Old 01-31-2013, 10:30 AM   #1
1reddawg OP
1reddawg's Avatar
Oddometer: 2,292
Issue with Cam Chain tensioner upgrade
I am having trouble getting the spring Loaded Cam Tensioner upgraded bolt started to finish the job.Any ideas or suggestions on how to get this bolt started.There just isnt enough room to get a good turn on the bolt to get a thread started. Any ideas will be greatly appreciated.
Thanks as always
1 Frustated Reddawg..
Current ride
2012 BMW Triple Black GSA
1reddawg screwed with this post 01-31-2013 at 12:10 PM
1reddawg is offline   Reply With Quote
Old 01-31-2013, 01:15 PM   #2
gsweave
Yinz, blinkers are on.
Oddometer: 11,796
Thanks as always
Left side? did you remove throttle body or are you tryin to work around it?
1 Peter 2:16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave screwed with this post 01-31-2013 at 01:24 PM
gsweave is offline   Reply With Quote
Old 01-31-2013, 01:37 PM   #3
1reddawg OP
1reddawg's Avatar
Oddometer: 2,292
Throttle body is taken off.Left Side
Current ride
Old 01-31-2013, 02:20 PM   #4
gsweave
Oddometer: 11,796
do you own an old socket that you can cut down?
Old 01-31-2013, 02:48 PM   #5
1reddawg OP
1reddawg's Avatar
Oddometer: 2,292
I will give that a try,Thanks gsweave
Current ride
1reddawg screwed with this post 01-31-2013 at 03:05 PM
Old 01-31-2013, 03:06 PM   #6
tps
Oddometer: 66
Thanks as always
I was able to fit a 12 point box end wrench around mine, push it down with my finger, and hold it down while getting 1 or 2 points of a turn each time. It eventually caught. Yeah, it was a real pain...
'04 R1150GS Adventure
'88 K75S, Red - Hellboy
'72 R75/5 Toaster, Blue - BluBawls
http://www.drysideriders.com
tps is offline   Reply With Quote
Old 01-31-2013, 08:16 PM   #7
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 2,012
push harder
mine was a bitch.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is online now   Reply With Quote
Old 02-01-2013, 05:22 AM   #8
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by trc.rhubarb View Post
push harder
That's about it right there. The new tensioner device is filled with oil, has an internal spring, and has a ball check valve at the bottom of the piston bore. (You can see part of the check valve ball at the bottom of the bore.)
When in service, the one-way check valve allows the new tensioner cylinder to fill with oil easily. You know, it lets oil in but won't let it out. Once the cylinder is filled with oil the piston is very hard to compress. The reason for the difficulty is the only path for the oil to escape is between the tight piston-to-cylinder clearance. I don't mean the original tensioner body piston, but the piston clearance on the new tensioner 'insert' you are installing.
The new tensioner is shipped filled with oil. What you can do is get the oil out of there. That makes the tensioner insert (and the original screw-in tensioner body) easier to compress by hand while installing it.
Here's one way to remove the oil. Clamp the new tensioner in a VERTICAL vise or other VERTICAL clamping method. Clamp it between the jaws with the open end of the piston pointing down, and the cylinder pointing up. Note: You're doing this with only the tensioner insert in the jaws, not the whole screw-in tensioner body.
Slowly close the vise and watch oil weep out from between the piston-to-bore clearance. The first portion of the compression process is usually easier because there is often some air inside the tensioner along with the oil. And if so the air will compress much easier than the oil will squeeze past the piston clearance. Turn the vise handle a little and wait a few moments for the oil to begin weeing out. When the oil flow stops, turn the handle a little more.
After the piston is compressed and the oil has found its way out, the piston will be much easier to compress by hand. It still won't be easy, but it will be easier.
BUT WAIT there is a caveat to all the above. The issue may just be that the cam chain is pushing up on the chain guide, which reduces the available space for the tensioner body. To solve that, put the gearbox in a high gear and turn the rear wheel forward a little. Doing that rotates the crank and cam chains in the forward direction, and ensures that the slack side (the side the tensioner is on) of the chain is slack, and allows the maximum room to install the tensioner body.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 02-01-2013, 05:35 AM   #9
rdwalker
Oddometer: 2,541
Originally Posted by Poolside View Post
... Here's one way to remove the oil. ....
This is quite useful info, thanks! This thread caught my eye, as I am just now ordering the tensioner for my 1150RT; how timely!
Great reference, appreciated.
By the way, for any lurkers here: this is Jim's write-up on tensioner replacement: http://advwisdom.hogranch.com/Wisdom...ionerSwap.html.
(I still have in my archives a snapshot of his original pictorial thread from 8 years ago, when Poolside was a young'un, with only 1,725 posts to his credit... )
And, to add to installation hints: apparently, a lot of swearing eases tensioner compression. Check out between markers 6:45 and 8:30 of this video. I like that "encouragement" method - I use it a lot myself!
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker screwed with this post 02-01-2013 at 06:27 AM
rdwalker is online now   Reply With Quote
Old 02-01-2013, 05:44 AM   #10
slipperyeel
Oddometer: 9
Thanks as always
I didn't have much trouble with this job so i am wondering why you might be. I wondered if the cam chain is somehow at its tightest point, but it should be on max slack without the tensioner in there and besides, you're only talking about getting the threads to start engaging.
I would check the bolt threads carefully and make sure you haven't been unlucky with the part you've been supplied (compare it closely with the old one). Maybe it has been dropped or machined badly?
Otherwise stick with it. It's a worthwhile job, makes a big difference.
Good luck
slipperyeel is offline   Reply With Quote
Old 02-01-2013, 08:36 AM   #11
1reddawg OP
1reddawg's Avatar
Oddometer: 2,292
Thank You Poolside This did it.It took longer to get the bike in a higher gear than to get the bolt started!! I litteraly was trying yesterday for 4 hours trying to get that Bolt started.. Thank You all again for your advise & Help!!!
Current ride
1reddawg screwed with this post 02-01-2013 at 08:52 AM
Old 02-01-2013, 09:13 AM   #12
kimokk
kimokk's Avatar
Oddometer: 103
What model years does this upgrade apply to?
'09 BMW R1200GSA Adventure! (gone)
IBA #49426
kimokk is offline   Reply With Quote
Old 02-01-2013, 09:37 PM   #13
rdwalker
Oddometer: 2,541
Not yours.
I don't know exactly which models had the "old" tensioner originally - I believe it was through 2005.
But, in any case, my 2006 already had the "new style" from factory.
Robert.
Old 02-01-2013, 09:51 PM   #14
trc.rhubarb
Oddometer: 2,012
I recently replaced the right side on my 07.
The old one seemed fine but replacing it made all the startup noise go away.
New looked the same as the old but wasn't as notchy.
Follow me here
Old 02-07-2013, 12:09 AM   #15
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Thank You Poolside This did it. It took longer to get the bike in a higher gear than to get the bolt started!! I litteraly was trying yesterday for 4 hours trying to get that Bolt started.. Thank You all again for your advise & Help!!!
You bet. It's nice when it's easy like that.
Times are GMT -7.   It's 05:37 PM.
