Thread Tools Rating: Thread Rating: 37 votes, 5.00 average. Display Modes
Old 03-02-2013, 12:22 AM   #106
dlearl476
Two-bit Throttle Bum
dlearl476's Avatar
Oddometer: 24,425
Originally Posted by Xtremjeepn View Post
Well, something fun happened with the Eurovan today! The original owner, the artist of the below pictures, sent me the other two original drawing
Did he send you one with a rod flying out the side of the engine compartment?
I feel your pain, brother. I found out yesterday my new-to-me Smart might need a new $1K airbag ECU. That's what I get for forgoing a PPI.
"When the power of love overcomes the love of power, the world will know peace" - Jimi Hendrix
Politics is the gentle art of getting votes from the poor and campaign funds from the rich by promising to protect each from the other. -- Oscar Ameringer
dlearl476 is online now   Reply With Quote
Old 03-02-2013, 10:16 AM   #107
Abenteuerfahrer
Deaf on Wheels
Abenteuerfahrer's Avatar
Oddometer: 2,304
Hi...I've been lurking on your side...
I got a 2002 Eurovan Camper(Winebago) with 120k on it. If you're thinking of dropping the oil pan I believe that you have to remove the right CV joint in order to access the pan bolts there?
Removed mine and the pan was crystal clean. Changed oil every 5-7k miles. I know it's overkill but..lookee there, it's "clean". I also always use 0-40 Mobil 1. It is possible that you have heavy condensation in the pan and your gas tank also has a lot of water.
Good luck...
cheers...
Abenteuerfahrer is offline   Reply With Quote
Old 03-02-2013, 12:34 PM   #108
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,076
Wink
Hey thanks!
I'm sure condensation was possible. It was a New Jersey car it's whole life till I brought it to the insanely dry Colorado.
Might get a look at it soon. My fuel lines showed up for the 951 last night So I'll try to assemble that today so I can get the van inside.
06 KTM 950 Adventure(The Fainting Goat)
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn is offline   Reply With Quote
Old 03-02-2013, 07:28 PM   #109
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,076
Eek
Well the weather was MUCH nicer today. Got the new fuel lines on my 951 so that I could move it out of the way to work on the van inside.
HATE having the 951 outside though.
The knock today sounded much different and seemed to be very much valve noise from the right side of the motor. Guess I will just have to take it all apart and look.
A little classic Porsche Porn for those that like such things
Back in the "work bay"
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-03-2013, 05:05 PM   #110
ducnut
Oddometer: 3,320
If you house me, this summer, I'll come out and help you finish that garage.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 03-03-2013, 06:47 PM   #111
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,076
Eek
I have a spare room. Its yours if you want to help finiish the garage. I can show you some of the local rides as well!
The number one sign I've done this too much already?
.....this was only an hour of work from driving it in the garage
When I started it up to pull it in the garage the knock REALLY sounded like it was coming from the valve train. I've also had some lingering cam codes so I figured I would pull the valve cover and take a look. Not a darn thing to be seen. Cam lock slides right into place when at TDC. Chain is tight. Nothing visually wearing or broken.
Maybe tomorrow I can get and assistant to crank it for me while I watch and listen. Then pull the pan and look there. Unfortunately, that will require removing the right wheel, disconnecting the lower suspension arm, removing both the inner and outer driveshaft to access the pan bolts. FN silly!
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-03-2013, 08:30 PM   #112
ducnut
Oddometer: 3,320
A regular VW mechanic, you are.
'96 Ducati 900SS
Old 03-05-2013, 03:28 PM   #113
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
was there any noise on throttle up? i forgot
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 03-05-2013, 03:31 PM   #114
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,076
Cool2
yep, same noise, just faster. Tracks right with rpm.
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-05-2013, 03:34 PM   #115
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,076
Cool2
.....and if my left arm wasn't busy holding this, I'd be out in the garage working on it(she is the whole reason for the project)
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-05-2013, 11:38 PM   #116
George Papadopolis
between
George Papadopolis's Avatar
Oddometer: 8,930
Shes a little angel, enjoy these days.
“It is difficult to find happiness within oneself, but it is impossible to find it anywhere else.”
Arthur Schopenhauer
George Papadopolis is offline   Reply With Quote
Old 03-06-2013, 04:51 PM   #117
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,076
Eek
Thanks.
Got 5 minutes with the van today. Had the wife crank it while I looked/listened with the valve cover off. Everything seems tight, unbroken and moving as it should.
But.....the oil flowing in the head is obviously filled with metal filings. So the next step is to remove the whole passenger side axle assemble so that I can get the pan off.
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-06-2013, 05:11 PM   #118
ducnut
Oddometer: 3,320
Bummer! Bummer! Bummer!
'96 Ducati 900SS
Old 03-07-2013, 08:42 AM   #119
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
Don't be bummed about it.. it's better to sort it out now than on the side of the road freezing cold....
Old 03-07-2013, 09:33 AM   #120
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,076
Totally agree. Not overly worried about it. It will get fixed and we will have a blast with it.
Just haven't had time to work on it much.
02 KTM 520 EXC
04 KTM 351 EXC
Thread Tools
Times are GMT -7.   It's 07:38 PM.
