Old 01-31-2013, 12:45 PM   #1
moto_psycho OP
Nob.
moto_psycho's Avatar
Oddometer: 122
KTM LC4 Crank bearings?
Hi guys, my bike is making a sound identical to this video, http://www.youtube.com/watch?v=uJulJeJarhE
In which the author replied it was both his main bearings. My bike is a 2004 640, which means it should have the needle roller bearings (am I right?), would it be easier to change both bearings without splitting the cases? Or should I split the cases?
Not enjoying orange as much as the next guy.
moto_psycho is offline   Reply With Quote
Old 01-31-2013, 05:17 PM   #2
It'sNotTheBike
Oddometer: 704
If your bike sounds like the one in the link :
Best not to run the engine any more because if the bearings fail the crank
and cases can be damaged severely.
You may still find the cases have been damaged such that they cannot be re-used,
but the best course is to quit riding it or running the engine if you hope to salvage most
of the engine for re-use.
It'sNotTheBike is offline   Reply With Quote
Old 01-31-2013, 06:30 PM   #3
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,277
In that video he stated that it was one of the crankshaft end bearings that was causing the noise...
To replace that bearing the motor needs to be removed and the cases split, there is no other way...
Are you certain that the noise from your engine is indeed coming from the bottom end?
gunnerbuck is offline   Reply With Quote
Old 01-31-2013, 10:05 PM   #4
moto_psycho OP
Nob.
Oddometer: 122
Cry
As mentioned it is exactly the same as that video. I've checked with other videos that have the rocker fault and its not the same. Trouble is I have to ride it once more next month as I am moving house. Let's hope its not too mangled in there paid 2200 for this bike not long ago and another 350 for a set of wheels.
The noise is definitely louder on the bottom end... waa.
Old 01-31-2013, 10:11 PM   #5
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,809
Please for the love of God do not run the engine any more... You can destry it completely as some of us I have found
If it makes a noise, start stripping the engine, top to bottom and inspect. It is better to fix something before it falls apart and it goes all over the place. You should have the new bearings but that does not mean anything. Things can still fail. How many kms/miles on the clocks ?
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 02-01-2013, 03:21 AM   #6
moto_psycho OP
Nob.
Oddometer: 122
Literally it will be moving 3 miles to my new house, then I will start the rebuild. The bike is on 12,000 miles. Very annoying indeed.
When the mains go do you tend to get a lit of end float? Any other symptoms?
Old 02-01-2013, 03:44 AM   #7
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,502
I was able to upgrade mine without splitting the case, was a pita but worked.
Used this method:
http://www.advrider.com/forums/showthread.php?t=73558
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 02-01-2013, 05:50 AM   #8
moto_psycho OP
Nob.
Oddometer: 122
You used the same method to remove the main gearbox bearing to do the 2 crankshaft bearings?
Old 02-01-2013, 05:59 AM   #9
juames
juames's Avatar
Oddometer: 2,502
Uh no...I have a 2002 that required the main bearing upgrade. But I think you're jumping the gun a little bit based on listening to a YouTube video. Do a little investigating first, take the side covers off, check the cam bearing, etc...before you think the worse case. These motors make a racket even when everything is fine.
Old 02-01-2013, 06:41 AM   #10
moto_psycho OP
Nob.
Oddometer: 122
I'm a 'pessimo-optimist', I believe I created that term myself, basically;
Expect the worst, and only good things can happen to you .
I will start investigating in 26 days (day after the move). I'll try to be one of those people that video's and takes photo's of everything for the benefit of everyone else.
Suppose I'll get the frame powdercoated orange while I'm at it... standard black 640 looks a little... un-KTM like ;).
Old 02-01-2013, 07:16 AM   #11
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,277
Used this method:
The main crank end bearings are pressed in from the crank side and can not be passed through the cases like the main shaft bearing you are referring to...
Old 02-06-2013, 11:30 AM   #12
moto_psycho OP
Nob.
Oddometer: 122
I've had a good search, are there any OEM alternatives for the crank bearings? The wait has become too much and I'm going to at least diagnose this weekend!
Old 02-06-2013, 12:25 PM   #13
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,515
Not sure there are any other options for mains. The press-on inner race is a bit of a special item.
Has the bike been run out of oil or something? If it is a main bearing at 12K miles chances are something else is wrong, mine were still mint at 60K miles. Be aware you need special tools to change these bearings.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 02-06-2013, 12:32 PM   #14
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,277
Yes, you can get the crank end bearings through a bearing shop by using the bearing #s and they are usually cheaper...
Left side # nj 306 c3
Right side # nj 207 ecp c3
Old 02-06-2013, 03:24 PM   #15
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,415
you can also find higher quality. if the person at the counter knows their job, they should be able to take those numbers and find every make of bearing available at that exact size and dimensions. chose the highest quality available that you can afford.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Times are GMT -7.   It's 12:49 AM.
