Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 03-12-2013, 11:47 AM   #121
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,007
Eek
I was having evil thoughts about trying to fit these to the Eurovan last night
06 KTM 950 Adventure(The Fainting Goat)
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn is offline   Reply With Quote
Old 03-12-2013, 11:59 AM   #122
Abenteuerfahrer
Deaf on Wheels
Abenteuerfahrer's Avatar
Oddometer: 2,299
But WHY ???? Got any warps with the current ones....overheatings ???
Just replaced my fronts because of warps and 120k originals..by buying a total package(German OEM) from Europarts/SD for $200.
Just curious
Cheers...
Abenteuerfahrer is offline   Reply With Quote
Old 03-12-2013, 12:01 PM   #123
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,007
Wink
Originally Posted by Abenteuerfahrer View Post
But WHY ????
Cheers...
Cause they were laying there
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-12-2013, 12:03 PM   #124
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,007
My "daily driver" needed replacement rotors and pads! Which is what those are from Once the brake pad warning light came on I figured it best to make sure the daily driver was up and running first before continuing my work on the van.
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-12-2013, 12:41 PM   #125
MasterMarine
Oddometer: 1,554
On my 02 EV MV Weekender, I ran for at least 10,000 miles after the brake pad warning light came on. I checked the pad thickness every time I rotated the tires and finally did the brakes after replacing the tires with the Nokian Entyre. There was still about 3/32 of an inch of material on the thinest pad.
Next time I am going to get pads without the indicator wiring and just make some jumpers to keep the light off.
MasterMarine is offline   Reply With Quote
Old 03-12-2013, 01:27 PM   #126
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,007
Wicked
FWIW, its easier a to just cut the wires for the existing pad sensors and wrap them together. (Leaving the pigtail plugged in) No jumper to fall out or fab and easy to go back to sensors if you want.
I disabled this feature on my track car (the 951) and on my old Audi S4 when I switched to Stoptechs. Not all race quality pads come with the provision for the sensors.
That said. I had 108k. Miles of use on the pads and rotors so I just replaced them all and put new sensors in. No reason to delete them on a daily use car. I used a complete Powerstop pad and rotor kit and it came with new sensors anyway.
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-12-2013, 05:35 PM   #127
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,007
Question
Okay, I got about an 1.5 hours of work in on the van and need some input from you guys.
Drained the oil and it was VERY silver and metallic looking.
Every rod has some play to it. I can "fairly easily" wiggle the rods back and forth, but no noticable up/down movement. There was no obvious single rod problem.
I pulled the bearing caps off a few of the "looser" rods and found some scoring on the rod bearings but the crank looks perfectly polished.
Here was the worst of the group. (I was going to measure them but A) couldn't find the stock spec and B) the batteries in my calipers were dead)
Thoughts on this?
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-12-2013, 07:09 PM   #128
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,373
Looks like it ran dry for a bit. Don't suppose there was any coolant contamination? I'd run some plastigauge in there to get a base line measurement.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 03-12-2013, 07:38 PM   #129
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,007
No coolant contamination.
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-12-2013, 09:46 PM   #130
Abenteuerfahrer
Deaf on Wheels
Oddometer: 2,299
Hi Mastermarine...
How do you like the Nokian eNTYRE ? Did the same on my 02 EuroVan Winnebago Camper, put on the 225/60-16. 102H XL. So far so good with 7600 miles on them but need a better toe in/out!
cheers..
Old 03-12-2013, 09:50 PM   #131
Abenteuerfahrer
Deaf on Wheels
Oddometer: 2,299
Thoughts on this?
Seems like Oil didn't get in there very well. Check oil passages! Or previous poor oil change history??
cheers...
Old 03-12-2013, 10:33 PM   #132
troidus
Oddometer: 13,790
Ugh. Slop and scoring is never good. You saw oil being pumped to the head, so the pump itself is spinning, but whether it's getting everywhere it needs to go remains to be seen. Have you cut the filter open yet to see if it came apart? Maybe some media tore loose and clogged a passage.
troidus is online now   Reply With Quote
Old 03-12-2013, 10:42 PM   #133
troidus
Oddometer: 13,790
I think you need to work more on go than whoa for now.
Old 03-12-2013, 10:53 PM   #134
Xtremjeepn OP
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,007
Eek
Details details.
I can pull the filter next.
Rod bearings are only $58 so I'm considering trying to get buy with just new bearings for the moment. I'll probably pull the oil pump apart and the cam adjusters and make sure there is not something clogged in there somewhere.
02 KTM 520 EXC
04 KTM 351 EXC
Old 03-13-2013, 03:21 AM   #135
Maccoul
Bam Bam
Oddometer: 101
Did you pull your main bearing caps? How much end play on the crank? Check your thrust bearing. Your in that far, seems silly not to at least pull the caps and check
Maccoul is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 09:45 PM.
