTM 351 EXC
Old 05-28-2013, 09:55 PM   #313
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,047
Thumb
Stumbled on a craigslist deal today. Guy had a brand new in the package set of 60" Yakima rack tracks for $70. These are normally about $130 before tax or shipping! They almost never come up for sale used since people leave them attached to toppers, etc when they sell their cars. (Would you take the time to fill the holes?)
I have a ton of extra Yakima rack stuff laying here, including a brand new set of mounts for these tracks I picked up a few months ago for about $20.
This should make for a nice rack set up. I have a few bike racks, a cargo box and may still have room to mount a solar panel.
I simply layed the tracks next to the hinge inside the roof and drilled the holes. Figuring that mounting it as close to the hinge as possible would give it the most support with the roof up, and down. I also mounted them as far back as reasonably possible. No sense in putting them all the way back since you would never put a cross bar at the back edge of the roof for a box/ski rack/etc.
Between neighborly interruptions and trips to the hardware store for longer bolts I really only got most of one rail sealed up and installed
02 KTM 520 EXC
04 KTM 351 EXC
Old 05-29-2013, 08:50 AM   #314
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,047
Thumb
Had to run some errands today, but had some time to kill so stopped at the Starbucks in Cherry Creek North(Because Aviano Coffee is MIA).
It was the usual mob scene!
Fortunately, I brought my own private patio area complete with table! (This van thing is slick)
Also comes with its own(semi) private changing table!
....and it was kind enough to rain on us for a bit so that I can test all those holes I drilled in the top last night......so far no leaks! The sound of the rain on the roof was also great for putting Elise to sleep!
02 KTM 520 EXC
04 KTM 351 EXC
Old 05-29-2013, 01:15 PM   #315
Lee C
Oddometer: 635
Very cool I need one
Lee C is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 04:19 AM.
